[snappyHexMesh] Meshing a STL file which has holes
Like Tree1Likes
  • 1 Post By simrego
Old   May 13, 2019, 04:21
Default Meshing a STL file which has holes
Owais Shabbir
Owais Shabbir is on a distinguished road
Dear Forum people,
I am new to meshing on snappyHexMesh. Currently, I am trying to mesh a protecting case of batteries. It contains a lot holes of diameter 7mm.
I have tried changing the level of refinements and also a few other parameters to increase the refinement around the holes to achieve a circular refinement but as you can see the holes in the attached picture, they always have a non-circular shape.
I chose the snappyHexMeshDict file from the snappyMultiRegionHeater meshing tutorial and set the case according to my geometry.
Any help would be appreciated.
Owais Shabbir is offline   Reply With Quote
Old   May 13, 2019, 09:47
anonymous
simrego is on a distinguished road
Hi!
It seems like if you loaded the castellated mesh not the snapped one.
Check how many timesteps do you have. If you have anything else not just a 0 folder, you have to check the last time in paraview or you will see the castellated mesh (by default 0 time is skipped). If you have this problem you can solve it by using the -overwrite switch in snappyHexMesh so you will overwrite your mesh at the 0 time.
If you don't have more timesteps, check if the snappying is enabled in the snappyHexMeshDict (at the begining of the file).
Owais Shabbir likes this.
simrego is offline   Reply With Quote
Old   May 14, 2019, 08:33
Owais Shabbir
I checked and it is turned on.
I am thinking maybe there is a new entity that I might have to introduce to refine the hole regions.
Btw just to clarify this is a solid present in the domain, I am meshing the flow domain around this solid.
This is the SHMDict that I am using, may be you can pick which entity should be improved/added.
            castellatedMesh   true;
   snap            true;
   addLayers       false;
   geometry
   {    topcover
           type triSurfaceMesh;
           file "topcover.stl";
   refinementBox   {type searchableBox;
   min   (-0.02 -0.01 -0.01);
   max   (0.7 0.03 0.2);}
   castellatedMeshControls
       maxLocalCells 500000;
       maxGlobalCells 5000000;
       minRefinementCells 10;
       nCellsBetweenLevels 3;
    features
               file "topcover.eMesh";
               level 4;
       refinementSurfaces
           topcover
           {            level (5 5);
               faceZone topcover;
               cellZone topcover;
               cellZoneInside outside;
      resolveFeatureAngle 5;
       refinementRegions
       //      refinementBox
       //        mode inside;
        //       levels ((1E15 1));
       locationInMesh (-0.1 -0.1 -0.25);
      allowFreeStandingZoneFaces true;
   snapControls
        nSmoothPatch 3;
       tolerance 4.0;
       nSolveIter 30;
       nRelaxIter 5;
       nFeatureSnapIter 15;
   implicitFeautureSnap        false;
   explicitFeatureSnap                true;
   multiRegionFeatureSnap        false;
   addLayersControls
       relativeSizes true;
           topcover
               nSurfaceLayers 3;
       expansionRatio 1.3;
       finalLayerThickness 0.02;
       minThickness 0.01;
       nGrow 1;
       featureAngle 80;
       nRelaxIter 3;
       nSmoothSurfaceNormals 1;
      nSmoothNormals 3;
       nSmoothThickness 2;
       maxFaceThicknessRatio 0.5;
       maxThicknessToMedialRatio 1;
       minMedianAxisAngle 90;
       nBufferCellsNoExtrude 0;
       nLayerIter 50;
   meshQualityControls
       #include "meshQualityDict"
   ce   needs to be higher than this.
   mergeTolerance   1e-6;
I have removed the comments so it is clear and concise to be read.
holes, mesh around holes, snappyhesmeshdict, snappyhexmesh
[OpenFOAM.org] Patches to compile OpenFOAM 2.2 on Mac OS X gschaider OpenFOAM Installation 136 October 10, 2017 18:25
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 11:03
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 12:46
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
