February 14, 2019, 10:00 |
Problem with face matching
Alejandro
Hello, first of all this is my first question in the forum so I apologise for any mistake I can make.
I am trying to create a 3D C-grid with blockMesh to use it as background mesh in snappyHexMesh, and I have almost succeeded except for a problem with face matching. To create it, I have divided the domain in 2 quarters of cylinders and 1 prism, but the problem is that blockMesh sets as defaultFaces the face between the prism and the two quarters and this is a face I expected that blockMesh would ignore. When I tried to use mergePatchPairs as an alternative I got an error message about no cell neighbours faces. I attatch the blockMeshDict and an Image of the C-grid side with the problematic face outlined in red. Does anyone know how to remove that defaultFace or how to correct my blockMeshDict so this problem does not appear? HTML Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1812 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (74 844.8 0)//0 (-770.8 0 0)//1 (74 -844.8 0)//2 (74 844.8 30)//3 (-770.8 0 30)//4 (74 -844.8 30)//5 (74 0 0)//6 (74 0 30)//7 (844.8 -844.8 0)//8 (844.8 844.8 0)//9 (844.8 844.8 30)//10 (844.8 -844.8 30)//11 ); blocks ( hex (1 2 6 6 4 5 7 7) (20 20 2) simpleGrading (1 1 1) //cuarto de cilindro hex (0 1 6 6 3 4 7 7) (20 20 2) simpleGrading (1 1 1) //cuarto de cilindro hex (0 2 8 9 3 5 11 10) (30 15 2) simpleGrading (1 1 1) //cubo (30 celdas en y 15 en x ) ); edges ( arc 1 2 (-523.3638087 -597.3638087 0) arc 0 1 (-523.3638087 597.3638087 0) arc 4 5 (-523.3638087 -597.3638087 30) arc 3 4 (-523.3638087 597.3638087 30) ); boundary ( inlet { type patch; faces ( (5 4 1 2) (4 3 0 1) ); } outlet { type patch; faces ( (8 9 10 11) ); } frontAndBack { type symmetry; faces ( (3 4 7 7) (4 5 7 7) (5 11 10 3) (2 1 6 6) (1 0 6 6) (0 9 8 2) ); } topAndBottom { type wall; faces ( (3 10 9 0) (5 2 8 11) ); } ); mergePatchPairs ( //( ) merge patch pair 0 ); // ************************************************************************* // Thank you!! Last edited by Alejandro_Dominguez; February 14, 2019 at 11:08. |
March 2, 2019, 15:08 |
Andrew O. Winter
Rep Power: 11 |
I would try splitting the third hex you’re trying to create into two separate hexes along the line y = 0. As far as I know, you can’t create a hex that has a face connected to 2 faces of 2 different hexes.
So you would need to add an additional pair of vertices... (844.8 0 0) //12 (844.8 0 30) //13 split the third hex into... hex(0 6 12 9 3 7 13 10) hex(6 2 8 12 7 5 11 13) Of course you would also need to edit the boundaries appropriately too. Note I have not actually run your blockMeshDict to check my edits (I’m using my phone to write to you), but I believe this approach is the correct one to take. Good luck! |
blockmesh, facematching, mergepatchpairs |
[ICEM] Error in mesh writing | helios | ANSYS Meshing & Geometry | 21 | August 19, 2021 15:18 |
Problem with 'Mapped Face Meshing' | RobertW | FLUENT | 0 | November 19, 2016 16:39 |
[snappyHexMesh] Error while running SnappyHex in parallel | mg.mithun | OpenFOAM Meshing & Mesh Conversion | 1 | February 10, 2016 14:13 |
[Commercial meshers] Face ordering problem for nonrectangular cyclic boundary conditions | cfdmarkus | OpenFOAM Meshing & Mesh Conversion | 3 | August 17, 2011 16:07 |
gmsh2ToFoam | sarajags_89 | OpenFOAM | 0 | November 24, 2009 23:50 |
