[blockMesh] Cylinder mesh using blockMesh with m4 macro
Like Tree1Likes
  • 1 Post By Antimony
Old   November 21, 2017, 02:30
Default Cylinder mesh using blockMesh with m4 macro
Lewis
Lewis Liang is on a distinguished road
Currently, I am trying to mesh a vertical cylinder by using the m4 macro provides by Ehsan Madadi. The script is shown below:
|  \\    /   O peration     |                                                 |
|   \\  /    A nd           | Copyright (C) 2016 Ehsan Madadi-Kandjani        |
FoamFile
    version     2.0;
    `format'      ascii;
    class       dictionary;
    object      blockMeshDict;
// General macros to create cylinder mesh
changecom(//)changequote([,])
define(calc, [esyscmd(perl -e 'use Math::Trig; print ($1)')])
define(VCOUNT, 0)
define(vlabel, [[// ]Vertex $1 = VCOUNT define($1, VCOUNT)define([VCOUNT], incr(VCOUNT))])
define(hex2D, hex ($1b $2b $3b $4b $1t $2t $3t $4t))
define(btQuad, ($1b $2b $2t $1t))
define(topQuad, ($1t $4t $3t $2t))
define(bottomQuad, ($1b $2b $3b $4b))
convertToMeters 0.001;
// Inner square side half
define(s, 0.35)
// Inner square side curvature
define(sc, 0.4)
// cylinder radius
define(r, 0.7)
// Height of cylinder
define(z, 20.0)
// Base z
define(Zb, 0)
// Outlet z
define(Zt, calc(Zb + z))
// Number of cells at inner square
define(Ns, 20)
// Number of cells between inner square and circle
define(Ni, 10)
// Number of cells in the cylinder height
define(Nz, 100)
As introduced from the http://www.ehsanmadadi.com/cylinder-mesh/ and the OpenFOAMWiki https://openfoamwiki.net/index.php/H...ckMesh_with_m4. I just can mesh a cylinder with a centre of bottom plane located in (0 0 0). It is straightforward to set up the length and original point in the Z direction. However, I am confusing to modify original point in XY plane, for example, to build a cylinder whose central point of bottom plane located in (10 10 0). Could anyone face this same problem?
Thanks in advance!
Zuodong
Lewis Liang is offline   Reply With Quote
Old   November 21, 2017, 03:15
Antimony is on a distinguished road
One possible solution would be to use transformPoints and translate by the vector (10 10 0) after you have created the mesh using blockMesh
Cheers,
Antimony
Lewis Liang likes this.
Antimony is offline   Reply With Quote
Old   November 21, 2017, 03:28
Lewis
Hi Antimony! It works now after typing this command:
transformPoints -translate '(10 10 0)'
Many thanks!
Zuodong
[ICEM] How to mesh for regular pentagonal cylinder using ICEM in 2D? ranjanrk ANSYS Meshing & Geometry 0 June 18, 2016 03:10
Dynamic Structured mesh around cylinder problem!!! ludosbiz Mesh Generation & Pre-Processing 2 March 23, 2016 16:15
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 07:42
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
