[snappyHexMesh] Edge Refinement
Like Tree1Likes
  • 1 Post By fracasce
Old   May 5, 2017, 18:12
Default Edge Refinement
Franco
fracasce is on a distinguished road
Hi foamers,
I'm having hard times with SHM and extrudeMess, since I'm trying to create a 2D mesh from SHM with extrudeMesh. The mesh is fine (I don't get any error with checkMesh), however, the refinement seems not to work on the edges. As you can see from the images, there are some very sharp edges at the four corner of the mash. I improved the feature level, but I can't get rid of the problem. I'm quite sure that there is a problem with the introduction of the viscous layers (when the layers are not added, I don't get this error), however, I can't understand which parameter I should change in addLayersControls (I tried with featureAngle, without success). Could you please help me?
Thanks a lot!!
Franco
|  \\    /   O peration     | Version:  4.1                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap            true;
addLayers       true;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
    Air.stl
        type    triSurfaceMesh;
        name    Air;
    Base1.stl
        name    Base1;
    Base2.stl
        name    Base2;
    Base3.stl
        name    Base3;
    Base4.stl
        name    Base4;
    Base5.stl
        name    Base5;
    Bottom.stl
        name    Bottom;
    Left.stl
        name    Left;
    Outlet.stl
        name    Outlet;
    RCF1.stl
        name    RCF1;
    RCF2.stl
        name    RCF2;
    RCF3.stl
        name    RCF3;
    RCF4.stl
        name    RCF4;
    Right.stl
        name    Right;
    Top.stl
        name    Top;
    refinementBox
        type    searchableBox;
        min     (0.05 0    0);
        max     (0.64 0.15 0.01);
// Settings for the castellatedMesh generation.
castellatedMeshControls
    // Refinement parameters
    // If local number of cells is >= maxLocalCells on any processor
    // switches from from refinement followed by balancing
    // (current method) to (weighted) balancing before refinement.
    maxLocalCells 100000;
    // Overall cell limit (approximately). Refinement will stop immediately
    // upon reaching this number so a refinement level might not complete.
    // Note that this is the number of cells before removing the part which
    // is not 'visible' from the keepPoint. The final number of cells might
    // actually be a lot less.
    maxGlobalCells 2000000;
    // The surface refinement loop might spend lots of iterations refining just
    // a few cells. This setting will cause refinement to stop if <=
    // minimumRefine are selected for refinement. Note: it will at least do one
    // iteration (unless the number of cells to refine is 0)
    minRefinementCells 10;
    // Number of buffer layers between different levels.
    // 1 means normal 2:1 refinement restriction, larger means slower
    // refinement.
    nCellsBetweenLevels 1;
    //maxLoadUnbalance 0.10;
    // Explicit feature edge refinement
    // Specifies a level for any cell intersected by its edges.
    // This is a featureEdgeMesh, read from constant/triSurface for now.
    features (
        {file "Base1.eMesh"; level 5;}
        {file "Base2.eMesh"; level 5;}
        {file "Base3.eMesh"; level 5;}
        {file "Base4.eMesh"; level 5;}
        {file "Base5.eMesh"; level 5;}
        {file "Bottom.eMesh"; level 5;}
        {file "Left.eMesh"; level 5;}
        {file "Outlet.eMesh"; level 5;}
        {file "RCF1.eMesh"; level 5;}
        {file "RCF2.eMesh"; level 5;}
        {file "RCF3.eMesh"; level 5;}
        {file "RCF4.eMesh"; level 5;}
        {file "Right.eMesh"; level 5;}
        {file "Top.eMesh"; level 5;}
    // Surface based refinement
    // Specifies two levels for every surface. The first is the minimum level,
    // every cell intersecting a surface gets refined up to the minimum level.
    // The second level is the maximum level. Cells that 'see' multiple
    // intersections where the intersections make an
    // angle > resolveFeatureAngle get refined up to the maximum level.
    refinementSurfaces
        Base1
            // Surface-wise min and max refinement level
            level (4 5);
        Base2
            level (4 5);
        Base3
            level (4 5);
        Base4
            level (4 5);
        Base5
            level (4 5);
        Bottom
            level (4 5);
        Outlet
            level (4 5);
        Top
            level (4 5);
        Left
            level (5 5);
        Right
            level (5 5);
        RCF1
            level (5 6);
        RCF2
            level (5 6);
        RCF3
            level (5 6);
        RCF4
            level (5 6);
    // Resolve sharp angles on fridges
    resolveFeatureAngle 30; //was 30
    // Region-wise refinement
    // Specifies refinement level for cells in relation to a surface. One of
    // three modes
    // - distance. 'levels' specifies per distance to the surface the
    //   wanted refinement level. The distances need to be specified in
    //   descending order.
    // - inside. 'levels' is only one entry and only the level is used. All
    //   cells inside the surface get refined up to the level. The surface
    //   needs to be closed for this to be possible.
    // - outside. Same but cells outside.
    refinementRegions
        Air
            mode inside;
            levels ((1e15 5));
        /*refinementBox
        //Air
            mode inside;
            levels ((1e15 5));
    // Mesh selection
    // After refinement patches get added for all refinementSurfaces and
    // all cells intersecting the surfaces get put into these patches. The
    // section reachable from the locationInMesh is kept.
    // NOTE: This point should never be on a face, always inside a cell, even
    // after refinement.
    locationInMesh (0.1 0.1 0.005);
    // Whether any faceZones (as specified in the refinementSurfaces)
    // are only on the boundary of corresponding cellZones or also allow
    // free-standing zone faces. Not used if there are no faceZones.
    allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
    //- Number of patch smoothing iterations before finding correspondence
    //  to surface
    nSmoothPatch 3;
    //- Relative distance for points to be attracted by surface feature point
    //  or edge. True distance is this factor times local
    //  maximum edge length.
    tolerance 2.0;
    //- Number of mesh displacement relaxation iterations.
    nSolveIter 300;
    //- Maximum number of snapping relaxation iterations. Should stop
    //  before upon reaching a correct mesh.
    nRelaxIter 5;
    nFeatureSnapIter 15; // default is 10
// Settings for the layer addition.
addLayersControls
    // Are the thickness parameters below relative to the undistorted
    // size of the refined cell outside layer (true) or absolute sizes (false).
    relativeSizes true;
    // Per final patch (so not geometry!) the layer information
    layers
        Left
            nSurfaceLayers 3;
        Right
            nSurfaceLayers 3;
        Base1
            nSurfaceLayers 3;
        Base2
            nSurfaceLayers 3;
        Base3
            nSurfaceLayers 3;
        Base4
            nSurfaceLayers 3;
        Base5
            nSurfaceLayers 3;
    // Expansion factor for layer mesh
    expansionRatio 1.15;
    // Wanted thickness of final added cell layer. If multiple layers
    // is the thickness of the layer furthest away from the wall.
    // Relative to undistorted size of cell outside layer.
    // See relativeSizes parameter.
    finalLayerThickness 0.4;
    // Minimum thickness of cell layer. If for any reason layer
    // cannot be above minThickness do not add layer.
    minThickness 0.2;
    // If points get not extruded do nGrow layers of connected faces that are
    // also not grown. This helps convergence of the layer addition process
    // close to features.
    // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x)
    nGrow 0;
    // Advanced settings
    // When not to extrude surface. 0 is flat surface, 90 is when two faces
    // are perpendicular
    featureAngle 30; // was 60
    // Maximum number of snapping relaxation iterations. Should stop
    nRelaxIter 5;
    // Number of smoothing iterations of surface normals
    nSmoothSurfaceNormals 1;
    // Number of smoothing iterations of interior mesh movement direction
    nSmoothNormals 3;
    // Smooth layer thickness over surface patches
    nSmoothThickness 10;
    // Stop layer growth on highly warped cells
    maxFaceThicknessRatio 0.5;
    // Reduce layer growth where ratio thickness to medial
    // distance is large
    maxThicknessToMedialRatio 0.3;
    // Angle used to pick up medial axis points
    // Note: changed(corrected) w.r.t 16x! 90 degrees corresponds to 130 in 16x.
    minMedianAxisAngle 80; //was 90
    // Create buffer region for new layer terminations
    nBufferCellsNoExtrude 0;
    // Overall max number of layer addition iterations. The mesher will exit
    // if it reaches this number of iterations; possibly with an illegal
    // mesh.
    nLayerIter 50;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
    //- Maximum non-orthogonality allowed. Set to 180 to disable.
    maxNonOrtho 65;
    //- Max skewness allowed. Set to <0 to disable.
    maxBoundarySkewness 20;
    maxInternalSkewness 4;
    //- Max concaveness allowed. Is angle (in degrees) below which concavity
    //  is allowed. 0 is straight face, <0 would be convex face.
    //  Set to 180 to disable.
    maxConcave 80;
    //- Minimum pyramid volume. Is absolute volume of cell pyramid.
    //  Set to a sensible fraction of the smallest cell volume expected.
    //  Set to very negative number (e.g. -1E30) to disable.
    minVol 1e-13;
    //- Minimum quality of the tet formed by the face-centre
    //  and variable base point minimum decomposition triangles and
    //  the cell centre.  Set to very negative number (e.g. -1E30) to
    //  disable.
    //     <0 = inside out tet,
    //      0 = flat tet
    //      1 = regular tet
    minTetQuality 1e-30;
    //- Minimum face area. Set to <0 to disable.
    minArea -1;
    //- Minimum face twist. Set to <-1 to disable. dot product of face normal
    //  and face centre triangles normal
    minTwist 0.05;
    //- Minimum normalised cell determinant
    //  1 = hex, <= 0 = folded or flattened illegal cell
    minDeterminant 0.001;
    //- minFaceWeight (0 -> 0.5)
    minFaceWeight 0.05;
    //- minVolRatio (0 -> 1)
    minVolRatio 0.01;
    //must be >0 for Fluent compatibility
    minTriangleTwist -1;
    // Advanced
    //- Number of error distribution iterations
    nSmoothScale 4;
    //- Amount to scale back displacement at error points
    errorReduction 0.75;
// Advanced
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1e-6;
fracasce is offline   Reply With Quote
Old   May 6, 2017, 18:18
Franco
The problemhas been quickly solved by changing the factors in the snapcontroldict.
BTW, the introduction of the viscous layers does not affect the sharp edges shown in the figures (when addlayers is false, the sharp edges do not go way).
davcrisp likes this.
Old   December 2, 2017, 08:07
Deep
deepbandivadekar is on a distinguished road
This looks interesting. I am facing the exact same problem with SHM. Could you discuss more about what factors you changed? Perhaps, share your new shm dict ?
deepbandivadekar is offline   Reply With Quote
Old   December 2, 2017, 14:30
Franco
Dear Deep,
Unfortunately I'm not working anymore on this case and I do not remember which of the four factors I changed: I think it was tolerance or nSolveIter, but its a guess.
If that does not work, I would consider changing the size of the blocks in the blockMeshDict file (I would decrease their size and defining a low level of refinement for the surfaces, edges...).
Hope It helps,
Franco
extrude mesh, extrude2dmesh 2d mesh, snapphhexmesh
[snappyHexMesh] SnappyHexMesh running killed! Mark JIN OpenFOAM Meshing & Mesh Conversion 7 June 14, 2022 02:37
killed "snappyHexMesh" parkh32 OpenFOAM Pre-Processing 2 April 8, 2012 18:12
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
