[snappyHexMesh] rotate searchableBox
Like Tree3Likes
  • 3 Post By KKV_88
Old   October 17, 2017, 10:15
Question rotate searchableBox
Fridrik Magnusson
Fridrik is on a distinguished road
Hallo Everyone
Im trying to rotate a searchableBox 60 deg (pi/3) with the following command:
refinementBox4
    type searchableBox;
    min (0.355 0.190 -0.01);
    max (0.485 0.250 0.12);
    transform
                coordinateSystem
                    type    cartesian;
                    origin  (0 0 0);
                    coordinateRotation
                      type    localAxesRotation;
                      e3      (60 0 0);
but it is not rotating at all, can anybody give me a hint of what im doing wrong ?
Fridrik is offline   Reply With Quote
Old   August 12, 2018, 08:41
KAWA
KMM080 is on a distinguished road
Originally Posted by Fridrik View Post
Hallo Everyone
refinementBox4
    type searchableBox;
    transform
                coordinateSystem
                    type    cartesian;
                    origin  (0 0 0);
                    coordinateRotation
                      e3      (60 0 0);
Hi Fridrik,
Have you solved this problem, I have exactly the same problem?
Regards
KMM080 is offline   Reply With Quote
Old   November 9, 2019, 10:56
Kristina
KKV_88 is on a distinguished road
Originally Posted by KMM080 View Post
Hi Fridrik,
Regards
I'm posting my solution in the following. Hope it will help someone.
I rotated searchableBox for 45 deg. around y-axes.
zone1
		name zone1;
        	type searchableRotatedBox;
        	span    (1 1 1); //dimensions of the box
        	origin  (0 0 -0.707); //first corner of the box - origin of local coordinate system
		//definition of the axes of the local coordinate system (cartesian, left-handed coordinate system)
		e1      (0.707 0 0.707); //relationship of e1 local axes and global coord.system
                e3      (-0.707 0 0.707); //relationship of e3 local axes and global coord.system
hogsonik, allanZHONG and davcrisp like this.
KKV_88 is offline   Reply With Quote
Old   July 31, 2023, 04:19
CFDUser29 is on a distinguished road
zone1
		name zone1;
Your solution is very interesting, but it seems that with you solution you can't decide where in your domain your box is. If I understood correctly, you set the length of each dimension of the box, then the origin for the rotation and the two vectors for the rotation.
Suppose my box is located with : min(x1, y1, z1), max(x2, y2, z2), and that the origin for the rotation is outside my box. How do I do that?
If you have a solution, I would be glad because I could not find anything relevant but your post.
CFDUser29 is offline   Reply With Quote
Old   July 31, 2023, 06:42
M
AtoHM is on a distinguished road
Cool - I was not aware this is possible.
However - I would not approach this on the snappy-Level, but build this kind of geometry in a CAD tool where I can convince myself visually that it comes out right, export that to stl and use it as a refinement region.
AtoHM is offline   Reply With Quote
Old   August 1, 2023, 05:19
I guess this is the simplest way and a no-echec solution, but that can take a lot of time if there is 3 internal refined meshes to rotate for 12 different angles. Good solution though. Thanks
rotating, searchablebox, shm
[Gmsh] Rotate and duplicate mesh! tareqkh OpenFOAM Meshing & Mesh Conversion 1 December 23, 2019 14:01
Rotate frame reference in transient simulation wjy-c CFX 4 September 4, 2013 22:20
How to rotate a pointScalarField? carowjp OpenFOAM Programming & Development 5 January 27, 2013 20:49
surfaceTransformPoints -rotate ynos OpenFOAM Post-Processing 1 July 11, 2012 16:35
[GAMBIT] Rotate and revolute possible ? Ijaz ANSYS Meshing & Geometry 19 January 27, 2012 00:36
