[snappyHexMesh] Small domains in multi-region SnappyHexMesh
Like Tree1Likes
  • 1 Post By Tobi
Old   August 15, 2017, 09:54
Default Small domains in multi-region SnappyHexMesh
nusivares is on a distinguished road
Hello all,
So, basically this has been an issue for some time - I have fixed it before, but this time it is proving quite painful comparatively.
At the interface between two .stl files I get created a bunch (in the order of tens) absolutely miniature domains, can be even a single cell..
Does anybody have solutions for that?
nusivares is offline   Reply With Quote
Old   August 15, 2017, 17:49
Matt
matth is on a distinguished road
Hi nusivares,
I recently had exactly this problem. Increasing the level of refinement for one of the surfaces to (2 2) from (1 1) in the refinementSurfaces subdict in snappyHexMeshDict did the trick.
Cheers,
Matt
matth is offline   Reply With Quote
Old   August 16, 2017, 06:23
Default I think I fixed it
So, I think I fixed it - I followed the guidance of Tobias Holzmann here:
https://www.youtube.com/watch?v=NBmB6xsnznw&t=863s
But used not instead of Netgen 2D .stl meshing(before exporting it as improved quality .stl), but mefisto - this seems to have done the trick this case.
Trial and error as usual.
Old   August 22, 2017, 11:14
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
This is the way I go, too. The Mifesto algorithm produces the same triangle on both interfaces while the Netgen 2D just be consistent at the connecting corners. However, personally, Netgen 2D produces qualitatively better meshes but for multi-region cases I use Mifesto as well.
student666 likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
[snappyHexMesh] Multi Region Mesh of a car filter Zephiro88 OpenFOAM Meshing & Mesh Conversion 3 September 11, 2019 20:34
How to let the mesh motion solver just solve a small region near a moving boundary? zhajingjing OpenFOAM Running, Solving & CFD 9 April 28, 2016 05:15
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Multi Region setup tladd OpenFOAM Pre-Processing 1 April 21, 2014 10:22
[snappyHexMesh] multi region laplacian OpenFOAM Meshing & Mesh Conversion 1 July 20, 2012 07:49
