[mesh manipulation] topoSet for stl files
Like Tree2Likes
  • 1 Post By Owais Shabbir
Old   July 24, 2019, 11:55
Default topoSet for stl files
Owais Shabbir
Owais Shabbir is on a distinguished road
Dear All,
I am starting to work with topoSet and it is slightly confusing when it comes to using .stl files in it.
My goal is bring set of batteries generating heat due to charging in chtMultiRegion solver.
I have few questions that if someone could answer, it will be highly appreciated.
1) In snappyHexMeshDict when I set
  refinementSurfaces
	batteries_c3  {	level (2 2);
	faceZone batt1;
        cellZone batt1;
        cellZoneInside inside;
Is this cellZone that I created called batt1, be mentioned anywhere in topoSetDict file?
2) My geometry composes of 32 rectangular boxes, but when I try topoSet using
        name 	battCellSet;
	type 		cellSet;
	action	new;
	source	surfaceToCell;
	sourceInfo
		file "/mnt/...../refined1x_cht_toposet/constant/triSurface/batteries_c3.stl";
		useSurfaceOrientation false;
		outsidePoints	((0.46 0.0345 -0.1445183)); //vector chosen from ASCII stl file line 18
		includeCut	true;
		includeInside true;
		includeOutside false;
		nearDistance -1;
		curvature 0.9;
        name    batt;
        type    cellZoneSet;
        action  new;
        source  setToCellZone;
        sourceInfo
            set battCellSet;
It creates cells only at the boundary of stl which are assigned to battCellSet. Which makes sense from the choice. But is there a way to chose even the cells inside? Because when I want to use the option of invert later to assign the remaing domain to fluid region, the hollow volume inside batteries creates cellSetZone together with the outer cellSetZone.
3) I would highly appreciate if someone could explain nearDistance and curvature values to me, what are the ranges of the values, etc. I tried reading through the topoSet.C file but my knowledge of understanding it is very low.
Attaching my *Dict files.
Thanks
Owais - new to OFv6
File Type: c surfaceFeatureExtractDict.c (1,001 Bytes, 49 views)
Owais Shabbir is offline   Reply With Quote
Old   July 25, 2019, 05:13
Red face Resolved but splitMeshRegions gives a fatal error
Owais Shabbir
Hi all,
I was able to resolve it. I figured out all the cells saved through SHMDict were saved in constant/polyMesh/cellZones
so the right settings for topoSet to utilise were these:
name	battCellSet;
type	cellSet;
action	new;
source	zoneToCell;
sourceInfo
{	name 	"batt1"; //name assigned in SHMDict
        name    batteries;
        type    cellZoneSet;
        action  new;
        sourceInfo
            set batteriesCellSet;
This works fine when seen through paraview.
Problem is when I use splitMeshRegions I get a Fatal Error!
Create time
Create mesh for time = 0
Using current faceZones to divide inter-region interfaces into multiple patches.
--> FOAM FATAL ERROR:
Cell 0 with cell centre (-0.026349986 -0.0021249995 -0.17876937) is multiple zones. This is not allowed.
It is in zone batt1 and in zone fluid
    From function void getZoneID(const Foam::polyMesh&, const cellZoneMesh&, Foam::labelList&, Foam::labelList&)
    in file splitMeshRegions.C at line 1225.
FOAM exiting
I have tried different options but this is something I can't get rid of.
Any help!
Thanks
Owais
dasith0001 likes this.
Old   July 25, 2019, 06:46
Talking Solution
Owais Shabbir
Dear All,
So I figured out the error (well not really an error) was due to polyMesh/cellZones.
There were 3 regions instead of 2.
1st cellzone: batt1 defined by SHMDict
2nd cellzone: defined by topoSet called batteries
3rd cellzone: also defined by topoSet called fluid
learning: So just don't have additional names and it should be simple. Chose batt1 for both SHMDict and topoSet.
Have a nice day.
Old   October 21, 2020, 12:04
Default request
faramarz
aerospace1365 is on a distinguished road
Send a message via Yahoo to aerospace1365
Dear Sir,
Would you please contact me by aerospace1365@gmail.com.
Sincerely yours,
Hosein Faramarzpour
aerospace1365 is offline   Reply With Quote
Old   November 8, 2020, 18:42
Farzad Faraji
farzadmech is on a distinguished road
Dear Owais Shabbir
I have a problem with my STL file. it must be binary or ascii? where should I put as external point? exactly at the surface?
Thanks,
Farzad
Originally Posted by Owais Shabbir View Post
Dear All,
Have a nice day.
farzadmech is offline   Reply With Quote
chtmultiregion, toposet, toposet.c, toposetdict
problem compiling with header files jreiter164 Fluent UDF and Scheme Programming 2 August 14, 2015 18:31
attaching trn files hossein_sml CFX 1 August 5, 2015 20:17
How to call FORTRAN files as UDF? Ehsan-F Fluent UDF and Scheme Programming 6 September 11, 2012 12:03
Writing Case and Data Files Using Journal/Scheme Files svp Fluent UDF and Scheme Programming 0 April 5, 2011 12:04
Problems with result files Kasper CFX 5 December 14, 2006 03:41
