[snappyHexMesh] Mesh does not snap to geometry
Like Tree2Likes
  • 1 Post By simrego
  • 1 Post By OskarT
Old   September 16, 2019, 05:27
Default Mesh does not snap to geometry
Oskar T
OskarT is on a distinguished road
I am trying to setup do aerodynamics simulation of a car using symmetry. I've exported the car as STL file from freecad.
I've used blockMesh together with snappyHexMesh but got no snapping at all as seen below.
You can see the images here: https://drive.google.com/drive/folde...Z4?usp=sharing
blockMesh
|  \\    /   O peration     | Version:  v1906                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
scale   1;
vertices
    (-4 -0.5 -2) // 0
    (11 -0.5 -2) // 1
    (11  3 -2) // 2
    (-4  3 -2) // 3
    (-4 -0.5 0) // 4
    (11 -0.5 0) // 5
    (11  3 0) // 6
    (-4  3 0) // 7
blocks
    hex (0 1 2 3 4 5 6 7) (120 30 20) simpleGrading (1 1 1)
edges
boundary
    Sym
        type symmetryPlane;
        faces
            (4 5 6 7)
    backPanel
        type symmetryPlane;
        faces
            (3 2 1 0)
    Inlet
        type patch;
        faces
            (4 7 3 0)
    Outlet
        type patch;
        faces
            (1 2 6 5)
    Ground
        type wall;
        faces
            (0 1 5 4)
    Top
        type symmetryPlane;
        faces
            (3 7 6 2)
snappyHexMesh
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
#includeEtc "caseDicts/mesh/generation/snappyHexMeshDict.cfg"
// Which of the steps to run
castellatedMesh true;
snap            true;
addLayers       false;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
    Car
        type triSurfaceMesh;
        file "Car.stl";
// Settings for the castellatedMesh generation.
castellatedMeshControls
	// Specifies a level for any cell intersected by its edges.
    // This is a featureEdgeMesh, read from constant/triSurface for now.
    features
//      { file "CAD.eMesh"; level 1; }
    // Surface based refinement
    // Specifies two levels for every surface. The first is the minimum level,
    // every cell intersecting a surface gets refined up to the minimum level.
    // The second level is the maximum level. Cells that 'see' multiple
    // intersections where the intersections make an
    // angle > resolveFeatureAngle get refined up to the maximum level.
    refinementSurfaces
        Car
            // Surface-wise min and max refinement level
            level (3 3);
	resolveFeatureAngle 10;
	    refinementRegions
		refinementBoxA
            mode inside;
            levels ((1 1)); //Le 1 n'a aucune influence pour une box //------1
    locationInMesh (0 0.1 -0.1); // Offset from (0 0 0) to avoid coinciding with face or edge
	maxLocalCells 1500000;
    maxGlobalCells 2000000;
	minRefinementCells 10;
    nCellsBetweenLevels 6;
// Settings for the snapping.
snapControls
    nSmoothPatch 3;
    tolerance 4;
    nSolveIter 100;
    nRelaxIter 5;
// Settings for the layer addition.
addLayersControls
    layers
        "Car.*"
            nSurfaceLayers 6;
        bottom
            nSurfaceLayers 6;
    relativeSizes       false; // false, usually with firstLayerThickness
    expansionRatio      1.2;
//    finalLayerThickness 0.5;
    minThickness        1e-3;
    firstLayerThickness 0.01;
//  maxThicknessToMedialRatio 0.6;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
    minTetQuality -1e+30;
/*writeFlags
//    scalarLevels
    layerSets
    layerFields
mergeTolerance 1e-6;
Any ideas on how to fix this?
OskarT is offline   Reply With Quote
Old   September 16, 2019, 05:55
anonymous
simrego is on a distinguished road
Hi!
What was the command for snappyHexMesh?
You may missed the -overwrite switch, so you will find your snapped mesh at the second time step.
Also that tolerance is a bit high, you can use the "default" 2.
And as i see you have no feature snapping.
Try to put this into the snapControls:
implicitFeatureSnap true;
explicitFeatureSnap false;
Or:
implicitFeatureSnap false;
explicitFeatureSnap true;
But you will need the edge mesh for this what you are commented in the castellatedMeshControls. This is the default setup, so you can simply uncomment the features without adding these lines.
Maybe this won't solve your problem but you will need it to capture the features.
OskarT likes this.
simrego is offline   Reply With Quote
Old   September 16, 2019, 06:14
Oskar T
Boy do I feel stupid, haha!
It was hiding in the second time step. "snappyHexMesh -overwrite" solved my problem!
I also changed the tolerance down to 2 and opt for the implicit snapping feature but these was not the solution to my problem, my command was.
Thank you!
simrego likes this.
blockmesh, hexmesh, mesh, snap, snappyhexmesh
[ANSYS Meshing] How to mesh this geometry to get best quality?(provide your suggestion) Roh ANSYS Meshing & Geometry 1 October 10, 2017 14:23
[snappyHexMesh] snappyHexMesh & Mesh around a missile sasanghomi OpenFOAM Meshing & Mesh Conversion 2 October 15, 2014 20:54
Inner geometry gets lost exporting mesh from ICEM CFD to CFX-Pre powpow CFX 3 December 20, 2012 10:14
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 15:09
