[mesh manipulation] extrudeMesh skewness error
Like Tree1Likes
  • 1 Post By yasasvi.harishkumar
Old   May 31, 2018, 07:18
Question extrudeMesh skewness error
Yasasvi Harish Kumar
yasasvi.harishkumar is on a distinguished road
This is my blockMeshDict:
| \\ / O peration | Version: 5 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 0.001;
vertices
(20 0 0)
(65 0 0)
(65 0.0065 0)
(20 0.0020 0)
(20 0 40)
(65 0 40)
(65 0.0065 40)
(20 0.0020 40)
edges
line 0 1
line 3 2
line 7 6
line 4 5
line 0 3 //(19.9992384613 0.17453071 0)
line 1 2 //(64.9975249992 0.5672248074 0)
line 5 6 //(64.9975249992 0.5672248074 40)
line 4 7 //(19.9992384613 0.17453071 40)
line 0 4
line 1 5
line 2 6
line 3 7
blocks
hex (1 0 4 5 2 3 7 6)
(18 1 18)
simpleGrading
(1 1 1)
boundary
inlet
type patch;
faces ((1 2 6 5));
outlet
type patch;
faces ((7 4 0 3));
bottom
type patch;
faces ((0 1 5 4));
top
type patch; //(or wall)
faces ((3 2 6 7));
wall
type wall;
faces (
(4 7 6 5)
(0 3 2 1)
I'm trying to extrude this mesh to make a cylinder with a hole in the middle. This is my extrudeMeshDict file:
| \\ / O peration | Version: 2.2.2 |
FoamFile
version 2.0;
format ascii;
class dictionary;
object extrudeMeshDict;
constructFrom patch;
sourceCase ".";
sourcePatches (top);
exposedPatchName bottom;
flipNormals false;
extrudeModel sector;
nLayers 10;
expansionRatio 1.0; //0.9;
sectorCoeffs
axisPt (0 0 20);
axis (0 0 65);
angle 360;
mergeFaces true; //false;
mergeTol 0;
But when I run extrudeMesh and then run checkMesh, it gives me the following error:
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
internal points: 0
faces: 730
internal faces: 350
cells: 180
faces per cell: 6
boundary patches: 5
point zones: 0
face zones: 1
cell zones: 0
Overall number of cells of each type:
hexahedra: 180
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
inlet 10 20 ok (non-closed singly connected)
outlet 10 20 ok (non-closed singly connected)
bottom 0 0 ok (empty)
top 0 0 ok (empty)
wall 360 380 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-0.065 -4.0182158 -168960) (0.065 4.0182158 0.04)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (4.2747924e-17 1.5629954e-19 5.0680011e-24) OK.
***High aspect ratio cells found, Max aspect ratio: 3984422.4, number of cells 180
<<Writing 180 cells with high aspect ratio to set highAspectRatioCells
Minimum face area = 0.0001. Maximum face area = 8069.1202. Face area magnitudes OK.
Min volume = 0.032828302. Max volume = 1.9596511. Total volume = 123.48904. Cell volumes OK.
Mesh non-orthogonality Max: 89.999984 average: 77.614853
*Number of severely non-orthogonal (> 70 degrees) faces: 280.
Non-orthogonality check OK.
<<Writing 280 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
***Max skewness = 49592.18, 36 highly skew faces detected which may impair the quality of the results
<<Writing 36 skew faces to set skewFaces
Coupled point location match (average 0) OK.
Failed 2 mesh checks.
Time = 0.0001
Mesh stats
internal points: 0
faces: 748
internal faces: 332
cells: 180
faces per cell: 6
boundary patches: 5
point zones: 0
face zones: 0
cell zones: 0
hexahedra: 180
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Point usage OK.
Face vertices OK.
inlet 10 22 ok (non-closed singly connected)
outlet 10 22 ok (non-closed singly connected)
top 36 76 ok (non-closed singly connected)
wall 360 418 ok (non-closed singly connected)
Boundary openness (4.1067703e-17 -1.1295084e-18 -2.6830594e-23) OK.
***High aspect ratio cells found, Max aspect ratio: 4150387, number of cells 180
Minimum face area = 3.202096e-05. Maximum face area = 10893.312. Face area magnitudes OK.
Min volume = 0.010091589. Max volume = 2.2678961. Total volume = 123.48904. Cell volumes OK.
Mesh non-orthogonality Max: 89.999985 average: 80.104291
Face pyramids OK.
***Max skewness = 51694.863, 54 highly skew faces detected which may impair the quality of the results
<<Writing 54 skew faces to set skewFaces
End
Can someone please explain the problem here and give me solution to reduce the skewness and aspect ratio. Thank you.
Peppeeeee likes this.
yasasvi.harishkumar is offline   Reply With Quote
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 07:35
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
