September 25, 2017, 10:53 |
Bad snappyHexMesh transition
Mosaad
Dear all,
I am trying to generate mesh with 3 different level of refinement. But I always obtain a bad transition between them as show in the following picture. How can I overcome this problem ? Regards, |
September 25, 2017, 12:32 |
Brian Willis
Rep Power: 15 |
Your mesh may be fine. When viewing a slice in Paraview, apply the option of crinkle cut to view the mesh without any kind of interpolation which is probably what you are seeing in the attached photo.
September 25, 2017, 14:03 |
Icaro A. Accordi
Rep Power: 16 |
...and unclick decompose polyhedra
September 28, 2017, 08:46 |
Solved
Mosaad
Thanks all un-checking the "decompose polyhedral" and crinkle solved the problem
[snappyHexMesh] snappyHexMesh Parallel bad size error | andrewpomeroy | OpenFOAM Meshing & Mesh Conversion | 2 | April 2, 2018 02:08 |
[snappyHexMesh] bad trailing edge boundary layer with snappyHexMesh | draufunddran | OpenFOAM Meshing & Mesh Conversion | 14 | March 1, 2018 10:42 |
[snappyHexMesh] snappyHexMesh: Bad snapping on shallow slopes | matthiasd | OpenFOAM Meshing & Mesh Conversion | 5 | February 1, 2017 18:23 |
[Other] Bad Mesh transition | BakedAlmonds | OpenFOAM Meshing & Mesh Conversion | 1 | July 21, 2016 06:18 |
[snappyHexMesh] Remove snappyHexMesh bad cells (subSetMesh) | jet_engine | OpenFOAM Meshing & Mesh Conversion | 1 | June 24, 2016 10:31 |
