[blockMesh] Unable to run blockMesh for tutorial "cylinder" in OpenFoam |
Sampath
Rep Power: 0 ![]() |
I am using OpenFoam v1706 and doing the tutorials. I am using bash on ubuntu on windows. There I have encountered the following error. Please help me resolve it. Thanks in advance Sampath. /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1706 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : v1706-17752679325a Arch : "LSB;label=32;scalar=64" Exec : blockMesh Date : Sep 25 2017 Time : 15:11:13 Host : "Sampath" PID : 840 Case : /mnt/g/ofsampath/trial_runs/cylinderRuns/cylinder nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "/mnt/g/ofsampath/trial_runs/cylinderRuns/cylinder/system/blockMeshDict" Using #codeStream at line 19 in file "/mnt/g/ofsampath/trial_runs/cylinderRuns/cylinder/system/blockMeshDict" Using #codeStream with "/mnt/g/ofsampath/trial_runs/cylinderRuns/cylinder/dynamicCode/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_1c19e29ae18c779aa836a14631d6419f303e 3d9d.so" Invoking wmake libso /mnt/g/ofsampath/trial_runs/cylinderRuns/cylinder/dynamicCode/_1c19e29ae18c779aa836a14631d6419f303e3d9d wmake libso /mnt/g/ofsampath/trial_runs/cylinderRuns/cylinder/dynamicCode/_1c19e29ae18c779aa836a14631d6419f303e3d9d g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1706 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -g -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1706/src/OSspecific/POSIX/lnInclude -fPIC -c codeStreamTemplate.C -o Make/linux64Gcc63DPInt32Opt/codeStreamTemplate.o In file included from /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/scalar.H:39:0, from /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/IOstream.H:49, from /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/Ostream.H:39, from /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/UILListIO.C:27, from /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/UILList.C:91, from /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/UILList.H:383, from /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/ILList.H:39, from /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/IDLList.H:35, from /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/entry.H:45, from /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/dictionary.H:84, from codeStreamTemplate.C:29: /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/floatScalar.H:54:1: internal compiler error: Illegal instruction static const floatScalar floatScalarGREAT = 1.0e+6; ^~~~~~ 0xac5ddf crash_signal /home/pgh/OpenFOAM/ThirdParty-1706/gcc-6.3.0/gcc/toplev.c:333 Please submit a full bug report, with preprocessed source if appropriate. Please include the complete backtrace with any bug report. See <http://gcc.gnu.org/bugs.html> for instructions. /opt/OpenFOAM/OpenFOAM-v1706/wmake/rules/General/transform:28: recipe for target 'Make/linux64Gcc63DPInt32Opt/codeStreamTemplate.o' failed make: *** [Make/linux64Gcc63DPInt32Opt/codeStreamTemplate.o] Error 1 --> FOAM FATAL IO ERROR: Failed wmake "dynamicCode/_1c19e29ae18c779aa836a14631d6419f303e3d9d/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_1c19e29ae18c779aa836a14631d6419f303e 3d9d.so" file: /mnt/g/ofsampath/trial_runs/cylinderRuns/cylinder/system/blockMeshDict from line 17 to line 17. From function static void (* Foam::functionEntries::codeStream::getFunction(con st Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&) in file db/dictionary/functionEntries/codeStream/codeStream.C at line 219. FOAM exiting ksb@Sampath:/mnt/g/ofsampath/trial_runs/cylinderRuns/cylinder$ |
Rep Power: 9 ![]() |
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file codeStreamTemplate.C g++ -std=c++11 -m64 -DOPENFOAM_PLUS=1706 -Dlinux64 -DWM_ARCH_OPTION=64 -DWM_DP -DWM_LABEL_SIZE=32 -Wall -Wextra -Wold-style-cast -Wnon-virtual-dtor -Wno-unused-parameter -Wno-invalid-offsetof -O3 -DNoRepository -ftemplate-depth-100 -g -IlnInclude -I. -I/opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude -I/opt/OpenFOAM/OpenFOAM-v1706/src/OSspecific/POSIX/lnInclude -fPIC -c codeStreamTemplate.C -o Make/linux64Gcc63DPInt32Opt/codeStreamTemplate.o In file included from /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/scalar.H:39:0, from /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/IOstream.H:49, from /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/Ostream.H:39, from /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/UILListIO.C:27, from /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/UILList.C:91, from /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/UILList.H:383, from /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/ILList.H:39, from /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/IDLList.H:35, from /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/entry.H:45, from /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/dictionary.H:84, from codeStreamTemplate.C:29: /opt/OpenFOAM/OpenFOAM-v1706/src/OpenFOAM/lnInclude/floatScalar.H:54:1: internal compiler error: Illegal instruction static const floatScalar floatScalarGREAT = 1.0e+6; ^~~~~~ 0xac5ddf crash_signal /home/pgh/OpenFOAM/ThirdParty-1706/gcc-6.3.0/gcc/toplev.c:333 Please submit a full bug report, with preprocessed source if appropriate. Please include the complete backtrace with any bug report. See <http://gcc.gnu.org/bugs.html> for instructions. /opt/OpenFOAM/OpenFOAM-v1706/wmake/rules/General/transform:28: recipe for target 'Make/linux64Gcc63DPInt32Opt/codeStreamTemplate.o' failed make: *** [Make/linux64Gcc63DPInt32Opt/codeStreamTemplate.o] Error 1 --> FOAM FATAL IO ERROR: Failed wmake "dynamicCode/_2c1a7ee7b5369acae9da148f9823fdd8cde6256a/platforms/linux64Gcc63DPInt32Opt/lib/libcodeStream_2c1a7ee7b5369acae9da148f9823fdd8cde6 256a.so" file: /home/user/pipeCyclic/system/blockMeshDict from line 17 to line 23. From function static void (* Foam::functionEntries::codeStream::getFunction(con st Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&) in file db/dictionary/functionEntries/codeStream/codeStream.C at line 219. FOAM exiting |
I solved the problem by removing OpenFoam v1706 and reinstalling OpenFoam v5 for ubuntu by following the instructions on https://openfoam.org/download/5-0-ubuntu/ on my Bash on Ubuntu on Windows.
Ph.D.(c) Oğuzhan KIRIKBAŞ
I also have the same problem. I use OpenFOAM v1712 in ubuntu in windows. Can anybody help. I appreciate.
#5 | |
Mark Olesen
Rep Power: 40 ![]() ![]() |
The problem can't be the same with OpenFOAM-v1712 - it really must be something else - might have to check the error messages again. In 1706, and earlier Code:
static const floatScalar floatScalarGREAT = 1.0e+6; Code:
constexpr floatScalar floatScalarGREAT = 1.0e+6; but it might be a more general gcc-6.3.0 issue, as mentioned here: https://develop.openfoam.com/Develop...lus/issues/776 |
Flow past a 2D cylinder - High Re (1E+05) - Cd too high | Pervispasco | OpenFOAM Running, Solving & CFD | 4 | March 14, 2022 02:19 |
[blockMesh] Cylinder mesh using blockMesh with m4 macro | Lewis Liang | OpenFOAM Meshing & Mesh Conversion | 2 | November 21, 2017 02:28 |
OpenFOAM Training Jan-Jul 2017, Virtual, London, Houston, Berlin | CFDFoundation | OpenFOAM Announcements from Other Sources | 0 | January 4, 2017 06:15 |
[OpenFOAM.org] A Mac OS X of23x Development Environment Using Docker | rt08 | OpenFOAM Installation | 1 | February 28, 2016 19:00 |
[snappyHexMesh] Able to run snappyHexMesh in parallel on local machine but unable to run on linux clu | abhinav2601 | OpenFOAM Meshing & Mesh Conversion | 1 | January 26, 2015 05:42 |
