[snappyHexMesh] TopoSet does not select all faces |
Mondal
Rep Power: 7 ![]() |
Hi everyone,
Hope you are doing well. Recently, I have stuck in a situation and can not understand how this problem can be solved. My problem is with topoSet. Lets briefly describe what I am trying. Please have a look at the attachment. I would like to create two different faceSets from an STL surface meshed using snappyhexmesh. First of all, I created a 3D meshing and then converted into 2D using extrudeMesh utility. After doing this, when I apply topoSet, it runs perfectly and produced two different faceSets. But the faceSet created by topoSet seems to miss some of the faces (see attached picture). I can not understand what's happening here. Why these cells are not selecting?. Is that the problem of Meshing (CheckMesh shows Mesh Ok)? or defining topoSet? For better clarification, I also attached my topoSet and createPatch dictionary. Can anyone comment on it so that I can understand what the problem is? Any help would be appreciated. I didn't find any thread about this issue. Regards Razon |
#2 | |
Mondal
Problem Resolved...... |
Owais Shabbir
Would you like to share the solution? Thanks. Owais |
Mondal
Hi Owais,
Sure.It was just a problem of defining the coordinates of the two extreme points. I made a mistake to select wrong coordinate of Z direction. If you face this kind of problem, I would suggest please check the bounding box carefully before putting it in the topoSet. I think slicing by paraview is the best way to identify the coordinates of the bounding box. Have fun! Cheers Razon |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 14:53 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 13:38 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
