[blockMesh] Creating an internal mesh within blockMesh?
Like Tree1Likes
  • 1 Post By sk11
Old   June 18, 2018, 04:14
Default Creating an internal mesh within blockMesh?
Ashish Vinayak
ashish.vinayak is on a distinguished road
I would like to create an internal mesh (cylinder) within a blockMesh (cube).
The idea would be to import a cylinder into the cube geometry. The end result would merge both the geometries together. However, I require that the cylinder maintains its surface patch after the merging.
How should I go about doing this?
ashish.vinayak is offline   Reply With Quote
Old   June 18, 2018, 10:32
anonymous
simrego is on a distinguished road
Hi!
Try to use snappyHexMesh. I think that's the easiest way.
simrego is offline   Reply With Quote
Old   June 18, 2018, 18:03
Ashish Vinayak
Any tips on how I would go about doing this?
Old   June 22, 2018, 04:21
Sarath
sk11 is on a distinguished road
Under refinement surfaces in snappyHexMesh, there is option to provide faceType as internal
refinementSurfaces
shape_name
level (2 2);
faceType internal;
faceZone shape_name;
cellzone shape_name;
cellZoneInside inside;
Here shape_name is specified in the geometry section. For more information, read the snappyHexMesh dict file from the directory etc/caseDicts/annotated
Sarath
ashish.vinayak likes this.
sk11 is offline   Reply With Quote
Old   June 22, 2018, 04:42
Ashish Vinayak
Thanks sk11 ! Turns out in 2 days I figured out the same thing as well and learnt how to use SHM as well Patience is key
I'm using the baffle option though instead of internal it seems to do the job for my small test cases.
Sarath
baffles, blockmesh, internal mesh
[snappyHexMesh] Creating very fine, high accuracy mesh with snappyHexMesh JD_Welch OpenFOAM Meshing & Mesh Conversion 10 July 5, 2023 12:50
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[blockMesh] error with blockMesh: "internal face or already belongs to some other patch" sajad6 OpenFOAM Meshing & Mesh Conversion 0 October 23, 2014 09:26
blockMesh: block with 6 vertexes dani OpenFOAM 3 June 25, 2009 14:13
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 10:38
