[snappyHexMesh] weird resolveFeatureAngle or misconception
Like Tree1Likes
  • 1 Post By fracasce
Old   July 6, 2016, 14:37
Default weird resolveFeatureAngle or misconception
Almond Wong
BakedAlmonds is on a distinguished road
Before I make my point, correct me if I am wrong.
In sHMD, when 2 level of refinement for the surface are defined, one of the factors resulting in the higher level of refinement is the resolveFeatureAngle. Of which any angle higher than the specified angle will have the maximum level of refinement specified.
Doesn't it sound weird to have higher refinement when the angle is larger as this would mean a gentler curve, edge, corner etc. Normally, parts that are harder to get are areas with sharp edges (lower angle).
For example a wedge (90 degree) on a plate (180 degree). With a resolveFeatureAngle of 100 degree would make the plate have the maximum refinement level (as 180 > 100) and the edge between the plate and the wedge at a lower refinement level (as 90 < 100).
Is there other way to manipulate or use this function?
BakedAlmonds is offline   Reply With Quote
Old   December 8, 2016, 08:02
Default Confirmation that others have the same pondering
Tobias Lindström
tobiaslindstrom is on a distinguished road
Due to the absence of replies, and in order to highlight that there are others who have encountered this strange interpretation and perplexing conclusion, I would like to say that I have the same interpretation as you do, and do not understand what the parameter is supposed to do given the way I interpret its function. I can see no other than your interpretation to:
"resolveFeatureAngle Applies maximum level of refinement to cells that can see intersections whose angle exceeds this."
and yet I cannot square it with the intention of, as you say, having higher refinement applied to large rather than small angles.
It would be greatly appreciated if someone more knowledgeable could give some clarity into the matter.
tobiaslindstrom is offline   Reply With Quote
Old   May 6, 2017, 16:24
Franco
fracasce is on a distinguished road
I know it is a late, but I've found an interesting explication of the resolvefeatureangle in this presentation, starting from the 220 page of the following pdf: http://www.dicat.unige.it/guerrero/o...ng/module3.pdf
I hope it helps!
Franco
fracasce is offline   Reply With Quote
Old   December 30, 2022, 07:33
Aditya Chaudhary
fluidist.adi15 is on a distinguished road
I hope it helps!
Franco
Hi! Do you still have this pdf? Thanks!
fluidist.adi15 is offline   Reply With Quote
Old   January 4, 2023, 17:37
Default answer to post
Franco
Hello, please have a look to this pdf: https://www.dropbox.com/search/perso...05123703344216
Old   January 5, 2023, 23:51
Aditya Chaudhary
Hi! Sorry but the search result shows "no results found" with the link you shared.
Old   January 5, 2023, 23:54
Default try this
Franco
https://www.dropbox.com/sh/o9knx9gqg...K7-yl5-Za?dl=0
allanZHONG likes this.
feature angle, resolve
Weird thing in AMI boundary condition in OpenFOAM mortezahdr OpenFOAM Running, Solving & CFD 1 December 3, 2018 16:31
[ANSYS Meshing] Weird Meshing Problems Engineer23 ANSYS Meshing & Geometry 6 November 21, 2016 06:30
Weird AMI Courant Number Vyssion OpenFOAM Running, Solving & CFD 3 April 13, 2016 03:31
Weird reversed flow problem Kimican Main CFD Forum 0 February 26, 2016 19:15
Something weird encountered when running OpenFOAM in parallel on multiple nodes xpqiu OpenFOAM Running, Solving & CFD 2 May 2, 2013 05:59
