[snappyHexMesh] Meshing Airfoil sections using SHM |
February 1, 2019, 09:42 |
Raj Kiran
Rep Power: 8 |
Hello Foamers,
I am simulating a VAWT with a NACA0018 profile. I modeled it in ICEM and meshing is done using SHM but always the mesh is very bad. I cleaned the exported stl file in blender for getting a waterproof stl but got some bad mesh results. Also tried few python scripts which i got online in blender for modeling NACA profile but even that didn’t give a good result. I tried Salome where I imported the stl file and fused after exploding then exported even that didn’t work for me. I don’t understand where I am doing wrong . I am out of all options and in great need of the community Regards , Raj Kiran. Last edited by Rakkiran; February 1, 2019 at 11:41. Reason: Spell checks and for clear explanation |
March 8, 2019, 02:55 |
Niels Nielsen
Rep Power: 27 |
Can you please share your files via either dropbox, GDrive Onedrive?
Linnemann PS. I do not do personal support, so please post in the forums. |
March 8, 2019, 03:19 |
Raj Kiran
Rep Power: 8 |
I don't have the polymesh right now. But here are the files which I can upload
https://drive.google.com/open?id=1Jm...-FQbkGaaWKOKSo |
March 12, 2019, 09:23 |
Niels Nielsen
Rep Power: 27 |
Hi
I would use cfmesh or salome. Salome you can mesh one face and then extrude to the height you need. See the screenshots.
March 12, 2019, 10:02 |
Raj Kiran
Rep Power: 8 |
Thank you very much for working out the problem and I don't know how to use cfMesh. I would be very grateful if you could share the workflow in salome so that I could have a guidance for what you have done.
Regards, Raj Kiran. |
March 13, 2019, 01:21 |
Niels Nielsen
Rep Power: 27 |
Here is a good guide to get started with cfmesh.
It is included with the openfoam.com version. Regarding Salome Here is a link to the case both with cfmesh and the .hdf file for Salome. https://drive.google.com/open?id=1Bk...ZPYjvDwUytExix
March 13, 2019, 01:30 |
Raj Kiran
Rep Power: 8 |
Thank you so much for bearing with beginners like me . I will try, and post if I get any problem . Will also post if I get my results.
Best Regards, Raj Kiran. |
[ANSYS Meshing] Meshing 3 Element Airfoil | mr.rushikumar | ANSYS Meshing & Geometry | 0 | March 1, 2014 22:57 |
Problem with restart solution in shape_optimization.py | robyTKD | SU2 Shape Design | 21 | May 29, 2013 09:26 |
[snappyHexMesh] How to Do External Mesh for Airfoil sHM | msuaeronautics | OpenFOAM Meshing & Mesh Conversion | 1 | September 23, 2012 04:00 |
[snappyHexMesh] Multi Region Meshing with sHM | marango | OpenFOAM Meshing & Mesh Conversion | 3 | March 27, 2012 00:51 |
Help regarding basic airfoil meshing in CFX | amoolraina | ANSYS Meshing & Geometry | 2 | May 22, 2010 18:51 |
