[Other] Oriented faceZone for layerAdditonRemoval
Like Tree1Likes
  • 1 Post By Bloerb
Old   December 12, 2018, 19:30
Default Oriented faceZone for layerAdditonRemoval
Sean Gorry
Sean95 is on a distinguished road
Hi all, I am working on a case that looks to model compression in a cylinder as a result of piston motion. At this stage I'm working with basic geometry to develop the piston motion and dynamic mesh.
I plan on using layerAdditionRemoval as a mesh modifier, and I'm just wondering about faceZoneName field. I imported my mesh from ANSYS, and as such I don't have any entires in the faceZone file. I want to use a boundary face for the layer a/r (head_wall in the case folder), but I'm not sure how to go about inverting its normal.
Any help would be great, the case files are attached.
Sean95 is offline   Reply With Quote
Old   December 29, 2018, 16:13
Bloerb will become famous soon enough
https://github.com/bloerb/linearMotionLayersFvMesh
Sean95 likes this.
Bloerb is offline   Reply With Quote
Old   January 4, 2019, 11:21
Sean Gorry
Thanks that's exactly what I'm looking for
I tried to implement the solver by moving files and using wmake,etc., but when I run the case the solver is name is not recognised. I would really appreciate if you could give me a few pointers on implementing it correctly as I also have to do the same on a simulation server.
Thanks again,
Sean
I am using BlueCFD on Windows btw.
Old   January 6, 2019, 16:31
Sean Gorry
Update:
It seems that the issue was caused by the fact that OpenFOAM was being running using blueCFD as it worked perfectly on Ubuntu.
Thanks again
[swak4Foam] swakExpression on faceZone returns empty field for non-empty zone jgross OpenFOAM Post-Processing 1 July 7, 2022 12:28
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
Calculate Mass Flowrate at a faceZone with OpenFOAM4 donQi OpenFOAM Post-Processing 1 August 31, 2016 22:13
Problem with Application based on a faceZone in parallel psilkeit OpenFOAM Programming & Development 2 April 28, 2016 10:47
