Hannes
Rep Power: 0 ![]() |
Hey foamers,
i having not so much experience in OpfenFoam, so i hope you could help me. i use Openfoam v5 and will simulate a periodic swinging mesh with dynamicInkJetFvMesh. But when i start a simulation, the mesh doesn't move. My question is did i need an extra file like toposet oder createbaffles or should be adjested my boundarie conditions false? Thanks in advance! best regards hannes15 |
Fynn
Rep Power: 10 ![]() |
Hi Hannes,
You only have to define the dynamicMeshDict in the constant folder. dynamicInkJetFvMesh is not using a solver to calculate the displacement but rather an explicit function. Therefore, you don't have to define a pointDisplacement or pointMotionUx boundary file. Take a look at the attached minimal working example (OF 4.x). cheers Fynn |
Hannes
Hi Fynn,
Thank's for the quick answer. Now, it's function and i know how to continue for my ba-thesis. For something like this file i searching in quite a spell. best regards Hannes |
dynamic grid, dynamicinkjetfvmesh, dynamicmeshdict |
Difference between Moving Wall and Moving Boundary | Finbar | FLUENT | 1 | January 12, 2018 09:06 |
HELP - Moving car simulation in fluent | Brad Wells | FLUENT | 7 | January 4, 2018 19:55 |
[snappyHexMesh] jagged, ragged edges... | ziemowitzima | OpenFOAM Meshing & Mesh Conversion | 138 | July 23, 2012 23:41 |
[Other] How to set up a dynamic mesh for a piston moving through a tube of variable diameter? | karkar | OpenFOAM Meshing & Mesh Conversion | 0 | July 4, 2012 06:54 |
Moving mesh in Fluent | fivos | FLUENT | 0 | April 2, 2010 09:45 |
