[snappyHexMesh] Disable balancing in snappyHexMesh
Like Tree2Likes
  • 2 Post By kmooney
Old   May 21, 2019, 16:54
Default Disable balancing in snappyHexMesh
wildfire230 is on a distinguished road
Hi All,
I am wondering if it is possible to disable the balancing step in snappyHexMesh? I have noticed that it is consuming a significant percentage of the total computation time of the meshing process, and I am curious what the consequences would be if we disable this balancing step? For my specific geometry, I know approximately how the final refined grids will be distributed, and I can easily use decomposePar to decompose the mesh into the appropriate regions where the cell distributions are relatively well balanced.
Does anyone have any insights into this?
Thanks
wildfire230 is offline   Reply With Quote
Old   May 21, 2019, 17:57
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
I'd say give it a shot and see what happens. I'm guessing you can just set the maxLoadUnbalance value to say 1.0 in snappyHexMeshDict to avoid the rebalancing operations.
snak and wildfire230 like this.
kmooney is offline   Reply With Quote
Old   May 22, 2019, 17:40
Thanks so much, you're right, that does the trick!
balancing, parallel, snappyhexmesh
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 02:37
[snappyHexMesh] snappyHexMesh Boundary Layer at Corner panpanzhong OpenFOAM Meshing & Mesh Conversion 5 July 3, 2018 06:53
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 03:54
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 03:55
[snappyHexMesh] Problem with snappyhexMesh: modelling a pore chamber and pore throat model Saideep OpenFOAM Meshing & Mesh Conversion 5 May 10, 2015 15:46
