[snappyHexMesh] Running snappyHexMesh in parallel creates new time directories
Like Tree1Likes
  • 1 Post By lebc
Old   October 4, 2018, 14:22
Default Running snappyHexMesh in parallel creates new time directories
Hüseyin Can Önel
hconel is on a distinguished road
I want to run snappyHexMesh in parallel and then pimpleFoam in parallel also. I'm using the following script for mesh preparation:
blockMesh > log.blockMesh
decomposePar > log.decomposePar.1
mpirun -np $nProc snappyHexMesh -latestTime -parallel > log.snappyHexMesh
reconstructParMesh -latestTime > log.reconstructPar1
renumberMesh -latestTime > renumberMesh.log
rm -rf processor*
topoSet > log.topoSet
and then the following for solving:
decomposePar > log.decomposePar.2
ls -d processor* | xargs -I {} rm -rf ./{}/0
ls -d processor* | xargs -I {} cp -r 0.org ./{}/0
mpirun -np $nProc pimpleFoam -parallel > log.pimpleFoam
reconstructPar > log.reconstructPar.2
However, snappyHexMesh creates new time directories and I don't want that but to start from 0. How can I do that? Also, is there an "optimized" way to do this by avoiding intermediate decomposition and reconstruction processes?
Thanks.
hconel is offline   Reply With Quote
Old   October 4, 2018, 17:59
Luis Eduardo
lebc is on a distinguished road
Try using "mpirun -np $nProc snappyHexMesh -latestTime -parallel -overwrite> log.snappyHexMesh", I use the "-overwrite" option and I don't get new time directories.
What I use to run my cases is a Allrun file:
#!/bin/sh
cd ${0%/*} || exit 1    # Run from this directory
# Source tutorial run functions
. $WM_PROJECT_DIR/bin/tools/RunFunctions
# Make dummy 0 directory
mkdir 0
runApplication blockMesh
cp system/decomposeParDict.hierarchical system/decomposeParDict
runApplication decomposePar
runParallel snappyHexMesh -overwrite
find . -type f -iname "*level*" -exec rm {} \;
ls -d processor* | xargs -I {} cp -r 0.org ./{}/0 $1
runParallel topoSet
runParallel `getApplication`
runApplication reconstructParMesh -constant
cp -a 0.org/. 0/
I just addapted the Allrun file from one tutorial, so maybe there are other ways to do it.
Kummi likes this.
lebc is offline   Reply With Quote
Old   October 5, 2018, 07:01
Hüseyin Can Önel
Hi Luis,
I do not have runParallel and runApplication commands, I guess they come with another application you have. Also, qsub and pbs scripts does not accept them I guess. Is there a way to do it with mpirun?
Old   October 5, 2018, 17:03
Luis Eduardo
These commands will be available when you execute the line ". $WM_PROJECT_DIR/bin/tools/RunFunctions", but you can probably use the mpi as well (I never used it, so I can't give you more information about it, sorry!)
When I run "runApplication blockMesh" I get the same result as your "blockMesh > log.blockMesh" command, so probably you can keep it.
I guess you could replace "runParallel" by "mpirun -np $nProc". For example, runParallel topoSet may have the same result as mpirun -np $nProc topoSet > log.topoSet
Also, I don't need to reconstruct my case before running the solver, because topoSet can be run in parallel. It seems to be the same case as yours, you just reconstruct it to run topoSet, and after decompose it again, correct?
Best Regards,
Luis
Old   October 5, 2018, 21:40
Hüseyin Can Önel
Thanks to you, sourcing that file allowed me to use runApplication and runParallel commands in pbs script job submissions! My idea was to successfully generate the mesh in parallel first error free, then continue on solving without intermediate reconstruction steps. I'm still not sure how to do it with mpirun commands, but runParallel function has taken care of everything smoothly! I'll post the final script when I get on my pc.
Old   September 27, 2022, 16:20
Default Can you post your script?
Diego Andrade
bravaiser is on a distinguished road
do you mind posting your script?
bravaiser is offline   Reply With Quote
[General] Extracting ParaView Data into Python Arrays Jeffzda ParaView 30 November 6, 2023 22:00
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
pimpleDyMFoam computation randomly stops babapeti OpenFOAM Running, Solving & CFD 5 January 24, 2018 06:28
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
