January 5, 2018, 02:56 |
Multiple Grid Algorithms
krishna kant
Rep Power: 10 |
I want to make a solver in openfoam in which some variables are defined in one grid and others are in different grid. Also the variables will be coupled to each other. Is it possible to make such solver in openFoam. And I need some suggestion to begin in this direction.
January 5, 2018, 04:29 |
Anton Kidess
Rep Power: 30 |
Have a look at how chtMultiRegionFoam handles multiple meshes and try to build up your solution from there.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
January 5, 2018, 05:27 |
krishna kant
Rep Power: 10 |
Thanks for your help
January 5, 2018, 10:25 |
Peter Hess
Rep Power: 17 |
Hello!
Hier is a good place where you could start: http://openfoamwiki.net/index.php/Ho...ure_to_icoFoam In: incompressible/pimpleDyMFoam/wingMotion You will find how to mapFields example. Using mapFields you are able to export Data/Fields from one Mesh to other! The Meshes must not be identical! Regards Peter |
January 8, 2018, 09:25 |
krishna kant
Rep Power: 10 |
Sir
First of all thanks for your suggestions. I find that chtMultiRegionFoam is one solver in which we use two different grids one for solid region and one for fluid region. They also create different fields for each regions. My problem is I am unable to get how they are differentiating in regions. They are creating only one block and then using toposet to define different region. But I still don't get how they identify which one is solid and which one is fluid. Also I can't use toposet to differentiate the regions in my problem because the region are same in both grids in my case. Only thing is one grid will be coarse and other will be fine. |
January 8, 2018, 09:43 |
#6 | |
Anton Kidess
Rep Power: 30 |
It's user specified via regionProperties. Yes you can, because topoSet doesn't care where your grids are located or if they overlap. Anyway, it sounds like you were expecting you could use chtMultiRegionFoam without any changes, which of course is not true. It just shows you some useful machinery to write a solver that deals with multiple meshes. In chtMultiRegionFoam those meshes are coupled at the boundaries, in your case you'll need to add a mechanism to interpolate the values from one mesh to another.
January 8, 2018, 10:00 |
Peter Hess
Rep Power: 17 |
Hello kk415!
You need to define which regions are solid and which are flluid in constant/regionsPeoperties as akidess mentioned! Hier is a working example of chtMultiRegionSimpleFoam. The regions are drawen in freecad and exported as stl, then defined by kind in regionsPeoperties. I hope it helps to understand the steps. Regards Peter Last edited by peterhess; January 8, 2018 at 12:31. |
May 8, 2018, 06:43 |
krishna kant
Rep Power: 10 |
Hi Peter and Anton,
I make a model for solving different PDE in different grids using mapField utility of OpenFoam. This work as following: #!/bin/sh cd testFoam_cavity; //case folder of coarse mesh blockMesh; for ((i=0;i < 100;i=i+1)) { cd ../testFoam_cavityfine_scalar //case folder of fine mesh mapFields ../testFoam_cavity -consistent cd ../testFoam_cavity testFoam //solver same as icoFoam i.e. solving NS equation and energy equation is commented cd ../testFoam_cavityfine_scalar testFoamScalar //solver for energy equation and NS equation is commented cd ../testFoam_cavity mapFields ../testFoam_cavityfine_scalar -consistent } It works fine in terms of result but the way is inefficient as It requires reading mesh too many times in one timeStep. Any suggestions to improve it. Thanks |
May 25, 2018, 06:47 |
#9 |
krishna kant
Rep Power: 10 |
Hi
I am trying to solve a cavity problem in which NS equations are solved in coarser grid and Energy equation is solved in finer grid. I am trying to interpolate fields in between the meshes similar to mapFields.c My testFoam.c file is as following /*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | \\ / A nd | Copyright (C) 2011-2016 OpenFOAM Foundation \\/ M anipulation | ------------------------------------------------------------------------------- License This file is part of OpenFOAM. OpenFOAM is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. OpenFOAM is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with OpenFOAM. If not, see <http://www.gnu.org/licenses/>. Application icoFoam Description Transient solver for incompressible, laminar flow of Newtonian fluids. \*---------------------------------------------------------------------------*/ #include "fvCFD.H" #include "regionProperties.H" #include "pisoControl.H" #include "meshToMesh0.H" #include "MapMeshes.H" // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // int main(int argc, char *argv[]) { #define NO_CONTROL #define CREATE_MESH createMeshesPostProcess.H #include "postProcess.H" #include "setRootCase.H" #include "createTime.H" #include "createMeshes.H" #include "createFields.H" #include "initContinuityErrs.H" #include "createTimeControls.H" #include "readSolidTimeControls.H" #include "setInitialMultiRegionDeltaT.H" meshToMesh0:rder mapOrder = meshToMesh0::INTERPOLATE; // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Info<< "\nStarting time loop\n" << endl; while (runTime.loop()) { #include "readTimeControls.H" #include "readSolidTimeControls.H" #include "setMultiRegionDeltaT.H" Info<< "Time = " << runTime.timeName() << nl << endl; //#include "CourantNo.H" //? forAll(fluidRegions, i) { Info<< "\nSolving for fluid region " << fluidRegions[i].name() << endl; pisoControl piso(fluidRegions[i]); #include "setRegionFluidFields.H" // Momentum predictor fvVectorMatrix UEqn ( fvm::ddt(U) + fvm::div(phi, U) - fvm::laplacian(nu, U) ); if (piso.momentumPredictor()) { solve(UEqn == -fvc::grad(p)); } // --- PISO loop while (piso.correct()) { volScalarField rAU(1.0/UEqn.A()); volVectorField HbyA(constrainHbyA(rAU*UEqn.H(), U, p)); surfaceScalarField phiHbyA ( "phiHbyA", fvc::flux(HbyA) + fvc::interpolate(rAU)*fvc::ddtCorr(U, phi) ); adjustPhi(phiHbyA, U, p); // Update the pressure BCs to ensure flux consistency constrainPressure(p, U, phiHbyA, rAU); // Non-orthogonal pressure corrector loop while (piso.correctNonOrthogonal()) { // Pressure corrector fvScalarMatrix pEqn ( fvm::laplacian(rAU, p) == fvc::div(phiHbyA) ); pEqn.setReference(pRefCell, pRefValue); pEqn.solve(fluidRegions[i].solver(p.select(piso.finalInnerIter()))); if (piso.finalNonOrthogonalIter()) { phi = phiHbyA - pEqn.flux(); } } // #include "continuityErrs.H" U = HbyA - rAU*fvc::grad(p); U.correctBoundaryConditions(); } } //all fluid regions //subtract= false; //Interpolation from coarser to finer mesh MapConsistentMesh<eqOp>(fluidRegions[0], solidRegions[0], mapOrder); forAll(solidRegions, i) { Info<< "\nSolving for solid region " << solidRegions[i].name() << endl; #include "setRegionSolidFields.H" //add these lines... fvScalarMatrix TEqn ( fvm::ddt(T) + fvm::div(phi, T) - fvm::laplacian(DT, T) ); TEqn.solve(); //done adding lines... } //all solid regions //Interpolation from finer to coarser mesh MapConsistentMesh<eqOp>(solidRegions[0], fluidRegions[0], mapOrder); runTime.write(); Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s" << " ClockTime = " << runTime.elapsedClockTime() << " s" << nl << endl; } Info<< "End\n" << endl; return 0; } // ************************************************** *********************** // I am getting this error [Rajesh@DRDO-Raja testFoam]$ wmake /home/Rajesh/OpenFOAM/OpenFOAM-4.1/applications/solvers/heatTransfer/testFoam g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I. -I./fluid -I./solid -I./include -I/home/Rajesh/OpenFOAM/OpenFOAM-4.1/src/meshTools/lnInclude -I/home/Rajesh/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude -I/home/Rajesh/OpenFOAM/OpenFOAM-4.1/src/regionModels/regionModel/lnInclude -I/home/Rajesh/OpenFOAM/OpenFOAM-4.1/src/sampling/lnInclude -I/home/Rajesh/OpenFOAM/OpenFOAM-4.1/src/lagrangian/basic/lnInclude -IlnInclude -I. -I/home/Rajesh/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude -I/home/Rajesh/OpenFOAM/OpenFOAM-4.1/src/OSspecific/POSIX/lnInclude -fPIC -c testFoam.C -o /home/Rajesh/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt64Opt/applications/solvers/heatTransfer/testFoam/testFoam.o In file included from testFoam.C:73:0: ./fluid/setRegionFluidFields.H: In function ‘int main(int, char**)’: ./fluid/setRegionFluidFields.H:3:21: warning: unused variable ‘T’ [-Wunused-variable] volScalarField& T = TFluid[i]; ^ In file included from testFoam.C:142:0: ./solid/setRegionSolidFields.H:5:21: warning: unused variable ‘U’ [-Wunused-variable] volVectorField& U = USolid[i]; ^ In file included from testFoam.C:50:0: /home/Rajesh/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude/createTimeControls.H:35:8: warning: variable ‘maxCo’ set but not used [-Wunused-but-set-variable] scalar maxCo = ^ /home/Rajesh/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude/createTimeControls.H:38:8: warning: variable ‘maxDeltaT’ set but not used [-Wunused-but-set-variable] scalar maxDeltaT = ^ g++ -std=c++0x -m64 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=64 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -I. -I./fluid -I./solid -I./include -I/home/Rajesh/OpenFOAM/OpenFOAM-4.1/src/meshTools/lnInclude -I/home/Rajesh/OpenFOAM/OpenFOAM-4.1/src/finiteVolume/lnInclude -I/home/Rajesh/OpenFOAM/OpenFOAM-4.1/src/regionModels/regionModel/lnInclude -I/home/Rajesh/OpenFOAM/OpenFOAM-4.1/src/sampling/lnInclude -I/home/Rajesh/OpenFOAM/OpenFOAM-4.1/src/lagrangian/basic/lnInclude -IlnInclude -I. -I/home/Rajesh/OpenFOAM/OpenFOAM-4.1/src/OpenFOAM/lnInclude -I/home/Rajesh/OpenFOAM/OpenFOAM-4.1/src/OSspecific/POSIX/lnInclude -fPIC -Xlinker --add-needed -Xlinker --no-as-needed /home/Rajesh/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt64Opt/applications/solvers/heatTransfer/testFoam/testFoam.o -L/home/Rajesh/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt64Opt/lib \ -lmeshTools -lfiniteVolume -lregionModels -lsampling -llagrangian -lgenericPatchFields -lOpenFOAM -ldl \ -lm -o /home/Rajesh/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt64Opt/bin/testFoam /home/Rajesh/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt64Opt/applications/solvers/heatTransfer/testFoam/testFoam.o: In function `void Foam::MapConsistentMesh<Foam::eqOp>(Foam::fvMesh const&, Foam::fvMesh const&, Foam::meshToMesh0:rder const&)': testFoam.C.text._ZN4Foam17MapConsistentMeshINS_4 eqOpEEEvRKNS_6fvMeshES4_RKNS_11meshToMesh05orderE[_ZN4Foam17MapConsistentMeshINS_4eqOpEEEvRKNS_6fvMe shES4_RKNS_11meshToMesh05orderE]+0x2b3): undefined reference to `Foam::mapLagrangian(Foam::meshToMesh0 const&)' collect2: error: ld returned 1 exit status make: *** [/home/Rajesh/OpenFOAM/OpenFOAM-4.1/platforms/linux64GccDPInt64Opt/bin/testFoam] Error 1 The Option file is as following: # 1 "Make/options" # 1 "<built-in>" # 1 "<command-line>" # 1 "Make/options" EXE_INC = -I. -I./fluid -I./solid -I./include -I$(LIB_SRC)/meshTools/lnInclude -I$(LIB_SRC)/finiteVolume/lnInclude -I$(LIB_SRC)/regionModels/regionModel/lnInclude -I$(LIB_SRC)/sampling/lnInclude -I$(LIB_SRC)/lagrangian/basic/lnInclude EXE_LIBS = -lmeshTools -lfiniteVolume -lregionModels -lsampling -llagrangian -lgenericPatchFields Any suggestion how to tackle the problem further. In case I am not clear in something then let me know. Thanks |
May 25, 2018, 11:16 |
#10 |
krishna kant
Rep Power: 10 |
It seems the problem is I can't get IO object list correctly. So I am attaching the create fluid and solid field file and the mapping file in which IO object list is required.
MapMeshes.H createFluidFields.H createSolidFields.H |
Grid Check Script | pdp.aero | SU2 | 2 | April 23, 2015 02:54 |
MapFields to New Grid For Extreme Grid Deformations due to Body Motion | albcem | OpenFOAM | 0 | May 5, 2009 15:17 |
Grid Adaptation | Suresh | FLUENT | 0 | October 15, 2003 14:18 |
GRID TO GRID INTERPOLATION in FLUENT | calogero | FLUENT | 3 | June 4, 2003 09:32 |
Numerical methods for discontinuous grid interfaces? | Hansong Hang | Main CFD Forum | 12 | September 16, 1998 23:26 |
