[Other] Meshing Regions With Different Mesh Numbers |
July 3, 2018, 17:08 |
Ümit Yelken
Rep Power: 8 |
Im working on multiregion. I want to mesh one of the region with more mesh numbers. Im using blockmesh. Do you have an idea?
July 3, 2018, 20:59 |
Olivier Huet
Hi uyelken,
Have a look at this link: http://www.wolfdynamics.com/wiki/mes..._blockmesh.pdf It is a good tutorial to learn how to use blockMesh. I think the part that will be useful for your problem starts at the page 40: Face Merging. This part will teach you how put side by side two blocks even if their mesh is different. I hope it will help you. Cheers, Olivier. |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 08:34 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 07:20 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 10:03 |
How to make sure the mesh numbers are the same for two identical faces? | beastieboys6 | FLUENT | 3 | April 26, 2012 22:13 |
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM | kawamatt2 | ANSYS Meshing & Geometry | 17 | December 20, 2011 12:45 |
