[Other] Multiple blocks for moving mesh
Like Tree1Likes
  • 1 Post By jiahui_93
Old   March 4, 2018, 03:24
Default Multiple blocks for moving mesh
jiahui_93 is on a distinguished road
Hi, I am doing a simulation of moving solid body obstacle within a rectangular fluid domain. I had referred movingCone, movingConeTopoChanger and stirring water case. I found out that all of them are using multiple blocks to create a hollow solid obstacle, instead of deleting the mesh cells by using subset mesh. Is there any reason of using this method?
I had tried subset mesh method but result shows extreme value field data. So, i was wondering is it subset mesh method not working, thus no one using this method.
Extreme value of field data
Another problem is The result doesn't show U, P and turbulence contour as expected (supposed to have high U between domain wall and obstacle wall as in the pic below). elev.jpg
Is it because i use a larger distance between solid obstacle (car) and domain (shaft) wall, so the high U tends not to be focus there? Anyway, the value and contour is really out of my expected. But at least i can see some contour on top, side and bottom of car wall
I want to try multiple block method, but facing error to create block with an internal face. As mentioned in this post below. Can i get some idea on this?
https://www.cfd-online.com/Forums/op...tml#post682691
I would be grateful for any comment and suggestion. Thanks
christoph45 likes this.
jiahui_93 is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
[Commercial meshers] COnvert FLuent MEsh to openfoam with interface manuc OpenFOAM Meshing & Mesh Conversion 1 July 25, 2017 04:13
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
