[snappyHexMesh] Collapsing layers
Like Tree2Likes
  • 2 Post By john myce
Old   March 27, 2017, 10:56
Default Collapsing layers
RomCFD is on a distinguished road
Hi everyone !
I am quite new working with SHM and I'm facing issues at adding layers step.
I have tried different combinations of parameters in snappyHexMeshDict, but I can't managed to obtain my surface fully covered by layers, even with simple shapes. Most of the time, I can't go further than 80% and in this case around 60% :
patch        faces    layers   overall thickness
                               [m]       [%]
wall_fluide  117651   3.53     1.1       64.7
wall_inlet   9291     2.78     0.727     64.1
wall_outlet1 8674     2.03     0.574     54.4
wall_outlet2 7822     2.51     0.654     61
wall_outlet3 8655     2.05     0.574     54.9
You can see in pictures attached an example of my issue : the 1st one is after snapping, the 2nd one is after addLayers step and the last one is the general shape of my domain.
Has anybody already met this problem with snappy ?
Thank you in advance !
Here is my snappyHexMeshDict :
|  \\    /   O peration     | Version:  4.1                                |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap            true;
addLayers       true;
geometry
//CellZones
    Entree.stl
        type triSurfaceMesh;
        name Entree;
    Sortie1.stl
        name Sortie1;
    Sortie2.stl
        name Sortie2;
    Sortie3.stl
        name Sortie3;
    Fluide.stl
        name Fluide;
//Conditions limites
    inlet.stl
        name  inlet;
    outlet1.stl
        name  outlet1;
    outlet2.stl
        name  outlet2;
    outlet3.stl
        name  outlet3;
    wall_fluide.stl
        name  wall_fluide;
    wall_inlet.stl
        name  wall_inlet;
    wall_outlet1.stl
        name  wall_outlet1;
    wall_outlet2.stl
        name  wall_outlet2;
    wall_outlet3.stl
        name  wall_outlet3;
castellatedMeshControls
    // Refinement parameters
    maxGlobalCells           12000000 ;
    maxLocalCells           4000000 ;
    minRefinementCells      10 ;
    maxLoadUnbalance        0.10 ;
    nCellsBetweenLevels      2 ;
    // Explicit feature edge refinement
    features
            file "inlet.eMesh" ;
            level  3 ;
            file "outlet1.eMesh" ;
            level  3 ;
            file "outlet2.eMesh" ;
            level  3 ;
            file "outlet3.eMesh" ;
            level  3 ;
            file "wall_fluide.eMesh" ;
            level  3 ;
            file "wall_inlet.eMesh" ;
            level  3 ;
            file "wall_outlet1.eMesh" ;
            level  3 ;
            file "wall_outlet2.eMesh" ;
            level  3 ;
            file "wall_outlet3.eMesh" ;
            level  3 ;
    // Surface based refinement
    refinementSurfaces
        inlet
            level ( 0  1 );
            patchInfo
            { type patch; }
        outlet1
            level ( 0  1 );
            patchInfo
            { type patch; }
        outlet2
            level ( 0  1 );
            patchInfo
            { type patch; }
        outlet3
            level ( 0  1 );
            patchInfo
            { type patch; }
        wall_fluide
            level ( 0  2 );
            patchInfo
            { type wall; }
        wall_inlet
            level ( 0  2 );
            patchInfo
            { type wall; }
        wall_outlet1
            level ( 0  2 );
            patchInfo
            { type wall; }
        wall_outlet2
            level ( 0  2 );
            patchInfo
            { type wall; }
        wall_outlet3
            level ( 0  2 );
            patchInfo
            { type wall; }
        Entree
            level (0 0);
            faceZone        Entree;
            cellZone        Entree;
            zone inside true;
        Sortie1
            level (0 0);
            faceZone        Sortie1;
            cellZone        Sortie1;
            zone inside true;
        Sortie2
            level (0 0);
            faceZone        Sortie2;
            cellZone        Sortie2;
            zone inside true;
        Sortie3
            level (0 0);
            faceZone        Sortie3;
            cellZone        Sortie3;
            zone inside true;
        Fluide
            level (0 0);
            faceZone        Fluide;
            cellZone        Fluide;
            zone inside true;
    // Feature angle:
    resolveFeatureAngle      30 ;
    //- Optional increment (on top of max level) in small gaps
    //gapLevelIncrement 2;
    planarAngle 30;
    // Region-wise refinement
    refinementRegions
    // Mesh selection
    locationInMesh ( 0  0  0 );
    allowFreeStandingZoneFaces true;
    // Optional: do not remove cells likely to give snapping problems
    // handleSnapProblems false;
    // Optional: switch off topological test for cells to-be-squashed
    //           and use geometric test instead
    //useTopologicalSnapDetection false;
snapControls
    nSmoothPatch 3;
    tolerance 1.0;
    // Number of mesh displacement relaxation iterations.
    nSolveIter 300;
    // Maximum number of snapping relaxation iterations. Should stop
    // before upon reaching a correct mesh.
    nRelaxIter 5;
    // Feature snapping
        nFeatureSnapIter 10;
        // Detect (geometric only) features by sampling the surface
        // (default=false).
        implicitFeatureSnap false;
        // Use castellatedMeshControls::features (default = true)
        explicitFeatureSnap true;
        // Detect features between multiple surfaces
        // (only for explicitFeatureSnap, default = false)
        multiRegionFeatureSnap false;
    // wip: disable snapping to opposite near surfaces (revert to 22x behaviour)
    // detectNearSurfacesSnap false;
addLayersControls
    // Are the thickness parameters below relative to the undistorted
    // size of the refined cell outside layer (true) or absolute sizes (false).
    relativeSizes true;
        // Expansion factor for layer mesh
        expansionRatio      1.2;
        // Wanted thickness of the layer furthest away from the wall.
        // If relativeSizes this is relative to undistorted size of cell
        // outside layer.
        //finalLayerThickness 0.5;
        // Wanted thickness of the layer next to the wall.
        // outside layer.
        firstLayerThickness 0.1;
        // Wanted overall thickness of layers.
        // outside layer.
        //thickness 0.5
    // Minimum overall thickness of total layers. If for any reason layer
    // cannot be above minThickness do not add layer.
    // outside layer..
    minThickness 1e-30;
    // Per final patch (so not geometry!) the layer information
    // Note: This behaviour changed after 21x. Any non-mentioned patches
    //       now slide unless:
    //          - nSurfaceLayers is explicitly mentioned to be 0.
    //          - angle to nearest surface < slipFeatureAngle (see below)
    layers
        wall_fluide
            nSurfaceLayers  5 ;
        wall_inlet
            nSurfaceLayers  5 ;
        wall_outlet1
            nSurfaceLayers  5 ;
        wall_outlet2
            nSurfaceLayers  5 ;
        wall_outlet3
            nSurfaceLayers  5 ;
    nGrow 0;
    // Advanced settings
    // Static analysis of starting mesh
        // When not to extrude surface. 0 is flat surface, 90 is when two faces
        // are perpendicular
        featureAngle  270 ;
        // Stop layer growth on highly warped cells
        maxFaceThicknessRatio 0.5;
    // Patch displacement
        // Number of smoothing iterations of surface normals
        nSmoothSurfaceNormals 1;
        // Number of smoothing iterations of interior mesh movement direction
        nSmoothNormals 3;
        // Smooth layer thickness over surface patches
        nSmoothThickness 10;
    // Medial axis analysis
        // Angle used to pick up medial axis points
        // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130
        // in 17x.
        minMedialAxisAngle 90;
        minMedianAxisAngle 90;
        // Reduce layer growth where ratio thickness to medial
        // distance is large
        maxThicknessToMedialRatio 0.3;
        // Optional: limit the number of steps walking away from the surface.
        // Default is unlimited.
        //nMedialAxisIter 10;
        // Optional: smooth displacement after medial axis determination.
        // default is 0.
        //nSmoothDisplacement 90;
        // (wip)Optional: do not extrude a point if none of the surrounding points is
        // not extruded. Default is false.
        //detectExtrusionIsland true;
    // Mesh shrinking
        // Optional: at non-patched sides allow mesh to slip if extrusion
        slipFeatureAngle 70;
        nRelaxIter 5;
        // Create buffer region for new layer terminations
        nBufferCellsNoExtrude 0;
        nLayerIter 60;
        //nRelaxedIter 20;
        // Additional reporting: if there are just a few faces where there
        // are mesh errors (after adding the layers) print their face centres.
        // This helps in tracking down problematic mesh areas.
        //additionalReporting true;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
    // Specify mesh quality constraints in separate dictionary so can
    // be reused (e.g. checkMesh -meshQuality)
    #include "meshQualityDict"
    // Optional : some meshing phases allow usage of relaxed rules.
    // See e.g. addLayersControls::nRelaxedIter.
    relaxed
        // Maximum non-orthogonality allowed. Set to 180 to disable.
        maxNonOrtho 70;
    //minFlatness 0.5;
    // Advanced
        // Number of error distribution iterations
        nSmoothScale 4;
        // amount to scale back displacement at error points
        errorReduction 0.75;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1e-6;
And my meshQualityDict :
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      meshQualityDict;
//- Maximum non-orthogonality allowed. Set to 180 to disable.
maxNonOrtho 65;
//- Max skewness allowed. Set to <0 to disable.
maxBoundarySkewness 4;
maxInternalSkewness 4;
//- Max concaveness allowed. Is angle (in degrees) below which concavity
//  is allowed. 0 is straight face, <0 would be convex face.
//  Set to 180 to disable.
maxConcave 80;
//- Minimum pyramid volume. Is absolute volume of cell pyramid.
//  Set to a sensible fraction of the smallest cell volume expected.
//  Set to very negative number (e.g. -1E30) to disable.
minVol 1e-13;
//- Minimum quality of the tet formed by the face-centre
//  and variable base point minimum decomposition triangles and
//  the cell centre. This has to be a positive number for tracking
//  to work. Set to very negative number (e.g. -1E30) to
//  disable.
//     <0 = inside out tet,
//      0 = flat tet
//      1 = regular tet
minTetQuality 1e-15;
//- Minimum face area. Set to <0 to disable.
minArea -1;
//- Minimum face twist. Set to <-1 to disable. dot product of face normal
// and face centre triangles normal
minTwist 0.02;
//- Minimum normalised cell determinant. This is the determinant of all
//  the areas of internal faces. It is a measure of how much of the
//  outside area of the cell is to other cells. The idea is that if all
//  outside faces of the cell are 'floating' (zeroGradient) the
//  'fixedness' of the cell is determined by the area of the internal faces.
//  1 = hex, <= 0 = folded or flattened illegal cell
minDeterminant 0.001;
//- Relative position of face in relation to cell centres (0.5 for orthogonal
//  mesh) (0 -> 0.5)
minFaceWeight 0.05;
//- Volume ratio of neighbouring cells (0 -> 1)
minVolRatio 0.01;
//- Per triangle normal compared to average normal. Like face twist
//  but now per (face-centre decomposition) triangle. Must be >0 for Fluent
//  compatibility
minTriangleTwist -1;
//- if >0 : preserve cells with all points on the surface if the
//  resulting volume after snapping (by approximation) is larger than
//  minVolCollapseRatio times old volume (i.e. not collapsed to flat cell).
//  If <0 : delete always.
//minVolCollapseRatio 0.1;
RomCFD is offline   Reply With Quote
Old   March 29, 2017, 13:01
me3840 is on a distinguished road
I find turning off the min tet quality metric helps a lot.
Also consider putting a single prism layer over that face you have with none in your images, it can help keep them from collapsing in the corner.
Obviously you also have some snapping issues there. Can you remove some of the edge refinement? Try turning up the number of feature snap iterations and a lower mesh displacement relaxation amount.
me3840 is offline   Reply With Quote
Old   March 31, 2017, 11:23
Hello !
Thank you for your answer. Indeed, I had obvious snapping issues in this case and they have been solved by increasing snap feature iterations and disabling the minTetQuality as you suggested.
Else I tried your other advices but they didn't solve completely the layering issue. I managed to have perfect layers on top and bottom cylinders which are aligned with the coordinate system (see img 1), but on the side cylinders the layering process seems to remove some cells (img 2 & 3). The checkMesh says it is ok but it will certainly have an impact on the simulation next.
Also, it's a bit out of the subject but I discovered that snappy didn't create my cellZones(Entree, Sortie.. and Fluide ) as I wanted :
Time:constant  cells:522769  faces:1616293  points:575123  patches:9   bb:(-330.706645193 -5 -304) (330.707619973 205 304.000000914)
cellZones:
    Entree    size:0
    Sortie1    size:16739
    Sortie2    size:0
    Sortie3    size:0
    Fluide    size:453633
Yet, I have imported the 5 cellZones as stl (closed surfaces) in the geometry part and declared them in castellated part. Is this the good method to add directly cellZones with SHM ?
OpenFoam 4.1
Old   November 29, 2019, 11:02
Kahnbein.Kai is on a distinguished road
i know its an old post, but i got the same problem.
These are my option at SnappyHexMesh
Solver iterations: 150
Relax iterations: 30
Max mesh conformation iterations: 30
Feature angle: 270°
Slip feature angle: 75°
I got these collapsing Layers at the edges, like in the pictur.
Does someone got any suggestions to avoid this ?
Best regards
Kai
Kahnbein.Kai is offline   Reply With Quote
Old   January 17, 2020, 04:42
john myce is on a distinguished road
Hello Kai,
I don't know if you have solved your problem since November. I'm trying to investigate how snappyHexMesh is working and I've found that if you increase your nSmoothSurfaceNormals iteration from 10 to 50, it can help to have a better distribution of prism layers over a surface.
Furthermore, having a feature angle (for the addlayer controls) more than 180 degrees even 150 degrees does not change so much the quality of the mesh. On the contrary it can produce the opposite effect on the mesh quality.
And finally I don't know if you have decreased the resolvefeatureangle (around 15 degrees for the castellated mesh) which can help to add layer on sharp surface.
Cheers,
belier1988 and Kahnbein.Kai like this.
john myce is offline   Reply With Quote
Old   January 18, 2020, 02:39
Hey John,
yes i solve this problem, i use cfMesh, to create the boundary layers.
I will try your suggestions, it has to be possibly to create a proper mesh with SHM.
Best regards
Kai
[snappyHexMesh] Layers collapsing max.pow OpenFOAM Meshing & Mesh Conversion 6 October 15, 2021 06:54
[snappyHexMesh] Collapsing layers michi.ka OpenFOAM Meshing & Mesh Conversion 6 September 22, 2018 10:20
[snappyHexMesh] Layers collapsing problem Manideep Reddy OpenFOAM Meshing & Mesh Conversion 2 March 12, 2018 08:09
[snappyHexMesh] SHM addLayers problem: boundary layers collapsing on a patch DOFuser OpenFOAM Meshing & Mesh Conversion 1 October 22, 2015 09:09
[snappyHexMesh] Collapsing Layers Tim_Simon OpenFOAM Meshing & Mesh Conversion 5 August 2, 2015 23:51
