January 10, 2017, 11:53 |
Creating baffles in blockMesh
Dario
Hello, I'm new to OpenFoam and I'm trying to learn it for a project in my college curriculum.
I' having a problem defining an internal face of a block mesh as a baffle. Mesh is defined in a blockMeshDict. I'm trying to define an internal face in blockMeshDict, so I can run createBaffles utility which requires a name of a face in createBafflesDict. I've tried defining an internal face as: Code:
plate { type patch; faces ( (5 6 14 13) (6 5 13 14) ); } Code:
Trying to specify a boundary face 4(5 6 14 13) on the face on cell 2 which is either an internal face or already belongs to some other patch. This is face 0 of patch 4 named plate. Code:
patches ( baffleLeft { type baffle; neighbourPatch right; faces ((5 6 14 13)); } right { type baffle; neighbourPatch left; faces ((6 5 13 14)); } ); Code:
--> FOAM FATAL IO ERROR: wrong token type - expected word, found on line 166 the punctuation token '{' Code:
baffles { baffleFaces { type faceZone; zoneName plate; flip false; patches { master { name plate; type wall; } slave { ${..master} } } } } Thanks in advance. |
January 23, 2017, 13:46 |
Not an easy one ...
Denys Wickens
Rep Power: 9 |
To get this to work you need to have the correct block-naming in blockMesh. This then creates the cellSets for the named blocks that topoSet can convert into faceZoneSets that createBaffles can use to make your baffles out of internal faces. Then edit all of the new patches in the new directory (with me it was 0.25) away from calculated to something sensible for your case and it'll run.
I actually learned all of this from CFD threads (so thanks to lots of people): my contribution is mostly in changing the formats so that they run in openFoam 4.1 where the original no longer would. So in blockMesh, add a name to each block you want to have an internal face become a baffle (I couldn't see this in the manual). Two blocks will need naming per baffle. hex (42 43 73 72 48 49 79 78) block27 ( 4 4 10) simpleGrading (1 1 1) Run blockMesh to make sure you are error-free before you start. You will also need the blocks to have an internal face that is the size and shape in the correct location for a baffle. For me this meant re-doing the blocks to get in the extra internal boundaries. In the required topSetDict file (in the system directory) have code such as the following. I've done this step-by-step because I'm also a beginner. A skilled practitioner could probably do this in half the statements. { name csBaffle0; type cellSet; action new; source zoneToCell; sourceInfo { name block27; } } { name csBaffle0_1; type cellSet; action new; source zoneToCell; sourceInfo { name block42;// Matching faces with block27 are to become a baffle. } } // convert to faces { name fsBaffle0; type faceSet; action new; source cellToFace; sourceInfo { set csBaffle0; option all; } } // get the common subset { name fsBaffle0; type faceSet; action subset; source cellToFace; sourceInfo { set csBaffle0_1; option all; } } // convert to a Zone { name fzsBaffle0; type faceZoneSet; action new; source setToFaceZone; sourceInfo { faceSet fsBaffle0; } } // end of baffle 0 In the createBafflesDict (in the system directory) have code such as: internalFacesOnly true; // Baffles to create. baffles { aBaffle11 { //- Use predefined faceZone to select faces and orientation. type faceZone; zoneName fzsBaffle0; patches { master { //- Master side patch name baf0_half0; type wall; neighbourPatch baf0_half1; } slave { //- Slave side patch name baf0_half1; type wall; neighbourPatch baf0_half0; } } } } Sequentially run blockMesh, checkMesh, topoSet, createBaffles and checkMesh from the terminal. If nothing crashes and you don't get error messages, edit the patch conditions for you new patches in the files in the new 0.25 directory created by createBaffles, rename your old 0 directory to 0.org, the new directory to 0, and run. It (eventually) did for me! |
[blockMesh] Wierd behaviour of blockMesh creating axis in wedge | rcastilla | OpenFOAM Meshing & Mesh Conversion | 1 | December 4, 2018 06:24 |
[Gmsh] Creating 2 baffles in geometry | caja94 | OpenFOAM Meshing & Mesh Conversion | 1 | October 7, 2018 04:05 |
[blockMesh] Segmentation Fault when creating block mesh topography (blockMesh) | jbrydg01 | OpenFOAM Meshing & Mesh Conversion | 2 | May 11, 2017 05:37 |
[blockMesh] Error while running blockMesh | Harak | OpenFOAM Meshing & Mesh Conversion | 0 | December 11, 2014 09:36 |
Possible Bug in pimpleFoam (or createPatch) (or fluent3DMeshToFoam) | cfdonline2mohsen | OpenFOAM | 3 | October 21, 2013 09:28 |
