[Other] fe40 surfaceConvert Segmentation Fault (core dumped) |
May 17, 2017, 07:59 |
#1 | |
raju ram bhakar
Rep Power: 9 |
I'm facing problem in converting .stl file to .ftr format using surfaceConvert 2.stl 2.ftr Reason for conversion : refineImmersedBoundaryMesh need .ftr file to refine the mesh.(If you can tell me a way where I don't need the ftr file that will also do) Error : Segmentation fault (core dumped) At the time of compiling the fe40 for every other utility the results were shown as name_of_the_library is up to date but for only surfaceConvert I got this message Quote:
August 31, 2018, 12:05 |
#2 | ||
Emre
Rep Power: 11 |
foam-extend 3.2 gives me same issue on Ubuntu 16.04 LTS. I succeeded 1 year ago on a different machine/OS with same configuration today. It is too weird. Quote:
Last edited by ordinary; August 31, 2018 at 19:27. Reason: I also tried this issue on foam-extend 4.0 |
June 16, 2019, 12:04 |
Sujay
Rep Power: 8 |
I'm facing the same issue with fe40. Anyone found the solution to this?
I'm trying to follow an immersed boundary tutorial, so not really sure of how this ftr file is utilised. Is there any way to overcome this or just use stl instead? |
[OpenFOAM] paraview parafoam segmentation fault (core dumped) | RicardoLB | ParaView | 3 | April 28, 2020 21:07 |
[OpenFOAM.org] Paraview 5.4 in shell environment of5x - Segmentation fault (core dumped) | dslbkxd | OpenFOAM Installation | 1 | February 3, 2018 01:56 |
Segmentation fault (core dumped) | Sugajen | OpenFOAM Running, Solving & CFD | 1 | August 2, 2017 13:06 |
Segmentation fault (core dumped) | zhoubiao1088 | OpenFOAM Running, Solving & CFD | 4 | March 13, 2017 21:06 |
Segmentation fault (core dumped) when changing pressure BC | jptorol | OpenFOAM Running, Solving & CFD | 0 | September 25, 2013 19:05 |
