[Other] conformed FSI mesh for unstructured fluid region
Like Tree1Likes
  • 1 Post By ashish.svm
Old   December 20, 2017, 20:55
Default conformed FSI mesh for unstructured fluid region
Ashish Kumar
ashish.svm is on a distinguished road
FSI (fluid structure interaction) problem. Need to generate a mesh around the given fluid mesh. Fluid region mesh will be 2D, solid region 3D
An example of fluid region mesh is shown below
top view (XY)
3D view
Fluid region mesh is generated from the output of another code and this mesh is in OpenFOAM format. To use this mesh in another meshing software, this can be converted to STL format, but that generates triangle and this mesh information is lost.
Until now I have explored snappyHexMesh option from OpenFOAM but in that case, I will have hard time generating a conforming mesh for fluid and solid regions.
Then I explored SALOME mesh generation software. I converted my fluid mesh to STL format and imported that in SALOME. In this I can generate a mesh but the generated mesh is very fine (as shown below) with a large number of tetrahedral elements.
Please suggest me methods to create mesh for this type of problem. Main criteria for the mesh are following:
1) If I can generate mainly hexahedral elements because tetrahedral results in larger number of cells and that will increase the runtime.
2) Finer mesh near the given fluid region and coarse mesh as we move away from the fluid surface.
ashish.svm is offline   Reply With Quote
Old   December 29, 2017, 13:05
Peter Hess
peterhess is on a distinguished road
Hello!
Well I am not sure if understand the problem you are facing right way...
Anyway, I belive that openFoam dont recognize 2D Mesh, if that the problem you have here.
I suggest trying a 3D Mesh for Fluid. At least one cell in the third direction.
Regards
Peter
peterhess is offline   Reply With Quote
Old   January 5, 2018, 03:48
Sam
anufagbemi is on a distinguished road
I'm having similar problems. i tried creating a mesh around my fluid domain in salome. But I'm having troubles merging both of them together and as a result can't obtain the solid mesh.
Both meshes are unstructured 3D meshes. Please if you were successful in yours let me know.
anufagbemi is offline   Reply With Quote
Old   January 5, 2018, 10:22
Peter Hess
Hello!
Post your case please!
Regards
Peter
Old   January 5, 2018, 13:43
Default You can merge the geometry using "Partition"
Ashish Kumar
Yes.
I used SALOME and then With the "Partition" option, I merged the two domains and then meshed the partitioned geometry.
anufagbemi likes this.
Old   January 5, 2018, 14:18
Sam
It's too big to upload. You can send me your email or something so i could send you the trisurface files. (I also separated the solid from the general case folder).
Fluid domain and solid domains are just inversions of the other done with Avizo. I tried to use the snappyHexMesh to mesh them separately then run them. However anytime I try to run it, It tells me this;
--> FOAM FATAL ERROR:
Master point addressing is not correct
    From function ExtendedGGIInterpolation::masterToSlavePointInterpolate(const Field<Type> pf)
    in file /home/anu/foam/foam-extend-4.0/src/foam/lnInclude/GGIInterpolation.C at line 492.
FOAM aborting
Aborted (core dumped)
I'm guessing the reason for this is that the meshes are not continuous at some points at the interface.
Now I'm attempting to use salome.
N.B the Allrun file has not yet been edited, i.e. you'll need to run the commands manually. Thanks for your help.
Samuel
Old   January 5, 2018, 14:36
Sam
@ashish.svm It seems the partition is only available in "geometry" mode. My fluid domain is a mesh and is very difficult to read it as a geometry because it has ridiculous amount of faces.
Old   January 5, 2018, 16:49
Sam
Originally Posted by ashish.svm View Post
Yes.
Do you mind if you share your case file. I want to see how you obtained your interface for both phases.
Old   January 11, 2018, 15:42
Ashish Kumar
Sorry for late reply. I have attached my case to the following link
https://www.dropbox.com/s/rd6phx4cw5...lex60.hdf?dl=0
Old   January 11, 2018, 15:45
Ashish Kumar
I had the same problem. My fluid domain was also a mesh. But mine was very simple and it consisted of only plane surfaces so I wrote a python code (for SALOME) to create geometry. Code to create geometry is following:
# -*- coding: utf-8 -*-
### This file is generated automatically by SALOME v8.3.0 with dump python functionality
import sys
import salome
salome.salome_init()
theStudy = salome.myStudy
import salome_notebook
notebook = salome_notebook.NoteBook(theStudy)
sys.path.insert( 0, r'E:/SALOME-8.3.0-WIN64/WORK/DDMGeom')
### GEOM component
import GEOM
from salome.geom import geomBuilder
import math
import SALOMEDS
geompy = geomBuilder.New(theStudy)
Vertex_c0001 = geompy.MakeVertex(0, 15, 0)
Vertex_c0002 = geompy.MakeVertex(0.5, 15, 0)
Vertex_c0003 = geompy.MakeVertex(-0.5, 15, 0)
Vertex_c0004 = geompy.MakeVertex(1, 15, 0)
Vertex_c0005 = geompy.MakeVertex(-1, 15, 0)
Vertex_c0006 = geompy.MakeVertex(1.192, 15.2432, 0)
Vertex_c0007 = geompy.MakeVertex(1.308, 14.7568, 0)
Vertex_c0008 = geompy.MakeVertex(-1.5, 15.0002, 0)
Vertex_c0009 = geompy.MakeVertex(1.0759, 15.7295, 0)
Vertex_c0010 = geompy.MakeVertex(1.4656, 14.2844, 0)
Vertex_c0011 = geompy.MakeVertex(-1.7481, 15.2504, 0)
Vertex_c0012 = geompy.MakeVertex(-1.7519, 14.7504, 0)
Vertex_c0013 = geompy.MakeVertex(1.4241, 13.8487, 0)
Vertex_c0014 = geompy.MakeVertex(0.95991, 16.2159, 0)
Vertex_c0015 = geompy.MakeVertex(-1.7442, 15.7503, 0)
Vertex_c0016 = geompy.MakeVertex(1.011, 16.684, 0)
Vertex_c0017 = geompy.MakeVertex(-1.7403, 16.2503, 0)
Vertex_c0018 = geompy.MakeVertex(1.2293, 17.1338, 0)
Vertex_c0019 = geompy.MakeVertex(-1.7364, 16.7503, 0)
Vertex_c0020 = geompy.MakeVertex(1.4476, 17.5836, 0)
Vertex_c0021 = geompy.MakeVertex(-1.5361, 17.1526, 0)
Vertex_c0022 = geompy.MakeVertex(1.6659, 18.0335, 0)
Vertex_c0023 = geompy.MakeVertex(1.9597, 18.4269, 0)
Vertex_c0024 = geompy.MakeVertex(2.3447, 18.745, 0)
Vertex_c0025 = geompy.MakeVertex(-1.7558, 14.2504, 0)
Vertex_c0026 = geompy.MakeVertex(2.7661, 19.0113, 0)
Vertex_c0027 = geompy.MakeVertex(-1.7351, 13.7514, 0)
Vertex_c0028 = geompy.MakeVertex(-1.6654, 13.2569, 0)
Vertex_c0029 = geompy.MakeVertex(-1.4192, 13.1625, 0)
Vertex_c0030 = geompy.MakeVertex(-1.8175, 12.8603, 0)
Vertex_c0031 = geompy.MakeVertex(3.2239, 19.2085, 0)
Vertex_c0032 = geompy.MakeVertex(3.4478, 19.5385, 0)
Vertex_c0033 = geompy.MakeVertex(3.4734, 19.0391, 0)
Vertex_c0034 = geompy.MakeVertex(3.4222, 20.0378, 0)
Vertex_c0035 = geompy.MakeVertex(3.3966, 20.5372, 0)
Vertex_c0036 = geompy.MakeVertex(3.371, 21.0365, 0)
Vertex_c0037 = geompy.MakeVertex(3.3455, 21.5359, 0)
Vertex_c0038 = geompy.MakeVertex(3.3179, 22.0351, 0)
Vertex_c0039 = geompy.MakeVertex(3.2846, 22.534, 0)
Vertex_c0040 = geompy.MakeVertex(3.2418, 23.0321, 0)
Vertex_c0041 = geompy.MakeVertex(3.2537, 23.5283, 0)
Vertex_c0042 = geompy.MakeVertex(3.3264, 24.023, 0)
Vertex_c0043 = geompy.MakeVertex(3.399, 24.5177, 0)
Vertex_c0044 = geompy.MakeVertex(3.6281, 24.9241, 0)
Vertex_c0045 = geompy.MakeVertex(4.0138, 25.2424, 0)
Vertex_c0046 = geompy.MakeVertex(4.3994, 25.5607, 0)
Vertex_c0047 = geompy.MakeVertex(4.785, 25.8789, 0)
Vertex_c0048 = geompy.MakeVertex(4.8823, 26.2691, 0)
Vertex_c0049 = geompy.MakeVertex(5.0734, 25.8071, 0)
Normal_c0001 = geompy.MakeVectorDXDYDZ(6.1232e-17, 1, 0)
Normal_c0002 = geompy.MakeVectorDXDYDZ(6.1232e-17, 1, 0)
Normal_c0003 = geompy.MakeVectorDXDYDZ(6.1232e-17, 1, 0)
Normal_c0004 = geompy.MakeVectorDXDYDZ(6.1232e-17, 1, 0)
Normal_c0005 = geompy.MakeVectorDXDYDZ(6.1232e-17, 1, 0)
Normal_c0006 = geompy.MakeVectorDXDYDZ(-0.9727, -0.23207, 0)
Normal_c0007 = geompy.MakeVectorDXDYDZ(-0.9727, -0.23207, 0)
Normal_c0008 = geompy.MakeVectorDXDYDZ(0.00073192, 1, 0)
Normal_c0009 = geompy.MakeVectorDXDYDZ(-0.9727, -0.23207, 0)
Normal_c0010 = geompy.MakeVectorDXDYDZ(-0.9172, -0.39843, 0)
Normal_c0011 = geompy.MakeVectorDXDYDZ(-0.99997, 0.0077962, 0)
Normal_c0012 = geompy.MakeVectorDXDYDZ(-0.99997, 0.0077962, 0)
Normal_c0013 = geompy.MakeVectorDXDYDZ(-0.82545, 0.56447, 0)
Normal_c0014 = geompy.MakeVectorDXDYDZ(-0.9727, -0.23207, 0)
Normal_c0015 = geompy.MakeVectorDXDYDZ(-0.99997, 0.0077962, 0)
Normal_c0016 = geompy.MakeVectorDXDYDZ(-0.89966, 0.43658, 0)
Normal_c0017 = geompy.MakeVectorDXDYDZ(-0.99997, 0.0077962, 0)
Normal_c0018 = geompy.MakeVectorDXDYDZ(-0.89966, 0.43658, 0)
Normal_c0019 = geompy.MakeVectorDXDYDZ(-0.99997, 0.0077962, 0)
Normal_c0020 = geompy.MakeVectorDXDYDZ(-0.89966, 0.43658, 0)
Normal_c0021 = geompy.MakeVectorDXDYDZ(-0.60916, 0.79305, 0)
Normal_c0022 = geompy.MakeVectorDXDYDZ(-0.89966, 0.43658, 0)
Normal_c0023 = geompy.MakeVectorDXDYDZ(-0.67429, 0.73847, 0)
Normal_c0024 = geompy.MakeVectorDXDYDZ(-0.5978, 0.80165, 0)
Normal_c0025 = geompy.MakeVectorDXDYDZ(-0.99997, 0.0077962, 0)
Normal_c0026 = geompy.MakeVectorDXDYDZ(-0.46741, 0.88404, 0)
Normal_c0027 = geompy.MakeVectorDXDYDZ(-0.99588, -0.090682, 0)
Normal_c0028 = geompy.MakeVectorDXDYDZ(-0.98212, -0.18823, 0)
Normal_c0029 = geompy.MakeVectorDXDYDZ(-0.60439, 0.79669, 0)
Normal_c0030 = geompy.MakeVectorDXDYDZ(-0.60439, 0.79669, 0)
Normal_c0031 = geompy.MakeVectorDXDYDZ(-0.32137, 0.94695, 0)
Normal_c0032 = geompy.MakeVectorDXDYDZ(-0.99869, -0.051181, 0)
Normal_c0033 = geompy.MakeVectorDXDYDZ(-0.99869, -0.051181, 0)
Normal_c0034 = geompy.MakeVectorDXDYDZ(-0.99869, -0.051181, 0)
Normal_c0035 = geompy.MakeVectorDXDYDZ(-0.99869, -0.051181, 0)
Normal_c0036 = geompy.MakeVectorDXDYDZ(-0.99869, -0.051181, 0)
Normal_c0037 = geompy.MakeVectorDXDYDZ(-0.99869, -0.051181, 0)
Normal_c0038 = geompy.MakeVectorDXDYDZ(-0.99825, -0.059095, 0)
Normal_c0039 = geompy.MakeVectorDXDYDZ(-0.99726, -0.073937, 0)
Normal_c0040 = geompy.MakeVectorDXDYDZ(-0.99524, -0.09749, 0)
Normal_c0041 = geompy.MakeVectorDXDYDZ(-0.98939, 0.14528, 0)
Normal_c0042 = geompy.MakeVectorDXDYDZ(-0.98939, 0.14528, 0)
Normal_c0043 = geompy.MakeVectorDXDYDZ(-0.98939, 0.14528, 0)
Normal_c0044 = geompy.MakeVectorDXDYDZ(-0.63654, 0.77125, 0)
Normal_c0045 = geompy.MakeVectorDXDYDZ(-0.63654, 0.77125, 0)
Normal_c0046 = geompy.MakeVectorDXDYDZ(-0.63654, 0.77125, 0)
Normal_c0047 = geompy.MakeVectorDXDYDZ(-0.63654, 0.77125, 0)
Normal_c0048 = geompy.MakeVectorDXDYDZ(-0.92407, -0.38223, 0)
Normal_c0049 = geompy.MakeVectorDXDYDZ(-0.92407, -0.38223, 0)
Plane_c0001 = geompy.MakePlane(Vertex_c0001, Normal_c0001, 0.5)
Plane_c0002 = geompy.MakePlane(Vertex_c0002, Normal_c0002, 0.5)
Plane_c0003 = geompy.MakePlane(Vertex_c0003, Normal_c0003, 0.5)
Plane_c0004 = geompy.MakePlane(Vertex_c0004, Normal_c0004, 0.5)
Plane_c0005 = geompy.MakePlane(Vertex_c0005, Normal_c0005, 0.5)
Plane_c0006 = geompy.MakePlane(Vertex_c0006, Normal_c0006, 0.5)
Plane_c0007 = geompy.MakePlane(Vertex_c0007, Normal_c0007, 0.5)
Plane_c0008 = geompy.MakePlane(Vertex_c0008, Normal_c0008, 0.5)
Plane_c0009 = geompy.MakePlane(Vertex_c0009, Normal_c0009, 0.5)
Plane_c0010 = geompy.MakePlane(Vertex_c0010, Normal_c0010, 0.5)
Plane_c0011 = geompy.MakePlane(Vertex_c0011, Normal_c0011, 0.5)
Plane_c0012 = geompy.MakePlane(Vertex_c0012, Normal_c0012, 0.5)
Plane_c0013 = geompy.MakePlane(Vertex_c0013, Normal_c0013, 0.5)
Plane_c0014 = geompy.MakePlane(Vertex_c0014, Normal_c0014, 0.5)
Plane_c0015 = geompy.MakePlane(Vertex_c0015, Normal_c0015, 0.5)
Plane_c0016 = geompy.MakePlane(Vertex_c0016, Normal_c0016, 0.5)
Plane_c0017 = geompy.MakePlane(Vertex_c0017, Normal_c0017, 0.5)
Plane_c0018 = geompy.MakePlane(Vertex_c0018, Normal_c0018, 0.5)
Plane_c0019 = geompy.MakePlane(Vertex_c0019, Normal_c0019, 0.5)
Plane_c0020 = geompy.MakePlane(Vertex_c0020, Normal_c0020, 0.5)
Plane_c0021 = geompy.MakePlane(Vertex_c0021, Normal_c0021, 0.5)
Plane_c0022 = geompy.MakePlane(Vertex_c0022, Normal_c0022, 0.5)
Plane_c0023 = geompy.MakePlane(Vertex_c0023, Normal_c0023, 0.5)
Plane_c0024 = geompy.MakePlane(Vertex_c0024, Normal_c0024, 0.5)
Plane_c0025 = geompy.MakePlane(Vertex_c0025, Normal_c0025, 0.5)
Plane_c0026 = geompy.MakePlane(Vertex_c0026, Normal_c0026, 0.5)
Plane_c0027 = geompy.MakePlane(Vertex_c0027, Normal_c0027, 0.5)
Plane_c0028 = geompy.MakePlane(Vertex_c0028, Normal_c0028, 0.5)
Plane_c0029 = geompy.MakePlane(Vertex_c0029, Normal_c0029, 0.5)
Plane_c0030 = geompy.MakePlane(Vertex_c0030, Normal_c0030, 0.5)
Plane_c0031 = geompy.MakePlane(Vertex_c0031, Normal_c0031, 0.5)
Plane_c0032 = geompy.MakePlane(Vertex_c0032, Normal_c0032, 0.5)
Plane_c0033 = geompy.MakePlane(Vertex_c0033, Normal_c0033, 0.5)
Plane_c0034 = geompy.MakePlane(Vertex_c0034, Normal_c0034, 0.5)
Plane_c0035 = geompy.MakePlane(Vertex_c0035, Normal_c0035, 0.5)
Plane_c0036 = geompy.MakePlane(Vertex_c0036, Normal_c0036, 0.5)
Plane_c0037 = geompy.MakePlane(Vertex_c0037, Normal_c0037, 0.5)
Plane_c0038 = geompy.MakePlane(Vertex_c0038, Normal_c0038, 0.5)
Plane_c0039 = geompy.MakePlane(Vertex_c0039, Normal_c0039, 0.5)
Plane_c0040 = geompy.MakePlane(Vertex_c0040, Normal_c0040, 0.5)
Plane_c0041 = geompy.MakePlane(Vertex_c0041, Normal_c0041, 0.5)
Plane_c0042 = geompy.MakePlane(Vertex_c0042, Normal_c0042, 0.5)
Plane_c0043 = geompy.MakePlane(Vertex_c0043, Normal_c0043, 0.5)
Plane_c0044 = geompy.MakePlane(Vertex_c0044, Normal_c0044, 0.5)
Plane_c0045 = geompy.MakePlane(Vertex_c0045, Normal_c0045, 0.5)
Plane_c0046 = geompy.MakePlane(Vertex_c0046, Normal_c0046, 0.5)
Plane_c0047 = geompy.MakePlane(Vertex_c0047, Normal_c0047, 0.5)
Plane_c0048 = geompy.MakePlane(Vertex_c0048, Normal_c0048, 0.5)
Plane_c0049 = geompy.MakePlane(Vertex_c0049, Normal_c0049, 0.5)
geompy.addToStudy(Vertex_c0001,'Vertex_c0001')
geompy.addToStudy(Vertex_c0002,'Vertex_c0002')
geompy.addToStudy(Vertex_c0003,'Vertex_c0003')
geompy.addToStudy(Vertex_c0004,'Vertex_c0004')
geompy.addToStudy(Vertex_c0005,'Vertex_c0005')
geompy.addToStudy(Vertex_c0006,'Vertex_c0006')
geompy.addToStudy(Vertex_c0007,'Vertex_c0007')
geompy.addToStudy(Vertex_c0008,'Vertex_c0008')
geompy.addToStudy(Vertex_c0009,'Vertex_c0009')
geompy.addToStudy(Vertex_c0010,'Vertex_c0010')
geompy.addToStudy(Vertex_c0011,'Vertex_c0011')
geompy.addToStudy(Vertex_c0012,'Vertex_c0012')
geompy.addToStudy(Vertex_c0013,'Vertex_c0013')
geompy.addToStudy(Vertex_c0014,'Vertex_c0014')
geompy.addToStudy(Vertex_c0015,'Vertex_c0015')
geompy.addToStudy(Vertex_c0016,'Vertex_c0016')
geompy.addToStudy(Vertex_c0017,'Vertex_c0017')
geompy.addToStudy(Vertex_c0018,'Vertex_c0018')
geompy.addToStudy(Vertex_c0019,'Vertex_c0019')
geompy.addToStudy(Vertex_c0020,'Vertex_c0020')
geompy.addToStudy(Vertex_c0021,'Vertex_c0021')
geompy.addToStudy(Vertex_c0022,'Vertex_c0022')
geompy.addToStudy(Vertex_c0023,'Vertex_c0023')
geompy.addToStudy(Vertex_c0024,'Vertex_c0024')
geompy.addToStudy(Vertex_c0025,'Vertex_c0025')
geompy.addToStudy(Vertex_c0026,'Vertex_c0026')
geompy.addToStudy(Vertex_c0027,'Vertex_c0027')
geompy.addToStudy(Vertex_c0028,'Vertex_c0028')
geompy.addToStudy(Vertex_c0029,'Vertex_c0029')
geompy.addToStudy(Vertex_c0030,'Vertex_c0030')
geompy.addToStudy(Vertex_c0031,'Vertex_c0031')
geompy.addToStudy(Vertex_c0032,'Vertex_c0032')
geompy.addToStudy(Vertex_c0033,'Vertex_c0033')
geompy.addToStudy(Vertex_c0034,'Vertex_c0034')
geompy.addToStudy(Vertex_c0035,'Vertex_c0035')
geompy.addToStudy(Vertex_c0036,'Vertex_c0036')
geompy.addToStudy(Vertex_c0037,'Vertex_c0037')
geompy.addToStudy(Vertex_c0038,'Vertex_c0038')
geompy.addToStudy(Vertex_c0039,'Vertex_c0039')
geompy.addToStudy(Vertex_c0040,'Vertex_c0040')
geompy.addToStudy(Vertex_c0041,'Vertex_c0041')
geompy.addToStudy(Vertex_c0042,'Vertex_c0042')
geompy.addToStudy(Vertex_c0043,'Vertex_c0043')
geompy.addToStudy(Vertex_c0044,'Vertex_c0044')
geompy.addToStudy(Vertex_c0045,'Vertex_c0045')
geompy.addToStudy(Vertex_c0046,'Vertex_c0046')
geompy.addToStudy(Vertex_c0047,'Vertex_c0047')
geompy.addToStudy(Vertex_c0048,'Vertex_c0048')
geompy.addToStudy(Vertex_c0049,'Vertex_c0049')
geompy.addToStudy(Normal_c0001,'Normal_c0001')
geompy.addToStudy(Normal_c0002,'Normal_c0002')
geompy.addToStudy(Normal_c0003,'Normal_c0003')
geompy.addToStudy(Normal_c0004,'Normal_c0004')
geompy.addToStudy(Normal_c0005,'Normal_c0005')
geompy.addToStudy(Normal_c0006,'Normal_c0006')
geompy.addToStudy(Normal_c0007,'Normal_c0007')
geompy.addToStudy(Normal_c0008,'Normal_c0008')
geompy.addToStudy(Normal_c0009,'Normal_c0009')
geompy.addToStudy(Normal_c0010,'Normal_c0010')
geompy.addToStudy(Normal_c0011,'Normal_c0011')
geompy.addToStudy(Normal_c0012,'Normal_c0012')
geompy.addToStudy(Normal_c0013,'Normal_c0013')
geompy.addToStudy(Normal_c0014,'Normal_c0014')
geompy.addToStudy(Normal_c0015,'Normal_c0015')
geompy.addToStudy(Normal_c0016,'Normal_c0016')
geompy.addToStudy(Normal_c0017,'Normal_c0017')
geompy.addToStudy(Normal_c0018,'Normal_c0018')
geompy.addToStudy(Normal_c0019,'Normal_c0019')
geompy.addToStudy(Normal_c0020,'Normal_c0020')
geompy.addToStudy(Normal_c0021,'Normal_c0021')
geompy.addToStudy(Normal_c0022,'Normal_c0022')
geompy.addToStudy(Normal_c0023,'Normal_c0023')
geompy.addToStudy(Normal_c0024,'Normal_c0024')
geompy.addToStudy(Normal_c0025,'Normal_c0025')
geompy.addToStudy(Normal_c0026,'Normal_c0026')
geompy.addToStudy(Normal_c0027,'Normal_c0027')
geompy.addToStudy(Normal_c0028,'Normal_c0028')
geompy.addToStudy(Normal_c0029,'Normal_c0029')
geompy.addToStudy(Normal_c0030,'Normal_c0030')
geompy.addToStudy(Normal_c0031,'Normal_c0031')
geompy.addToStudy(Normal_c0032,'Normal_c0032')
geompy.addToStudy(Normal_c0033,'Normal_c0033')
geompy.addToStudy(Normal_c0034,'Normal_c0034')
geompy.addToStudy(Normal_c0035,'Normal_c0035')
geompy.addToStudy(Normal_c0036,'Normal_c0036')
geompy.addToStudy(Normal_c0037,'Normal_c0037')
geompy.addToStudy(Normal_c0038,'Normal_c0038')
geompy.addToStudy(Normal_c0039,'Normal_c0039')
geompy.addToStudy(Normal_c0040,'Normal_c0040')
geompy.addToStudy(Normal_c0041,'Normal_c0041')
geompy.addToStudy(Normal_c0042,'Normal_c0042')
geompy.addToStudy(Normal_c0043,'Normal_c0043')
geompy.addToStudy(Normal_c0044,'Normal_c0044')
geompy.addToStudy(Normal_c0045,'Normal_c0045')
geompy.addToStudy(Normal_c0046,'Normal_c0046')
geompy.addToStudy(Normal_c0047,'Normal_c0047')
geompy.addToStudy(Normal_c0048,'Normal_c0048')
geompy.addToStudy(Normal_c0049,'Normal_c0049')
geompy.addToStudy(Plane_c0001,'Plane_c0001')
geompy.addToStudy(Plane_c0002,'Plane_c0002')
geompy.addToStudy(Plane_c0003,'Plane_c0003')
geompy.addToStudy(Plane_c0004,'Plane_c0004')
geompy.addToStudy(Plane_c0005,'Plane_c0005')
geompy.addToStudy(Plane_c0006,'Plane_c0006')
geompy.addToStudy(Plane_c0007,'Plane_c0007')
geompy.addToStudy(Plane_c0008,'Plane_c0008')
geompy.addToStudy(Plane_c0009,'Plane_c0009')
geompy.addToStudy(Plane_c0010,'Plane_c0010')
geompy.addToStudy(Plane_c0011,'Plane_c0011')
geompy.addToStudy(Plane_c0012,'Plane_c0012')
geompy.addToStudy(Plane_c0013,'Plane_c0013')
geompy.addToStudy(Plane_c0014,'Plane_c0014')
geompy.addToStudy(Plane_c0015,'Plane_c0015')
geompy.addToStudy(Plane_c0016,'Plane_c0016')
geompy.addToStudy(Plane_c0017,'Plane_c0017')
geompy.addToStudy(Plane_c0018,'Plane_c0018')
geompy.addToStudy(Plane_c0019,'Plane_c0019')
geompy.addToStudy(Plane_c0020,'Plane_c0020')
geompy.addToStudy(Plane_c0021,'Plane_c0021')
geompy.addToStudy(Plane_c0022,'Plane_c0022')
geompy.addToStudy(Plane_c0023,'Plane_c0023')
geompy.addToStudy(Plane_c0024,'Plane_c0024')
geompy.addToStudy(Plane_c0025,'Plane_c0025')
geompy.addToStudy(Plane_c0026,'Plane_c0026')
geompy.addToStudy(Plane_c0027,'Plane_c0027')
geompy.addToStudy(Plane_c0028,'Plane_c0028')
geompy.addToStudy(Plane_c0029,'Plane_c0029')
geompy.addToStudy(Plane_c0030,'Plane_c0030')
geompy.addToStudy(Plane_c0031,'Plane_c0031')
geompy.addToStudy(Plane_c0032,'Plane_c0032')
geompy.addToStudy(Plane_c0033,'Plane_c0033')
geompy.addToStudy(Plane_c0034,'Plane_c0034')
geompy.addToStudy(Plane_c0035,'Plane_c0035')
geompy.addToStudy(Plane_c0036,'Plane_c0036')
geompy.addToStudy(Plane_c0037,'Plane_c0037')
geompy.addToStudy(Plane_c0038,'Plane_c0038')
geompy.addToStudy(Plane_c0039,'Plane_c0039')
geompy.addToStudy(Plane_c0040,'Plane_c0040')
geompy.addToStudy(Plane_c0041,'Plane_c0041')
geompy.addToStudy(Plane_c0042,'Plane_c0042')
geompy.addToStudy(Plane_c0043,'Plane_c0043')
geompy.addToStudy(Plane_c0044,'Plane_c0044')
geompy.addToStudy(Plane_c0045,'Plane_c0045')
geompy.addToStudy(Plane_c0046,'Plane_c0046')
geompy.addToStudy(Plane_c0047,'Plane_c0047')
geompy.addToStudy(Plane_c0048,'Plane_c0048')
geompy.addToStudy(Plane_c0049,'Plane_c0049')
Compound_c0001 = geompy.MakeCompound([Plane_c0001, \
Plane_c0002, \
Plane_c0003, \
Plane_c0004, \
Plane_c0005, \
Plane_c0006, \
Plane_c0007, \
Plane_c0008, \
Plane_c0009, \
Plane_c0010, \
Plane_c0011, \
Plane_c0012, \
Plane_c0013, \
Plane_c0014, \
Plane_c0015, \
Plane_c0016, \
Plane_c0017, \
Plane_c0018, \
Plane_c0019, \
Plane_c0020, \
Plane_c0021, \
Plane_c0022, \
Plane_c0023, \
Plane_c0024, \
Plane_c0025, \
Plane_c0026, \
Plane_c0027, \
Plane_c0028, \
Plane_c0029, \
Plane_c0030, \
Plane_c0031, \
Plane_c0032, \
Plane_c0033, \
Plane_c0034, \
Plane_c0035, \
Plane_c0036, \
Plane_c0037, \
Plane_c0038, \
Plane_c0039, \
Plane_c0040, \
Plane_c0041, \
Plane_c0042, \
Plane_c0043, \
Plane_c0044, \
Plane_c0045, \
Plane_c0046, \
Plane_c0047, \
Plane_c0048, \
Plane_c0049, \
geompy.addToStudy( Compound_c0001,'Compound_c0001')
Glue_c0001 = geompy.MakeGlueEdges(Compound_c0001, 0.001)
geompy.addToStudy( Glue_c0001,'Glue_c0001')
geompy.ExportIGES(Glue_c0001,'./DFNGeometry.iges')
Old   August 2, 2019, 09:40
Mohammad Hossein GOlestan
mhgolestan is on a distinguished road
Hi @anufagbemi
I want to create a mesh similar to yours (porous structure), but faced the same error. Could you solve this issue?
mhgolestan is offline   Reply With Quote
How I can introduce my power heat (W) in chtMultiRegionFoam? aminem OpenFOAM Pre-Processing 32 August 29, 2019 03:23
Conjugate heat transfer- chtMultiRegionFoam Divergence after changing mesh size sandymech1 OpenFOAM Running, Solving & CFD 1 March 10, 2018 14:09
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
