[blockMesh] wedge patch is not planar
Like Tree3Likes
  • 3 Post By GerhardHolzinger
Old   July 17, 2019, 12:08
Unhappy wedge patch is not planar
Majid Arjmandi
majidsvn7 is on a distinguished road
I had a problem with this axisymmetric geometry in blockMesh, I've used "movingCone" Tutorial from the openFOAM Tutorial folder and create the mesh alike in form this tutorial instruction.
After running blockMesh and checkMesh, I encounter with this error.I really need your help ...
the blockMesh file has been attached and the error is in below form.
--> FOAM Warning :
From function virtual void Foam::wedgePolyPatch::calcGeometry(Foam::PstreamBu ffers&)
in file meshes/polyMesh/polyPatches/constraint/wedge/wedgePolyPatch.C at line 70
Wedge patch 'front' is not planar.
At local face at (29.9502 4.462631 0.1948429) the normal (-3.334594e-16 -0.0436195 0.9990482) differs from the average normal (5.775252e-20 -0.04361943 0.9990482) by 5.931354e-15
Either correct the patch or split it into planar parts
--> FOAM Warning :
At local face at (29.9502 4.475863 0.1954206) the normal (-8.614346e-16 -0.0436195 0.9990482) differs from the average normal (5.775252e-20 -0.04361943 0.9990482) by 5.931354e-15
--> FOAM Warning :
At local face at (29.9502 4.489096 0.1959984) the normal (-4.730452e-16 -0.0436195 0.9990482) differs from the average normal (5.775252e-20 -0.04361943 0.9990482) by 5.931354e-15
checkMesh :
Checking geometry...
Overall domain bounding box (0 0 -0.1962872) (30 4.495712 0.1962872)
Mesh has 2 geometric (non-empty/wedge) directions (1 1 0)
Mesh has 3 solution (non-empty) directions (1 1 1)
Wedge back with angle 2.500002 degrees
***Wedge patch back not planar. Point (0 0.7939456 -0.03466441) is not in patch plane by 3.059446e-08 metre.
Boundary openness (1.555391e-19 -1.353222e-14 -2.299723e-13) OK.
Max cell openness = 2.073679e-16 OK.
Max aspect ratio = 12.04334 OK.
Minimum face area = 1.194516e-05. Maximum face area = 0.03910105. Face area magnitudes OK.
Min volume = 2.379515e-07. Max volume = 0.0005166389. Total volume = 23.42307. Cell volumes OK.
Mesh non-orthogonality Max: 0 average: 0
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 0.3307965 OK.
Coupled point location match (average 0) OK.
Failed 1 mesh checks.
End
majidsvn7 is offline   Reply With Quote
Old   July 18, 2019, 05:19
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
It's most probably the precision of the points you provide in the file blockMeshDict.
Calculating the half-angle of the wedge, using python yields the following:
>>> import math
>>> a1=math.atan(0.1962872431/4.49571169971)
>>> a2=math.atan(0.1090484684/2.4976205539)
>>> a1
0.04363328263897132
>>> a2
0.04363323129548074
>>> a1/a2
1.0000011767061265
>>> math.degrees(a1)
2.5000029415145035
>>> math.degrees(a2)
2.4999999997491877
Also, the error message of OpenFOAM can be interpreted to point to insufficient precision:
At local face at (2.679282868525897 1.265350810419537 -0.05524640948741723) the normal (1.743214710593797e-16 -0.04361938736096225 -0.9990482215820488) differs from the average normal (-6.901918021236692e-20 -0.04361942583205133 -0.9990482199023509) by 1.482846079653545e-15
which translates to:
At the face X, the normal vector \vec{n_X} differs from the average normal vector (the normal vector averaged over all faces) \overline{\vec{n_i}} by very little (note the *e-15)
majidsvn7, Aabadani and Y.H like this.
GerhardHolzinger is offline   Reply With Quote
Old   July 18, 2019, 06:01
Majid Arjmandi
First of all, I need to thank you for paying attention to my work. By using your tips, The errors and warnings were resolved after applying the highest order of accuracy in defining the relevant points. I also used Python to calculate the half-angles of the wedge, but I often entered the points with less precision. Thank you again.
blockmesh, planar
[Other] Wedge patch '*' is not planar LilumDaru OpenFOAM Meshing & Mesh Conversion 7 September 18, 2024 06:52
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
steadyUniversalMRFFoam Tutorial fails in MixingPlane HenrikJohansson OpenFOAM Bugs 0 February 14, 2019 05:48
Near wall treatment in k-omega SST Arnoldinho OpenFOAM Running, Solving & CFD 38 March 8, 2017 14:48
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
