[snappyHexMesh] snappyHexMesh and checkMesh - different definitions of skewness
Like Tree1Likes
  • 1 Post By cibanez
Old   May 9, 2017, 09:21
Default snappyHexMesh and checkMesh - different definitions of skewness
Yuehan
wc34071209 is on a distinguished road
Hi everybody,
It seems that snappyHexMesh and checkMesh calculate face skewness in a different way.
snappyHexMesh output
Checking final mesh ...
Checking faces in error :
    non-orthogonality > 80  degrees                        : 0
    faces with face pyramid volume < 1e-30                 : 0
    faces with concavity > 80  degrees                     : 0
    faces with skewness > 4   (internal) or 20  (boundary) : 0
    faces with interpolation weights (0..1)  < 0.005       : 0
    faces with volume ratio of neighbour cells < 0.001     : 0
    faces with face twist < 0.001                          : 152
    faces on cells with determinant < 0.0001                : 54
Finished meshing with 206 illegal faces (concave, zero area or negative cell pyramid volume)
Finished meshing in = 98.52 s.
End
checkMesh output
Checking geometry...
    Overall domain bounding box (-0.600453913 -0.000453508017 -6.17837081e-08) (0.60016445 2.4400002 2.46000011)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (-1.48156865e-16 8.02340479e-17 -2.54456316e-16) OK.
    Max cell openness = 3.16296583e-16 OK.
    Max aspect ratio = 26.777507 OK.
    Minimum face area = 3.60752727e-08. Maximum face area = 0.00704660078.  Face area magnitudes OK.
    Min volume = 1.40396368e-10. Max volume = 0.000584855605.  Total volume = 7.1436757.  Cell volumes OK.
    Mesh non-orthogonality Max: 79.940617 average: 12.8038228
   *Number of severely non-orthogonal (> 70 degrees) faces: 329.
    Non-orthogonality check OK.
  <<Writing 329 non-orthogonal faces to set nonOrthoFaces
    Face pyramids OK.
 ***Max skewness = 4.39520581, 1 highly skew faces detected which may impair the quality of the results
  <<Writing 1 skew faces to set skewFaces
    Coupled point location match (average 0) OK.
Failed 1 mesh checks.
End
wc34071209 is offline   Reply With Quote
Old   May 9, 2017, 11:00
akidess's Avatar
Anton Kidess
I'm guessing the skew face that snappyHexMesh reports lies on the boundary.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
Old   May 10, 2017, 05:36
Yuehan
Yes, you are right. But do you know why this happens?
Old   August 30, 2023, 06:12
Cristóbal
cibanez is on a distinguished road
It happens because when checkMesh checks for face skewness it only uses one threshold value to issue the warning. That is skewThreshold_ = 4, which is hardcoded.
You can take a look at https://develop.openfoam.com/Develop...eck.C#L565-630 to see that checkMesh doesn't distinguish between internal or boundary faces to write out the warning. At the beginning of this file you will also find the hardcoded variables used as threshold values. For instance it can be seen that nonOrthThreshold_ = 70 degrees for non-orthogonality.
It could then be a good practice to lower maxBoundarySkewness in your meshQualityDict to 4 when creating the mesh with SHM to be sure to avoid checkMesh warnings.
rmaries likes this.
cibanez is offline   Reply With Quote
[snappyHexMesh] error checkMesh after run snappyHexMesh Hemmati OpenFOAM Meshing & Mesh Conversion 5 November 20, 2016 03:42
[snappyHexMesh] Able to run snappyHexMesh in parallel on local machine but unable to run on linux clu abhinav2601 OpenFOAM Meshing & Mesh Conversion 1 January 26, 2015 06:42
[mesh manipulation] checkMesh Erros after refineMesh mgdenno OpenFOAM Meshing & Mesh Conversion 10 October 14, 2014 06:16
checkMesh Errors after refineMesh mgdenno OpenFOAM 0 July 30, 2012 22:39
[snappyHexMesh] snappyHexMesh not snapping perfectly to surface and failing checkMesh Greg Givogue OpenFOAM Meshing & Mesh Conversion 5 February 28, 2011 12:43
