[Other] splitMeshRegions does not create interface patch between regions
Like Tree3Likes
  • 1 Post By fsan
  • 2 Post By mwaqas
Old   August 16, 2019, 11:34
Default splitMeshRegions does not create interface patch between regions
fsan is on a distinguished road
Here's my problem, I'm trying to do a simulation with chtMultiRegionFoam to check the thermal evolution in the surface of a pipe.
The geometry contain a fluid region with relatitive cold methan, around it a solid region for the pipe and arounnd the pipe a fluid region for hot air.
The mesh was created on the Ansys Workbench (spaceClaim and fluent meshing) and was import to openFoam with the "fluent3DMeshToFoam" command.
Then when I try to split the mesh into different region by typing
in the terminal:
splitMeshRegions -cellZones -overwrite
The three different region are well recognize but no interface patch are created (like "fluidToSolid" and "solidToofluid") as you can see in the output given in the terminal:
Create time
Create mesh for time = 0
Creating single patch per inter-region interface.
Trying to match regions to existing cell zones.
Number of regions:3
Writing region per cell file (for manual decomposition) to "/media/ubuntu/DATAS/Run/Coude/Coudemsh3/constant/cellToRegion"
Writing region per cell as volScalarField to "/media/ubuntu/DATAS/Run/Coude/Coudemsh3/0/cellToRegion"
Region	Cells
0	6867
1	37308
2	142547
Region	Zone	Name
0	0	fff-solid-pipe
1	1	fff-fluid-pipe
2	2	fff-fluid-air
Sizes of interfaces between regions:
Interface	Region	Region	Faces
Reading geometric fields
Reading volScalarField cellToRegion
Adding patches
Adding patches
Region 0
Creating mesh for region 0 fff-solid-pipe
Testing:"/media/ubuntu/DATAS/Run/Coude/Coudemsh3/system/fff-solid-pipe/fvSchemes"
Mapping fields
Mapping field cellToRegion
Deleting empty patches
Writing new mesh
Writing addressing to base mesh
Writing map pointRegionAddressing from region0 points back to base mesh.
Writing map faceRegionAddressing from region0 faces back to base mesh.
Writing map cellRegionAddressing from region0 cells back to base mesh.
Writing map boundaryRegionAddressing from region0 boundary back to base mesh.
Region 1
Creating mesh for region 1 fff-fluid-pipe
Testing:"/media/ubuntu/DATAS/Run/Coude/Coudemsh3/system/fff-fluid-pipe/fvSchemes"
Mapping fields
Writing new mesh
Writing map pointRegionAddressing from region1 points back to base mesh.
Writing map faceRegionAddressing from region1 faces back to base mesh.
Writing map cellRegionAddressing from region1 cells back to base mesh.
Writing map boundaryRegionAddressing from region1 boundary back to base mesh.
Region 2
Creating mesh for region 2 fff-fluid-air
Testing:"/media/ubuntu/DATAS/Run/Coude/Coudemsh3/system/fff-fluid-air/fvSchemes"
Mapping fields
Writing new mesh
Writing map pointRegionAddressing from region2 points back to base mesh.
Writing map faceRegionAddressing from region2 faces back to base mesh.
Writing map cellRegionAddressing from region2 cells back to base mesh.
Writing map boundaryRegionAddressing from region2 boundary back to base mesh.
End
The problem is that I can't use the "compressible::TurbulentTemperatureCoupledBaffleMi xed" or the "compressible::TurbulentTemperatureRadCoupledMixed " boundary condition, this mean that I have one same patch contained in two different region.
Even if I try to launch my simulation, I have the folowing fatal error: " not type 'mappedPatchBase' ".
I tried to replace in the polymesh the 'wall' by 'mappedWall' but it's still not working.
I would like to ask if some of you know how I can create those interface patch? If there is a command that can help to separate the patch shared by two region in two or any other clue.
Thank you
fsan is offline   Reply With Quote
Old   August 22, 2019, 05:54
Muhammad Waqas
mwaqas is on a distinguished road
Send a message via Skype™ to mwaqas
Hello Fsan,
This problem occurs when you have non-conformal mesh in Ansys. Make a conformal mesh in Ansys and you will get a mappedWall.
Regards
mwaqas is offline   Reply With Quote
Old   August 23, 2019, 06:20
Hello Muhammad,
Thank you for you reply, I did check if the mesh was non-conformal or not but it look like a conformal mesh for me.
I upload some screen of the different region separation so you can all tell me what you think about it. The green and red region are fluid while the white region is a solid.
I can also upload the msh file if needed.
Thank you
Old   August 23, 2019, 06:37
Muhammad Waqas
The mesh is conformal.
Then, there might be a problem with your BC.
Can you please upload your BC file (0/P or U, wherever is the problem) as well as your polyMesh/boundary file of problematic regions.
Probably, you are not giving correct BC.
Regards
Old   August 23, 2019, 09:39
Alright I upload the boundary files for each of the region (fluidAir, fluidNG and solid). And I'll post just below the boundary condition for U:
For the fluid air region:
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  dev
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    location    "0/fff-fluid-air";
    object      U;
dimensions      [ 0 1 -1 0 0 0 0 ];
internalField   uniform (0 0 0);
boundaryField
    #includeEtc "caseDicts/setConstraintTypes"
    inlet-air
        type            fixedValue;
        value           uniform (-0.15 0 0);
    outlet-air
        type            pressureInletOutletVelocity;
        value           $internalField;
    wall-fff-fluid-air
        type            noSlip;
    wall-fff-fluid-air-fff-solid-pipe
        type            noSlip;
And for the fluid Natural Gas region:
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    location    "0/fff-fluid-pipe";
    object      U;
boundaryField
    inlet-gas
        type            fixedValue;
        value           uniform (0 0.15 0);
    outlet-gas
    wall-fff-fluid-pipe-fff-solid-pipe
        type            noSlip;
The main problem I think is during the generation of the interface patch (solid_to_fluid and fluid_to_liquid) when i execute:
As I don't get the mappedWall boundary condition for my T field where I need to use it, I can't use it afterward.
And I don't know what other BC I could use for the T fields instead of the coupled BC.
Thank you for your help.
Old   August 23, 2019, 11:09
Muhammad Waqas
You are not getting any coupled wall during mesh conversion. I had this problem once when I had exported Ansys mesh to Openfoam. It was due to the non-conformal mesh. As I wasn't having any coupled wall in Ansys meshing.
It is looking like to me that you don't have coupled wall in Ansys meshing (because if there would be a coupled wall, you would have automatically got in OpenFOAM ).
You can do these things:
1) Check in fluent if your interface type is coupled or not. I suspect, it wont be.
2) Create coupled interface and then export to OpenFOAM.
Regards
fsan and ajithnair like this.
Old   August 23, 2019, 11:35
Thank you again for your reply.
I can't have acces to fluent now but when I will, I'll tell here if it would work or not.
Regards
Old   August 27, 2019, 12:18
Hi Muhammad,
Naming each side of the interface in fluent did make the job, openFoam now recognize my interface and patch them. Thank you for the help.
Unfortunately, right now my simulation is not working as I wish, certaintly because of the BC, the scheme or the thermophysical model I don't know yet.
Regards
Old   March 9, 2022, 05:30
Default No interface found with spliMeshRegions
eugenioS is on a distinguished road
Dear All,
I am currently facing a very similar problem to the one that you describe here.
Starting from a multi-region unstructured mesh built with ICEMCFD and exported in *.msh format, I'm importing it to openfoam using fluent3DMeshToFoam (fluentMeshToFoam not working). The import is performed correctly, however, when I employ splitMeshRegions to generate my subdomains, the interface patch is not recognized.
The 3D mesh is apparently completely mapped, and I've tried with several way of dealing with the interface, e.g. with or without prism layer, or even with a mostly mapped structured mesh.
I have tested splitMeshRegions with several different flags but the results is the same.
The version that I employ is v2012.
Do you know from where the problem might come?
Thank you in advance for your valuable advise
Dr. Eugenio Schillaci
eugenioS is offline   Reply With Quote
Old   March 30, 2022, 08:09
Nico
Hr_kules is on a distinguished road
Hey Eugenio,
i faced a similar problem and solved it by using the createPatch dict and take the boundaries that i want to have mapped and directly write them in the file, the result is pretty much the same as with the automatically generated patches.
Hr_kules is offline   Reply With Quote
Old   June 6, 2022, 06:56
JuanMi
keitaro7_14 is on a distinguished road
You can follow those 2 Youtube Video to understand the procedure:
https://www.youtube.com/watch?v=04uqs6ERJa4
https://www.youtube.com/watch?v=NjUtTvzVULA
Result:
https://youtu.be/qdGUBnPqx7o
At least in Salome it is the proper way to do it. you have to create a Partition of the solids in order to create an unique entity. Afterwards, define the external boundary only (Group of Faces) and the solids (Group of Volumes).
That's all.
keitaro7_14 is offline   Reply With Quote
chtmultiregionfoam, mappedpatchbase error, splitmeshregions
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 03:01
Radiation interface hinca CFX 15 January 26, 2014 18:11
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 03:34
