[blockMesh] codeStream error: Failed wmake "dynamicCode/_..
Like Tree11Likes
  • 10 Post By chienfm
  • 1 Post By NachoZ
Old   December 7, 2016, 11:59
Question codeStream error: Failed wmake "dynamicCode/_..
David Kinast
david112 is on a distinguished road
I want to run blockMesh on an server. I tried the same mesh with the same OpenFoam version (4.1) an the same distribtion (Ubuntu 16.04 LTS) on my local computer an it worked. Now on the server it does not.
I tried to check nearly every file. I cannot find any difference.
I testet some ideas from this forum but found no working solution and now I hope for your help.
Thats what my blockMesh log file says:
|  \\    /   O peration     | Version:  4.1                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 4.1-1e03d68d4f4e
Exec   : blockMesh
Date   : Dec 07 2016
Time   : 14:51:46
Host   : "ip-172-31-13-78"
PID    : 1725
Case   : /home/ubuntu/Simulationen/kklOmegaSymmetry
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Creating block mesh from
    "/home/ubuntu/Simulationen/kklOmegaSymmetry/system/blockMeshDict"
Using #calcEntry at line 25 in file "/home/ubuntu/Simulationen/kklOmegaSymmetry/system/blockMeshDict"
Using #codeStream with "/home/ubuntu/Simulationen/kklOmegaSymmetry/dynamicCode/platforms/linux64GccDPInt32Opt/lib/libcodeStream_c7a725dacc55f2ad268ffdbc83a569d9a0f9ba99.so"
Invoking "wmake -s libso /home/ubuntu/Simulationen/kklOmegaSymmetry/dynamicCode/_c7a725dacc55f2ad268ffdbc83a569d9a0f9ba99"
/opt/openfoam4/wmake/wmake: 346: /opt/openfoam4/wmake/wmake: make: not found
/opt/openfoam4/wmake/wmake: 349: /opt/openfoam4/wmake/wmake: make: not found
wmake error: file 'Make/linux64GccDPInt32Opt/sourceFiles' could not be created in /home/ubuntu/Simulationen/kklOmegaSymmetry/dynamicCode/_c7a725dacc55f2ad268ffdbc83a569d9a0f9ba99
--> FOAM FATAL IO ERROR:
Failed wmake "dynamicCode/_c7a725dacc55f2ad268ffdbc83a569d9a0f9ba99/platforms/linux64GccDPInt32Opt/lib/libcodeStream_c7a725dacc55f2ad268ffdbc83a569d9a0f9ba99.so"
file: /home/ubuntu/Simulationen/kklOmegaSymmetry/system/blockMeshDict from line 19 to line 24.
    From function static void (* Foam::functionEntries::codeStream::getFunction(const Foam::dictionary&, const Foam::dictionary&))(Foam::Ostream&, const Foam::dictionary&)
    in file db/dictionary/functionEntries/codeStream/codeStream.C at line 175.
FOAM exiting
If theres further information needed to solve this problem, please let me know.
david
david112 is offline   Reply With Quote
Old   February 27, 2017, 06:45
Ngo Bao Chung
chienfm is on a distinguished road
Hi David,
It's a little bit late but the error appears since make is not installed in your system or the path has a problem. Installing make may solve this trouble.
In Ubuntu, you may use:
sudo apt-get remove make
sudo apt-get install make
or:
sudo apt-get install --reinstall make
Hope it also helps someone get the same trouble.
chienfm is offline   Reply With Quote
Old   April 1, 2017, 18:45
Mojtaba.a's Avatar
Mojtaba Amiraslanpour
Mojtaba.a is on a distinguished road
Send a message via Skype™ to Mojtaba.a
Originally Posted by chienfm View Post
Hi David,
Didn't expect that to solve my problem! I had this problem compiling swak4Foam.
Thank Ngo.
Learn OpenFOAM in Persian
SFO (StarCCM+ FLUENT OpenFOAM) Project Team Member
Complex Heat & Flow Simulation Research Group
If you can't explain it simply, you don't understand it well enough. "Richard Feynman"
Mojtaba.a is offline   Reply With Quote
Old   May 3, 2017, 08:37
David Kinast
Hi David,
Thanks!
I can't remenber, but I think thats what helped in my case.
Old   December 14, 2017, 21:48
Rui
roi247 is on a distinguished road
thank you Chienfm ....it is working for me too
roi247 is offline   Reply With Quote
Old   November 17, 2020, 03:29
Stanley90 is on a distinguished road
Hi David,
Thanks chienfm, it works for me too!
Stanley90 is offline   Reply With Quote
Old   September 22, 2022, 12:40
Default Reinstalling make didn't work
Ignacio Z
NachoZ is on a distinguished road
I tried reinstalling make as suggested by @chienfm and my OpenFoam was deleted. I do not know why that happenend but now I have to reinstall everything as it was including extra solvers and platforms I had installed. I am not sure if it will solve the problem once it is reinstalled, but I doubt it. Careful when using these instructions for yourselves.
MayReyes likes this.
NachoZ is offline   Reply With Quote
blockmesh, codestream, error, wmake
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 09:48
Problems Installing OF 1.6 32 bit bucksfan OpenFOAM Installation 19 August 4, 2009 02:36
OpenFOAM15 installables are incomplete problem with paraFoam tryingof OpenFOAM Bugs 17 December 7, 2008 05:41
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 22:45
[OpenFOAM] ParaFoam error message joey ParaView 1 October 2, 2006 14:28
