[Salome] SALOME and Partition operation problems |
March 25, 2019, 17:11 |
Nejc
Rep Power: 9 |
Hello.
This doesn't really belong to OpenFOAM and snappyHexMesh but this is the most relevant forum I can think of. I'm preparing STL files for multiregion snappy with salome. I Import STEP assembly, explode it to solids and do a Partition. Then I create volume groups for each of the solids and face groups from volume groups (the standard procedure, I guess? Or is there a simpler method?). My problem is that some of the faces are misteriously missing from the face groups. See the attached images. Has anyone had similar issues? Where do I even begin with the troubleshooting? Thanks! |
March 25, 2019, 18:52 |
Mattia
Rep Power: 8 |
try to explode the partition into solids and create face groups from those. In SMESH you will make a group on geometry also for volumes, selecting the exploded solids. By the way, what do you use as base for partition? As the very model is already exploded I guess you build a primitive to use partition on to obtain fluid volume. Is it correct? In the second pic you highlighted only 3 "missing" surfaces, but I guess all the caps are missing, correct? In this case another thing you could try is to repair the model (try glue edges / glue faces) just to be sure the geometry is a single piece. One last thing: what shape type did you select in the partition menu? Be sure to select solid and not compsolid. Anyways, without knowing exactly all the steps you did I can't say more. Bye |
March 26, 2019, 07:21 |
#3 | ||||
Nejc
Rep Power: 9 |
You need say no more, you got it right in the first try Thank you very much! |
March 26, 2019, 07:59 |
#4 | |
Mattia
Rep Power: 8 |
I don't know which CAD software you are using, I work mostly with Rhino6 so I can speak only for my specific case but usually I do split my model using feature edges and then rejoin (not fusing, just joining) everything together. When I import the resulting step file into Salome I get a single solid (or shell) but I can explode it into single parts. Splitting is like partitioning in Rhino and joining is kinda compound feature. Keep in mind I always work with surfaces and not solids, but I always get a watertight solid when I import the step into Salome. I dropped Inventor due to license costs so I don't know if inventor/solidworks work the same way rhino does. Bye |
March 26, 2019, 08:32 |
Nejc
Rep Power: 9 |
I use Creo and i'm almost certain there's no such option. I could split surfaces by hand but here's a complex assembly of 60+ objects which I have no intention to tamper with by hand.
I'm writing a script to automate the salome process so I need simple and reliable steps. So far it looks like it can be done |
March 28, 2019, 15:25 |
Nejc
Rep Power: 9 |
FYI, in the end I couldn't get it to work with face groups so I chose a different approach:
Thank you for your help. |
April 28, 2021, 16:59 |
#7 | |
TL
Rep Power: 5 |
I have similar problem to yours. But I am dealing with STL file. I could not explode it to solids. Do you have any idea about how to deal with STL assembly? Thank you. Regards, Tongfen |
April 28, 2021, 17:25 |
Nejc
Rep Power: 9 |
in my experience salome is terrible with STLs but my experience is very limited. maybe you could try with blender, at least that's where i would start...
April 28, 2021, 20:40 |
#9 |
TL
Rep Power: 5 |
Hi Kandelabr,
Actually I build my objects in Blender, and export to STL file to Salome. Salome could not recognize different objects. Can you take a look at my post: How to create Volume group from STL file of assembly Thanks. Regards, Tryphena |
