[snappyHexMesh] snappyHexMesh cannot achieve smooth surface from stl
Like Tree2Likes
  • 1 Post By fra76
  • 1 Post By alex::cfd
Old   October 21, 2018, 07:33
Default snappyHexMesh cannot achieve smooth surface from stl
Alex
alex::cfd is on a distinguished road
Hi all,
I use the coarse blockmesh and refine at stl surface approach explained in the userguide section 4.4. to place a wing section into a domain.
In principle, meshing works.
However, although the pointed trailing edge gets meshed fine, the round leading edge is awkward.
Here is the leading edge in the CAD program (actually blender):
The result looks like:
I found that increasing refinement levels from 4 to 7 increases quality:
This however is still unsatisfactory.
The geometry of the stl used as input looks well, wehn viewd in paraFoam.
Can I visualize the result of surfaceFeatureExtract somehow to see if the result is Ok?
One difference compared to the trailing edge is that the leading edge is resolved by much more points in the stl. Could this be a problem?
How can I achieve a more round shape at the tip? Any hints?
Thx
Alex
alex::cfd is offline   Reply With Quote
Old   October 22, 2018, 01:19
Francesco Del Citto
fra76 is on a distinguished road
Hi, Alex,
To me, it looks like you have to refine your mesh where the curvature is higher.
Try to give a max refinement level higher than the min one and, if needed, play with the resolveFeatureAngle parameter.
Hope this helps,
Francesco
Yanagi likes this.
fra76 is offline   Reply With Quote
Old   October 22, 2018, 13:39
Alex
yes, I tried that (actually spend the whole day trying to optimize parameters).
The route to success was recognizing that mesh quality control might render settings ineffective.
-> 1st disable all mesh quality contol. then get the parameters correct and then bit by bit turn on the quality control again.
Yanagi likes this.
[Gmsh] Extrude stl surface for building a prismatic layer KateEisenhower OpenFOAM Meshing & Mesh Conversion 12 April 21, 2016 17:54
[snappyHexMesh] Problem with snappyhexMesh: modelling a pore chamber and pore throat model Saideep OpenFOAM Meshing & Mesh Conversion 5 May 10, 2015 15:46
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 08:05
[snappyHexMesh] Snap Precision to a STL Surface malaboss OpenFOAM Meshing & Mesh Conversion 16 July 26, 2013 02:44
Structured or unstructured meshing of a STL file (surface) Milad06 Pointwise & Gridgen 4 April 25, 2013 12:55
