[blockMesh] Segmentation Fault when creating block mesh topography (blockMesh)
Like Tree1Likes
  • 1 Post By Antimony
Old   May 10, 2017, 23:27
Default Segmentation Fault when creating block mesh topography (blockMesh)
Jess
jbrydg01 is on a distinguished road
Hello!
I'm very new to openFoam, so in advance I appreciate any help and information that can be provided!
I'm trying to mesh a thin, flat rectangular plate in a boundary to simulate the flow around this plate. At this point, I'm simply trying to run the blockMesh utility, taking on step at a time, but have been encountering the following message that doesn't mean much to me:
Create time
Creating block mesh from
"/home/jbrydg01/OpenFOAM/jbrydg01-4.1/run/thesis/validate/AR1.6/system/blockMeshDict"
Creating curved edges
Creating topology blocks
Creating topology patches
Creating block mesh topology
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigSegv::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 Foam::face::centre(Foam::Field<Foam::Vector<double > > const&) const at ??:?
#4 Foam::cellModel::mag(Foam::List<int> const&, Foam::Field<Foam::Vector<double> > const&) const at ??:?
#5 Foam::blockMesh::createCellShapes(Foam::List<Foam: :cellShape>&) at ??:?
#6 Foam::blockMesh::createTopology(Foam::IOdictionary const&, Foam::word const&) at ??:?
#7 Foam::blockMesh::blockMesh(Foam::IOdictionary const&, Foam::word const&) at ??:?
#8 ? at ??:?
#9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#10 ? at ??:?
Segmentation fault (core dumped)
I've attached a copy of my blockMeshdict file to help troubleshoot. I've taken a number of looks through the syntax, and have paid careful attention to the ordering of the vertices to ensure the clockwise orientation from the inside perspective. A concern I have is that I have defined my plate as a wall without providing mesh information under blocks (see blockMesh file commentary).
Thanks for any help in advance! I really appreciate any feedback!
Jesse
jbrydg01 is offline   Reply With Quote
Old   May 11, 2017, 03:26
Antimony is on a distinguished road
Your block definition contains fewer than 8 vertices. Even if you are creating wedges or the like, you still need to have 8 vertices in the definition of the hex block.
Cheers,
Antimony
KaLium likes this.
Antimony is offline   Reply With Quote
Old   May 11, 2017, 06:37
Jess
Thanks Antimony! It seems to have resolved that issue!
Jesse
[snappyHexMesh] Creating very fine, high accuracy mesh with snappyHexMesh JD_Welch OpenFOAM Meshing & Mesh Conversion 10 July 5, 2023 12:50
[mesh manipulation] How to write cellSet for different regions in constant/polyMesh/sets Struggle_Achieve OpenFOAM Meshing & Mesh Conversion 3 June 17, 2019 10:29
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[Commercial meshers] Icem Mesh to Foam jphandrigan OpenFOAM Meshing & Mesh Conversion 4 March 9, 2010 03:58
blockMesh: block with 6 vertexes dani OpenFOAM 3 June 25, 2009 14:13
