Chris Schäfer
Rep Power: 9 ![]() |
Dear Foamers,
I read threads about toposet and others regarding spliiting patches etc. But I still struggeling with that. My goal is to split each of my Boundary-sides. I have something like a Box with left, right, front, back sides (forget the top and the bottom). I would like to split each of these 4 sides into two (so cutting each by the half) to have more flexible Boundary conditions. Has anyone an idea how to handle this? |
Niels Nielsen
Rep Power: 27 ![]() |
Easiest way to do this is using Paraview.
Follow this guide to select the cells you want in you BC. Remember to turn off "internalMesh" when you load the case. ![]() After this use surfaceToPatch with the stl you just made. ![]()
Linnemann PS. I do not do personal support, so please post in the forums. |
Chris Schäfer
many many thanks Niels.
But I got an fatal error if i execute surfaceToPatch with:"No Mesh available, Probaply mesh is not read." Which sounds strange to me because my mesh is of course there! Do you have any idea where the error comes from? |
Niels Nielsen
Could you please list the exact command you ran and the output of checkMesh.
Also an OF version would be nice to know.
Chris Schäfer
The error comes from the saved surface stl file. In my case it is empty becasue paraview complains that stl files does only support triangles, I have an irregular grid. I tried it with a polygonal file format, but this does not work with the "surfaceToPatch command. The other file formats (e.g vtm)to save the surface extraction which paraview suggested fails as well.
Any idea to overcome this issue? |
Niels Nielsen
Could you share the case?
Chris Schäfer
I have a complicated environment 5terrain case which is very huge. Therefore I tried your method also on the wind around Buildings tutorial, and it fails with the same error message. A bit strange, can you maybe try on that as well?
Niels Nielsen
Are you sure you followed all my steps?
1. Select surface cells to be used for BC 2. Extract selection 3. Extract surface 4. Save Data -> choose stl and ascii output. 5. Try and load the stl and see it is triangulated I did this for a case made with snappyHexMesh and have no problems. EDIT: Just used the windAroundBuildings tutorial and it work fine.
#9 |
Chris Schäfer
Yes, I made an animated gif, the same as your guidance but unfortunately I'am not able to share it with you. I cannot attach it as an gif the attachment management convert it to a jpg.
Sorry. |
#10 |
Niels Nielsen
I use imgur and then use the link to the gif here on the forum using "Insert Image".
#11 |
Chris Schäfer
Hi Niels, many thanks for your Help, and your excellent guidance.
If I apply a Triangulate filter before saving the surface stl file it works. Maybe it is somewhere predefined in your setting otherwise I do not know why you denot need it? Anyway, again many thanks. |
#12 |
Niels Nielsen
Maybe it is the Paraview version?
I'm using 5.5 on windows for the one I made.
#13 |
Chris Schäfer
Dear Nils,
sorry to come back again. After I could split each of my 4 patches successfully, the way forward is not clear to me. I mean now I have 8 new polymesh folders for each new splittet patch in terms of: oldside A splittet in SideA half1 and half2 oldside B splittet in SideB half1 and half2 oldside C splittet in SideC half1 and half2 oldside D splittet in SideD half1 and half2 Now I think I have to merge all of them and deleted the old entries out to have a new (combined)boundary, face, patch, owner, points and neighbour file inside the polymesh. But how, Or do I miss something? |
#14 |
Chris Schäfer
What I did in the meantime, is that I meshed the new splittet stl files with snappyhexmesh. So I think have what I want, but how I get rid of the old patches, how can I delete these. I read some other threads but I did not find the answer yet.
Any idea? |
#15 |
Chris Schäfer
Problem solved. Just using in the beginning the "half" names for each patch.
#16 |
Bernardo Ribeiro
Hi guys,
Is it possible to use the same idea (in paraview) but with the internal mesh? Meaning splitting the mesh with inner and outer cylinders? Thanks! Bernardo |
#17 | |
Niels Nielsen
No that will not be possible as the cells needs to be cut to get actual cylinders. You could make the cylinders in paraview and export them as stl and use in snappy before meshing.
2D Rotating Detonation Engine Periodic Boundaries | whitet86 | FLUENT | 2 | June 25, 2015 11:04 |
Flux difference splitting Vs Fluctuation splitting | Vino | Main CFD Forum | 0 | January 18, 2014 15:54 |
Flux splitting | Dr B.M. Smith (Smith) | OpenFOAM Running, Solving & CFD | 19 | January 9, 2013 04:07 |
Setting Flow/Pressure Boundaries in Floworks | Eran | FloEFD, FloWorks & FloTHERM | 3 | August 11, 2009 04:23 |
periodic boundaries - flow through a net | PK | FLUENT | 0 | July 12, 2007 11:58 |
