[blockMesh] Error: Block Hex has inward-pointing faces |
May 7, 2018, 09:07 |
Rep Power: 9 |
I'm trying to convert a rectangular mesh to a curved one by using the "arc" selection. The blockmesh of the curved mesh is: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (-2 -0.75 -0.8)//0 (1 -0.75 -0.8)//1 (1 1 -0.8)//2 (-2 1 -0.8)//3 // (-4.1 -0.75 -0.8)//4 (3.1 -0.75 -0.8)//5 (3.1 1 -0.8)//6 (-4.1 1 -0.8)//7 ); blocks ( hex (0 1 2 3 4 5 6 7) (30 10 20) simpleGrading (1 1 1) ); edges ( arc 2 3 (-0.5 1 0.25) arc 1 0 (-0.5 -0.75 0.25) arc 5 4 (-0.5 -0.75 2.35) arc 6 7 (-0.5 1 2.35) ); boundary ( inlet { type patch; faces ( (2 6 5 1) ); } outlet { type patch; faces ( (3 0 4 7) ); } road { type wall; faces ( (0 1 5 4) ); } top { type wall; faces ( (2 3 7 6) ); } sides { type wall; faces ( (0 1 2 3) (4 5 6 7) ); } ); // ************************************************************************* // Code:
/*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 5.0-dbb428a3a855 Exec : blockMesh Date : May 07 2018 Time : 14:47:12 PID : 4352 I/O : uncollated Case : /home/user/Desktop/curvedmesh nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Deleting polyMesh directory "/home/user/Desktop/curvedmesh/constant/polyMesh" Creating block mesh from "/home/user/Desktop/curvedmesh/system/blockMeshDict" Creating block edges No non-planar block faces defined Creating topology blocks --> FOAM FATAL IO ERROR: Block hex (0 1 2 3 4 5 6 7) (30 10 20) simpleGrading (1(1) 1(1) 1(1)) has inward-pointing faces 4(0 4 7 3) 4(1 2 6 5) 4(0 3 2 1) file: /home/user/Desktop/curvedmesh/system/blockMeshDict.blocks at line 37. From function void Foam::blockDescriptor::check(const Foam::Istream&) in file blockDescriptor/blockDescriptor.C at line 89. FOAM exiting Any tip on how to make the 4, 5 & 6, 7 points collinear would be great. - Openfoam v. 5.0 - OS: Ubuntu 17.04 |
May 28, 2018, 15:46 |
anonymous
Rep Power: 14 |
Hi!
Maybe blockMesh can't do it. I hope someone can explain that, but I think blockMesh create the blocks first and then it'll take into account your edges. And since this block has 0 thickness, when it try to create this block, of course it will crash. But if you use -0.79999999999999 then it's okay, and -0.79999999999999 = -0.8 so it should be fine. Or you can use 2 blocks and it will be ok. |
[snappyHexMesh] Layers not growing at all | zonda | OpenFOAM Meshing & Mesh Conversion | 12 | June 6, 2020 12:28 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
[snappyHexMesh] SHM is not extruding/adding Layers everywhere | matthiasd | OpenFOAM Meshing & Mesh Conversion | 2 | October 16, 2016 17:45 |
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library | aylalisa | OpenFOAM Installation | 23 | June 15, 2015 15:49 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 14:38 |
