[blockMesh] Merging multiple blocks of diferent mesh density. |
July 7, 2017, 20:27 |
Tom
Rep Power: 9 |
Hello all,
I'm trying to set up the following geometry in with blockMesh: Where the light blue area represents a coarse mesh, and the darker blue a fine mesh. The simplest way to do it would be to simply use face matching to ensure the rough sections is all connected, but then using mergePatchPairs to connect the three inner faces of the fine section won't work because of adjacency. Merging the top and bottom boxes into the center box and then using merging the left rough box into that combined box doesn't work either because it creates faces with less then 3 points. Can anyone suggest a work around? I've also heard people suggesting connecting such a geometry with cyclical boundaries - but doesn't that only work with meshes of the same density? |
July 15, 2017, 14:04 |
#2 | |
Tom
Rep Power: 9 |
CyclicAMI seems to actually be my best bet, but I'm not sure how to use it. Below is my best guess based on checking several threads here on CFD Online and the OpenFOAM user guide.
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // convertToMeters 0.1; vertices ( //left rough 'c' box //back plane (0 0 0)//0 (180 0 0)//1 (260 0 0)//2 (260 90 0)//3 (180 90 0)//4 (180 170 0)//5 (260 170 0)//6 (260 260 0)//7 (180 260 0)//8 (0 260 0)//9 //front plane (0 0 20)//10 (180 0 20)//11 (260 0 20)//12 (260 90 20)//13 (180 90 20)//14 (180 170 20)//15 (260 170 20)//16 (260 260 20)//17 (180 260 20)//18 (0 260 20)//19 //left center box //back plane (180 90 0)//20 (260 90 0)//21 (260 170 0)//22 (180 170 0)//23 //front plane (180 90 20)//24 (260 90 20)//25 (260 170 20)//26 (180 170 20)//27 ); blocks ( hex (0 1 8 9 10 11 18 19) (18 26 20) simpleGrading (1 1 1)//left rough box hex (1 2 3 4 11 12 13 14) (8 9 20) simpleGrading (1 1 1)//left bottom box hex (20 21 22 23 24 25 26 27) (16 160 20) simpleGrading (1 1 1)//left center box, note doubled mesh density hex (5 6 7 8 15 16 17 18) (8 9 20) simpleGrading (1 1 1)//left top box ); edges ( ); boundary ( inlet { type patch; faces ( (10 11 18 19)//left rough box (11 12 13 14)//left bottom box (24 25 26 27)//left center box (15 16 17 18)//left top box ); } outlet { type patch; faces ( (0 1 8 9)//left rough box (1 2 3 4)//left bottom box (20 21 22 23)//left center box (5 6 7 8)//left top box ); } fixedWalls { type wall; faces ( //left rough box (0 1 11 10)//bottom (0 10 19 9)//left wall (8 9 19 18)//top //left bottom box (1 2 12 11)//bottom (2 3 13 12)//right //left center box (21 22 26 25)//right //left top box (8 18 17 7)//top (6 7 17 16)//right ); } //use the Arbitray Mesh Interface next //********************* inTopInterface { type cyclicAMI; neighborPatch outTopInterface; faces ( (22 23 27 26)// ); } outTopInterface// { type cyclicAMI; neighborPatch inTopInterface; faces ( (5 6 16 15)// ); } //********************* outBottomInterface { type cyclicAMI; neighborPatch inBottomInterface; faces ( (3 4 14 13)// ); } inBottomInterface { type cyclicAMI; neighborPatch outBottomInterface; faces ( (20 21 25 24)// ); } //********************* leftRightInterface { type cyclicAMI; neighborPatch rightLeftInterface; faces ( (1 8 18 11)// ); } rightLeftInterface { type cyclicAMI; neighborPatch leftRightInterface; faces ( (20 24 27 23)// ); } ); // ************************************************************************* // Quote:
July 18, 2017, 22:28 |
Rep Power: 16 |
Seems to me that it is a simple issue with your spelling. neighbourPatch uses the British spelling, while you have used the American spelling. Cheers, Antimony |
July 19, 2017, 09:29 |
Tom
Rep Power: 9 |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 04:17 |
[Other] Multiple blocks for moving mesh | jiahui_93 | OpenFOAM Meshing & Mesh Conversion | 0 | March 4, 2018 02:24 |
[ICEM] meshing-incomplete mesh in part after moving blocks to separate domains | Mfaizan | ANSYS Meshing & Geometry | 8 | November 29, 2015 21:11 |
