[Gmsh] New version of gmshToFoam?
Like Tree17Likes
  • 4 Post By stootoon
  • 7 Post By stootoon
  • 3 Post By openfoamtutorials
  • 3 Post By Talder
Old   November 15, 2018, 12:13
Default New version of gmshToFoam?
Sina Tootoonian
stootoon is on a distinguished road
Hi folks,
I'm running OpenFoam-6 and gmsh 4.0.4 on macOS High Sierra.
My question: Is there a version of gmshToFoam that supports the latest .msh format generated by the latest version of gmsh?
Background:
I've just started learning to mesh with gmsh with the aim of doing some simple simulations in OpenFoam. I followed some simple gmsh tutorials such as https://www.youtube.com/watch?v=C_sCHpLaz3Y and generated some very simple meshes. However whenever I tried to run gmshToFoam, I'd get the following fatal IOError:
--> FOAM FATAL IO ERROR:
wrong token type - expected word, found on line 0 the label 18
I managed to track this down to the format of the .msh file generated by gmsh. The latest version of gmsh (4.0.4) uses a format in which e.g. the size of the $Nodes block is set with two numbers, such as
$Nodes
27 1331
whereas the .msh files generated by older versions of gmsh (such as 2.9.3 used in the youtube tutorial above) specify $Nodes as
$Nodes
1331
This older .msh format seems to be what the latest version of gmshToFoam is expecting, as I was able to run it successfully on the .msh file generated by the old gmsh version.
Is there a version of gmshToFoam that supports the latest .msh formats?
Thanks for your help,
Sina
stootoon is offline   Reply With Quote
Old   November 16, 2018, 08:38
Sina Tootoonian
SOLVED: There doesn't appear to be a version of gmshToFoam that supports the new .msh format, but there is an option in the latest gmsh to export to the old .msh format: File > Export > *.msh > Version 2 ASCII.
Old   November 24, 2018, 21:47
Robert
openfoamtutorials is on a distinguished road
Hi, author of the linked tutorial video here. Thanks for making a post about this! You can also specify the old format (until gmshToFoam is updated) in the command line via "gmsh ... -format msh2". I will be using this in all of my future videos!
openfoamtutorials is offline   Reply With Quote
Old   January 26, 2019, 07:56
Default gmsh to OpenFoam v1812
Tom Alderweireldt
Talder is on a distinguished road
Thanks Stootoon,
I ran in exactly the same 'gmshToFoam' FATAL ERROR issue, with a recently build mesh with gmsh 4.0.7. When I regenerated the mesh with an older gmsh 2.10 version, the problem disappeared.
Many thanks for locating this issue !!
Talder is offline   Reply With Quote
Old   February 13, 2019, 18:25
Default Foam Error bad token, expecting a word
Tom Alderweireldt
In my cases, I found out by just editing the .msh files obtained and adding a line with '$End' just to give it a word it was expecting, made it perfectly happy !!
I could convert any .msh file with this added '$end' line with gmshToFoam into Foam, ParaFoam didn't seem to have any issue.
Hope this helps,
Tom.
Old   April 17, 2019, 14:19
Default error in paraview after calculation
Dokeun, Hwang
dokeun is on a distinguished road
It's awesome !! Thank you for solving my nettlesome problem.
I converted Gmsh ver2 file successfully and ran the icoFoam from cavity.
But I got an error message from paraview when I load the result.
It tells some problem about discordance of face number and I and stuck there.
The error is as below.
ERROR: In /Users/kitware/dashboards/buildbot-slave/8275bd07/build/superbuild/paraview/src/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 6876
vtkOpenFOAMReaderPrivate (0x7f9f900ad050): The end face number 309 of patch top is not consistent with the start face number 280 of patch bottom
ERROR: In /Users/kitware/dashboards/buildbot-slave/8275bd07/build/superbuild/paraview/src/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 782
vtkPVCompositeDataPipeline (0x600001d097a0): Algorithm vtkPOpenFOAMReader(0x7f9f90097060) returned failure for request: vtkInformation (0x600027bdbac0)
Debug: Off
Modified Time: 4803293
Reference Count: 1
Registered Events: (none)
Request: REQUEST_DATA
FROM_OUTPUT_PORT: 0
ALGORITHM_AFTER_FORWARD: 1
FORWARD_DIRECTION: 0
and here is my case set.
Does it have relevance to converting stuff?
It was because boundary file
I changed physicalType as below
back
type empty;
physicalType empty;
nFaces 100;
startFace 180;
bottom
type wall;
physicalType wall;
nFaces 10;
startFace 280;
right
type wall;
physicalType wall;
nFaces 10;
startFace 290;
top
type zeroGradient;
physicalType zeroGradient;
nFaces 10;
startFace 300;
left
type wall;
physicalType wall;
nFaces 10;
startFace 310;
front
type empty;
physicalType empty;
nFaces 100;
startFace 320;
from zipped file.
dokeun is offline   Reply With Quote
Old   May 23, 2019, 12:32
Abbasi Maaz
Abbasi_Maaz is on a distinguished road
Hope this helps,
Tom.
Thank you. It worked for me.
Abbasi_Maaz is offline   Reply With Quote
Old   February 14, 2022, 10:01
Default Update :)
Sourav Mandal
sourav90 is on a distinguished road
I dunno why but this is what's happening with two versions of OpenFOAM in macOS Monterey, arm64 M1Pro:
  • OpenFOAMv-2106
    PHP Code:
    | \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox           |
    |  \\    /   O peration     | Version:  v2106                                 |
    |   \\  /    A nd           | Website:  www.openfoam.com                      |
    |    \\/     M anipulation  |                                                 |
    Build  _c15bfde3cb-20210624 OPENFOAM=2106
    Arch
    "LSB;label=32;scalar=64"
    Exec   gmshToFoam NeighborhoodConnected_MedianRadius5_ROI300_OctreeDepth7Original.msh
    Date
    Feb 14 2022
    Time
    14:57:33
    Host
    coldandwhite.local
    PID
    41390
    I
    /O    uncollated
    Case   : /Users/massisenergy/OpenFOAM/massisenergy-9/run/TestingGmshToFoam
    nProcs
    1
    trapFpe
    Floating point exception trapping not supported on this platform
    fileModificationChecking
    Monitoring run-time modified files using timeStampMaster (fileModificationSkew 5maxFileModificationPolls 20)
    allowSystemOperations Allowing user-supplied system call operations
    Create time
    --> FOAM FATAL IO ERROR: (openfoam-2106)
    Wrong token type expected wordfound on line 0variable "$Entities"
    fileinput at line 0.
        From Foam
    ::Istream &Foam::operator>>(Foam::Istream &, Foam::word &)
    in file primitives/strings/word/wordIO.C at line 70.
    FOAM exiting
  • OpenFOAM-9
    PHP Code:
       \\    /   O peration     | Website:  https://openfoam.org
        \\  /    A nd           | Version:  9
         \\/     M anipulation  |
    Build  9
    Exec
    Date
    Feb 14 2022
    Time
    14:57:44
    Host
    "coldandwhite.local"
    PID    41623
    I
    /O    uncollated
    nProcs
    1
    sigFpe
    Enabling floating point exception trapping (FOAM_SIGFPE).
    fileModificationChecking Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
    Create time
    Skipping tag $end at line 2
    Starting to read points at line 6
    Vertices to be read
    :789686
    Vertices read
    :789686
    Starting to read cells at line 789695
    Cells to be read
    :4697264
    Mapping region 2 to Foam patch 0
    Mapping region 2 to Foam cellZone 0
    Cells
    total:4247972
        hex
    :0
        prism
    :0
        pyr
    :0
        tet
    :4247972
    CellZones
    Zone    Size
        0    4247972
    Skipping tag $End at line 5486962
    Patch 0 gets name patch0
    --> FOAM Warning :
    From function Foam::polyMesh::polyMesh(const Foam::IOobject &, Foam::pointField &&, const Foam::cellShapeList &, const Foam::faceListList &, const Foam::wordList &, const Foam::wordList &, const Foam::word &, const Foam::word &, const Foam::wordList &, const bool)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 595
        Found 449292 undefined faces in mesh
    adding to default patch.
    Finding faces of patch 0
    FaceZones
    Zone    Size
    Writing zone 0 to cellZone cellZone_0
    and cellSet
    End
I could visualise it with paraFoam. So, with version 2 ascii .msh exported from Gmsh, gmshToFoam command is working in OpenFOAM-9 but not with v-2106. Haven't figured out how to specify the boundary conditions yet, but that's the topic of another post!
sourav90 is offline   Reply With Quote
gmsh, gmshtofoam
[OpenFOAM] Multiple version of ParaView Pavel Rodin ParaView 1 October 13, 2017 11:21
How can i uninstall new version of OF shipman OpenFOAM Installation 5 August 12, 2013 05:01
version GLIBCXX_3.4.9 and GLIBCXX_3.4.11 not found ovie Main CFD Forum 1 April 19, 2010 15:00
[OpenFOAM] Problem with paraFoam on a linux-64 bit bunni ParaView 4 April 14, 2010 21:55
Version 12 speed compared to 11 maka OpenFOAM Running, Solving & CFD 2 December 21, 2005 06:42
