[Other] checkMesh Error
Like Tree1Likes
  • 1 Post By Antimony
Old   July 31, 2017, 01:38
Default checkMesh Error
Upuli
upuli is on a distinguished road
Dear members
I created the following blockMesh file.
convertToMeters 1.0;
vertices
(-0.15 -0.15 -0.005) //0
(-0.15 0.15 -0.005)
(-0.05 0.45 -0.005)
(-0.05 0.45 0.005)
(-0.15 0.15 0.005)
(-0.15 -0.15 0.005)
(0.15 -0.15 -0.005)
(0.15 0.15 -0.005)
(0.05 0.45 -0.005)
(0.05 0.45 0.005)
(0.15 0.15 0.005)
(0.15 -0.15 0.005)
blocks
hex (0 5 4 1 6 11 10 7) (30 15 30) simpleGrading (1 1 1)
hex (1 4 3 2 7 10 9 8) (30 15 30) simpleGrading (1 1 1) //edgeGrading (10 10 10 10 10 10 10 10 10 10 10 10)
patches
wall Walls
(6 11 10 7)
(7 10 9 8)
(0 1 4 5 )
(1 2 3 4 )
patch Inlet
(0 5 11 6)
patch Outlet
(2 8 9 3)
empty back
(0 6 7 1)
(1 7 8 2)
empty front
(5 4 10 11)
(3 9 10 4)
edges
mergePatchPairs
but when the checkMesh is run it gives the following error
upuli@upuli-To-be-filled-by-O-E-M:~/C/practicalcorrectdim$ checkMesh
| \\ / O peration | Version: 4.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 4.1
Exec : checkMesh
Date : Jul 31 2017
Time : 09:24:55
Host : "upuli-To-be-filled-by-O-E-M"
PID : 3837
Case : /home/upuli/C/practicalcorrectdim
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 83700
internal faces: 78300
cells: 27000
faces per cell: 6
boundary patches: 5
point zones: 0
face zones: 0
cell zones: 0
Overall number of cells of each type:
hexahedra: 27000
prisms: 0
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 0
polyhedra: 0
Checking topology...
Boundary definition OK.
***Total number of faces on empty patches is not divisible by the number of cells in the mesh. Hence this mesh is not 1D or 2D.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces...
Patch Faces Points Surface topology
Walls 1800 1922 ok (non-closed singly connected)
Inlet 900 961 ok (non-closed singly connected)
Outlet 900 961 ok (non-closed singly connected)
back 900 961 ok (non-closed singly connected)
front 900 961 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-0.15 -0.15 -0.005) (0.15 0.45 0.005)
Mesh has 2 geometric (non-empty/wedge) directions (1 1 0)
Mesh has 2 solution (non-empty) directions (1 1 0)
All edges aligned with or perpendicular to non-empty directions.
Boundary openness (3.62619e-17 2.02015e-17 -6.50659e-15) OK.
Max cell openness = 2.17808e-16 OK.
Max aspect ratio = 5.29412 OK.
Minimum face area = 1.11111e-06. Maximum face area = 0.0002. Face area magnitudes OK.
***Zero or negative cell volume detected. Minimum negative volume: -6.66667e-08, Number of negative volume cells: 27000
<<Writing 27000 zero volume cells to set zeroVolumeCells
Mesh non-orthogonality Max: 180 average: 173.91
***Number of non-orthogonality errors: 78300.
<<Writing 78300 non-orthogonal faces to set nonOrthoFaces
***Error in face pyramids: 162000 faces are incorrectly oriented.
<<Writing 83700 faces with incorrect orientation to set wrongOrientedFaces
Max skewness = 0.805556 OK.
Coupled point location match (average 0) OK.
Failed 3 mesh checks.
End
I have attached the paraFoam file also.
Colud you please help me to solve the error
upuli is offline   Reply With Quote
Old   July 31, 2017, 23:12
Antimony is on a distinguished road
Quite possible that it your cells are twisted inside out leading to negative volume cells.
Check the log file of blockMesh. That will indicate to you the cells/faces that are twisted.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   August 1, 2017, 00:52
Upuli
Hi
There are list of Non orthogonal faces,Wrong oriented faces and zero volume cells ,how can I correct that.
Thanking you
rgds
Upuli
Old   August 1, 2017, 05:15
Yes, that is what I mentioned when I said twisted inside-out cells will be clear when you look at the log.
Essentially you need to change the order of your vertices in the definition of a block. It should be
hex (0 1 4 5 6 7 10 11) (30 15 30) simpleGrading (1 1 1)
hex (1 2 3 4 7 8 9 10) (30 15 30) simpleGrading (1 1 1)
instead of:
Cheers,
Antimony
siamak 60 likes this.
Old   August 1, 2017, 06:27
Upuli
Dear Antimony
Thank you very much for your prompt reply. I solved it according to your answer.
rgds
upuli
Old   August 8, 2017, 03:36
Upuli
Dear members
Now the mesh is OK. The checkMesh is OK.But when I run the solver it stopped after 0.06 seconds.Following is the error message.
Time = 0.06
Courant Number mean: 0.001 max: 0.05
diagonal: Solving for flametime, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.114397, No Iterations 1000
smoothSolver: Solving for Uy, Initial residual = 0.999999, Final residual = 0.00789023, No Iterations 1000
DICPCG: Solving for p, Initial residual = 1, Final residual = 8.17288e-07, No Iterations 224
time step continuity errors : sum local = 0.002, global = -0.002, cumulative = -0.022
DICPCG: Solving for p, Initial residual = 0.225934, Final residual = 9.2511e-07, No Iterations 208
time step continuity errors : sum local = 0.002, global = -0.002, cumulative = -0.024
DILUPBiCG: Solving for k, Initial residual = 5.3731e-07, Final residual = 5.3731e-07, No Iterations 0
DILUPBiCG: Solving for epsilon, Initial residual = 1.19655e-06, Final residual = 4.49407e-07, No Iterations 1
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#5 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#6 Foam::fvMatrix<double>::solve(Foam::dictionary const&) at ??:?
#7 Foam::fvMatrix<double>::solve() at ??:?
#8 ? at ??:?
#9 ? at ??:?
#10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#11 ? at ??:?
Floating point exception (core dumped)
Reducing velocity or the time step didn't help. The solver works well with mesh of box like geometry.How can I solve the problem.
rgds Upuli
Old   February 19, 2018, 02:45
Default Solver doesnot works after mesh changed
Upuli
I have ran a customized solver in the following mesh and it worked well.convertToMeters 1.0;
vertices
(0.15 0.3 -0.15)
(0.15 -0.3 -0.15)
(-0.15 -0.3 -0.15)
(-0.15 0.3 -0.15)
(0.15 0.3 0.15)
(0.15 -0.3 0.15)
(-0.15 -0.3 0.15)
(-0.15 0.3 0.15)
blocks
hex (4 5 6 7 0 1 2 3) (30 60 1) simpleGrading (1 1 1) //edgeGrading (10 10 10 10 10 10 10 10 10 10 10 10)
patches
wall Walls
(0 4 5 1)
(2 6 7 3)
patch Inlet
(1 5 6 2)
patch Outlet
(4 0 3 7)
empty back
(0 1 2 3)
empty front
(4 7 6 5)
edges
mergePatchPairs
but when I changed the mesh to following the solver stops at 0.02S (the initial time step )
vertices
(-0.15 -0.15 -0.15) //0
(-0.15 0.15 -0.15)
(-0.05 0.45 -0.15)
(-0.05 0.45 0.15)
(-0.15 0.15 0.15)
(-0.15 -0.15 0.15)
(0.15 -0.15 -0.15)
(0.15 0.15 -0.15)
(0.05 0.45 -0.15)
(0.05 0.45 0.15)
(0.15 0.15 0.15)
(0.15 -0.15 0.15)
blocks
hex (0 1 4 5 6 7 10 11) (30 30 1) simpleGrading (4 4 1)
hex (1 2 3 4 7 8 9 10) (60 30 1) edgeGrading (4 4 4 4 4 4 4 4 1 1 1 1)
patches
wall Walls
(6 11 10 7)
(7 10 9 8)
(0 1 4 5 )
(1 2 3 4 )
patch Inlet
(0 5 11 6)
patch Outlet
(2 8 9 3)
empty back
(0 6 7 1)
(1 7 8 2)
empty front
(5 4 10 11)
(3 9 10 4)
edges
mergePatchPairs
can some one help me to get rid of the problem. changing time step did not work.
thanks
Old   February 19, 2018, 06:10
You will need to provide more information - what do you mean the run stopped? Did it crash? Do you have a log of your run? What are your BC?
Don't forget to use code blocks if you paste them directly! Really helps others to have a quick look at your case.
Cheers,
Antimony
Old   February 20, 2018, 23:28
Upuli
The case is a combustion of solid fuels. The air is sent from the inlet and exits at the outlet. I checked the case removing the combustion of fuel and just sending air through the reactor. But the following error message appear.
Time = 0.02
Courant Number mean: 0.0024 max: 0.261077
smoothSolver:  Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0
smoothSolver:  Solving for Uy, Initial residual = 1, Final residual = 2.48371e-18, No Iterations 1
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#3  Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&) at ??:?
#4  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::dimensioned<double> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#5  ? at ??:?
#6  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#7  ? at ??:?
Following are the boundary conditions for U and pressure
U
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    Walls
        type            fixedValue;
        value           uniform (0 0 0);
    Inlet
        type            fixedValue;
        value           uniform (0 0.12 0);
    Outlet
        type            inletOutlet;
        //type            zeroGradient;
      inletValue      uniform (0 0 0);
    back
        type            empty;
    front
        type            empty;
Pressure
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 1;
boundaryField
    wall
        type            zeroGradient;
    Outlet
        type            fixedValue;
        value           uniform 1;
    Inlet
        type            zeroGradient;
    "front.*"
        type            empty;
    "back.*"
        type            empty;
Old   February 21, 2018, 01:08
Upuli
Hi
I found the reason for the error. There is field which was set to zero inside the reactor.
After setting it to the correct value the solver is running in the case.
Thank you for your prompt reply.
rgds
Upuli
Old   July 19, 2018, 03:50
Upuli
Hi
I want some help again. In the above mesh I use to use velocity in the inlet to be set to 0.12 in the Y direction so I used the following boundary conditions. other velocities are zero. But in Paraview a different value is shown as the inlet velocity(0.00539 ms-1). How can I solve this?
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
boundaryField
Walls
type fixedValue;
Inlet
type fixedValue;
Outlet
type inletOutlet;
back
type empty;
front
type empty;
File Type: png Screenshot from 2018-07-19 12-16-10 -2.png (12.2 KB, 7 views)
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 10:31
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
