[mesh manipulation] cellSet using setSet
Like Tree1Likes
  • 1 Post By mgab
Old   February 13, 2017, 08:13
Default cellSet using setSet
mgab is on a distinguished road
Hi
i'm following a tutorial in which is required to use cellSet but i saw that the tool merged into setSet. But i don't know how to use it!
The original cellSetDict is this:
// Name of set to operate on
name c0;
// One of clear/new/invert/add/delete|subset/list
action new;
// Actions to apply to cellSet. These are all the topoSetSource's ending
// in ..ToCell (see the meshTools library).
topoSetSources
    // Cells with cell centre within box
    boxToCell
       box   (0.1 0.05 0) (0.4 0.15 0.005);
Can anyone explain to me how to have the same result using setSet?
Thanks!
frantov likes this.
mgab is offline   Reply With Quote
Old   February 13, 2017, 12:33
cutter is on a distinguished road
please have a look at the following two wiki pages:
https://openfoamwiki.net/index.php/SetSet
https://openfoamwiki.net/index.php/TopoSet
I have no case to test against, but the given cellSetDict should translate to something like the following command in setSet:
cellSet c0 new boxToCell (0.1 0.05 0) (0.4 0.15 0.005)
Good luck!
Cutter
cutter is offline   Reply With Quote
Old   February 13, 2017, 13:14
Yes it works!
Thanks!
cellset, cellsetdict, setset
[snappyHexMesh] MultiRegion(Snappy): how to define new zones Cartuns11 OpenFOAM Meshing & Mesh Conversion 6 May 3, 2019 13:02
cellSet volume in fvOptions pablo_fil OpenFOAM Running, Solving & CFD 6 April 21, 2017 05:47
Access to cellid in cellSet Tobi OpenFOAM Programming & Development 5 April 16, 2017 22:05
irregular model simulation with chtMultiregionFoam lg88 OpenFOAM 59 July 28, 2016 12:44
Creating a cellSet fom yPlus buffi OpenFOAM Post-Processing 0 December 17, 2012 05:19
