[Other] polyDualMesh + Layers + cfMesh/improveMeshQuality = usable polyMeshes witH BLayer
Like Tree13Likes
  • 9 Post By FerdiFuchs
  • 1 Post By Lookid
  • 3 Post By Joko
Old   September 18, 2019, 06:56
Default polyDualMesh + Layers + cfMesh/improveMeshQuality = usable polyMeshes witH BLayer
Ferdinand Pfender
FerdiFuchs is on a distinguished road
Hi everyone,
i was trying a lot with polyDualMesh in combination with Netgen Meshes generated in Salome.
As most of us know already, polyDualMesh messes up with boundary Layers in Netgen Meshes and generates wrong oriented Faces, which makes the mesh unusable.
It seems, that it is possible to correct this wrong Faces with the cfMesh Tool "improveMeshQuality", to generate pretty suitable Polymeshes with Boundary Layers.
the procedure is as follows:
- create netgen Mesh with Layers (Use your favourite Tool)
- polyDualMesh -concaveMultiCells <angle>
- combinePatchFaces <angle>
- improveMeshQuality
Thats it! Have fun!
Best Wishes, FerdiFuchs
FerdiFuchs is offline   Reply With Quote
Old   May 8, 2020, 18:05
Lilian Chabannes
Lookid is on a distinguished road
Very good stuff thanks!
Any additional tips for boundary layer generation in SALOME? It messes things up for me most of the time.
lourencosm likes this.
Feel free to join the OpenFOAM Discord https://discord.gg/P9p9eHn, a live chat about OpenFOAM
Lookid is offline   Reply With Quote
Old   February 11, 2022, 11:27
Jost Kemper
Jost K is on a distinguished road
Thanks Fredi!
Your approach really does produce usable poly meshes!
I have experimented a bit with creating the prism layers with snappyHexMesh as a final step to the process (i.e. after using improveMeshQuality).
It works quite nicely so far.
Cheers,
Jost
Jost K is offline   Reply With Quote
Old   May 25, 2022, 08:17
Joko is on a distinguished road
Hello Ferdi, Hello Jost.
First of all, thanks to Ferdi. This helped me to create the first meshes with PolyDualMesh. However, I always had the problem with the boundary layers. With "ImproveMeshQuality" I always had the problem that the layers were "pulled out" of the corners. See picture in the attachment.
I think the idea of creating the layers afterwards is great, thanks Jost. But with SnappyHexMesh I always have the problem that the layers are not created correctly. If I get a "thickness" of the layers of 70% with Snappy, then I am usually super happy. Layer generation with cfmesh works much better.
So why do you use snappyHexMesh for layer generation?
You can also use the cfmesh command "generateBoundaryLayers" to create layers with cfmesh only. I am currently doing my first tests with this method and the first results look very good.
klausb, lourencosm and Nikoonz like this.
Joko is offline   Reply With Quote
[snappyHexMesh] Help with Snappy: no layers growing GianF OpenFOAM Meshing & Mesh Conversion 2 September 23, 2020 09:26
[snappyHexMesh] Collapsing layers RomCFD OpenFOAM Meshing & Mesh Conversion 5 January 18, 2020 02:39
[ICEM] Prism layers distorted near trailing edge of blade-Unstructured Mesh Rohith Giridhar ANSYS Meshing & Geometry 3 June 29, 2015 18:52
[mesh manipulation] Sharp edge problem on concave patches using polyDualMesh without error keepfit OpenFOAM Meshing & Mesh Conversion 1 November 25, 2014 15:28
Fluent diverges when using inflation layers ziggo FLUENT 4 August 9, 2013 13:11
