[snappyHexMesh] Unable to create patches while using snappyHexMesh
Like Tree3Likes
  • 1 Post By RobertHB
Old   June 29, 2018, 08:00
Default Unable to create patches while using snappyHexMesh
Ashish Vinayak
ashish.vinayak is on a distinguished road
I am trying to create a mesh where I have placed two cylinders of different diameters on to one another (Fig1).
There will be a simple inlet and outlet patch and the lateral surfaces will be in a wall patch. However, I am unable to select the patches (Fig2)
geometry and refinementSurfaces definitions are as follows:
geometry
testObject
type triSurfaceMesh;
file "testObject.stl";
regions
topSurface_lateral
name topSurface_lateral;
topInlet
name topInlet;
bottomSurface_lateral
name bottomSurface_lateral;
refinementSurfaces
testObject
// Surface-wise min and max refinement level
level (1 2); // was (2 2)
regions
topSurface_lateral
level (1 3);
patchInfo
type wall;
topInlet
level (1 3);
patchInfo
type wall;
level (1 3);
patchInfo
type patch;
I have tried quite a bit of things but I am unable to understand why creating patches is such a difficult task. Can someone help me figure this out?
File Type: jpg Screenshot from 2018-06-29 13-04-14.jpg (72.6 KB, 25 views)
File Type: jpg Screenshot from 2018-06-29 13-04-33.jpg (88.5 KB, 22 views)
Last edited by ashish.vinayak; June 29, 2018 at 08:05. Reason: Changed photos, corrected title
ashish.vinayak is offline   Reply With Quote
Old   June 29, 2018, 08:19
Robert
RobertHB is on a distinguished road
If i understand your post correctly, your stl contains both the smaller cylinder as well as the larger on. And the meshing process doesn't correctly represent the out shape of your domain?
What i did in a similar situation was to use two stl. files. One for each cylinder. That worked for me.
ashish.vinayak likes this.
If you liked my answer to your question, please consider leaving a "Like" in return
RobertHB is offline   Reply With Quote
Old   June 29, 2018, 08:36
Ashish Vinayak
You mean to say that instead of using a single closed stl I should use 2 closed stl files (one for each cylinder) ?
Old   June 29, 2018, 08:50
Robert
Exactly. In my case i connected three single, same diameter, cylinders to form a tube because i needed a single patch in the middle of the domain. Still looks and behaves like on big cylinder though.
Old   June 29, 2018, 10:08
Ashish Vinayak
Brilliant ! Your idea works.
The surfaces are behaving in a better way now. However, if I use two separate cylinders, SHM thinks that I want to cut one cylinder with the second one. The end result is only one cylinder and some kind of weird patchy hole. I'm wondering if I'm facing some kind of numerical error at the interface? Any ideas?
PS. I know it is patchy because my blockMesh is coarse at the moment. But I am certain it is not causing this error.
File Type: jpg Screenshot from 2018-06-29 15-05-00.jpg (70.0 KB, 26 views)
Old   June 29, 2018, 10:14
Ashish Vinayak
Switched on debug mode:
The upper cylinder disappears during the castellation steps. (see images)
File Type: jpg Screenshot from 2018-06-29 15-12-55.jpg (101.4 KB, 26 views)
File Type: jpg Screenshot from 2018-06-29 15-13-02.jpg (90.3 KB, 20 views)
Old   June 29, 2018, 10:47
Robert
Strange. Since both cylinders show up in the first step of sHM (right?) your setup should be correct until then.
What is the value of the tolerance <value>; setting? Maybe the points from the lower cylinder do not connect to the upper one?
I'm not at work anymore, but i could send you my sHM dict on Monday if you don't figure out your problem until then.
Old   June 30, 2018, 10:40
Ashish Vinayak
I don't think the points connecting together is a problem. While making the stl I take care to see that the top face of the lower cylinder and bottom face of upper cylinder match.
I was working with a tolerance of 1.0. I now set it to 3.0 and set debug to 1.
I was inspecting the time directories. During the initial stages I see that the patches from the upper cylinder are recognised (nFaces >> 0) However, after time = 0.07 it just sets nFaces = 0 on all the upper cylinder patches. Could you please help me solve this?
Thanks for your help Schönes Wochenende.
Last edited by ashish.vinayak; June 30, 2018 at 10:42. Reason: added more information
Old   July 2, 2018, 03:58
Robert
Hey,
i think i promised to much. My case that i had in mind does not consist of two stl files and my snappyHexMeshDict doesn't work for connecting two stl's - just tested it.
Old   July 2, 2018, 04:07
Ashish Vinayak
Another weird thing I've noticed today. Looking at the Clip in Paraview one sees that SHM recognizes the bottom cylinder as a solid shape but the top cylinder as a hollow shape with no internal mesh. Really weird.
@Robert That sucks for me. :/ But thanks anyway!
File Type: jpg Screenshot from 2018-07-02 09-05-34.jpg (98.1 KB, 18 views)
cylinder, patches, shm, snappyhexmesh
[snappyHexMesh] On which patches to set BC's for snappyHexMesh ? Talder OpenFOAM Meshing & Mesh Conversion 0 November 8, 2015 19:25
Cyclic boundaries in OF 21x morard OpenFOAM 25 May 13, 2013 23:35
[blockMesh] Include list of points Hikachu OpenFOAM Meshing & Mesh Conversion 0 June 20, 2011 10:03
[snappyHexMesh] snappyHexMesh with cyclic patches? Axel_T OpenFOAM Meshing & Mesh Conversion 1 October 12, 2010 11:03
[snappyHexMesh] SnappyHexMesh large number of patches written prapanj OpenFOAM Meshing & Mesh Conversion 0 July 15, 2009 09:11
