[Gmsh] STL on Gmsh + Mesh on Snappy
Like Tree1Likes
  • 1 Post By Antimony
Old   May 19, 2016, 12:56
Default STL on Gmsh + Mesh on Snappy
AdOo
adrieno is on a distinguished road
Hi all,
As I said in the title, I'am trying to make a geometry (a simple cube) on Gmsh then to mesh around this cube in a bigger box with snappy. I've seen that it is possible but I couldn't make it for the moment...
My problem comes from my geometry in ( .stl ). Snappy run very well and mesh all my domain (as my geometry didn't exist).
And actually my geometry didn't exist.... my .stl in empty (I linked it, just remove the .txt).
I think that comes from the fact that when I save it, the .stl extension seems to concerned only the mesh, not the geometry (I've posted a photo) whereas I didn't create any mesh...
Should I create a mesh inside my cube with Gmsh which will not been use after because snappy will mesh outside the cube in order just to "shape the geometry" ?
Thank you for any help,
Adrien
File Type: txt cube.stl.txt (49 Bytes, 9 views)
adrieno is offline   Reply With Quote
Old   May 20, 2016, 09:11
AdOo
Hi again,
I've define a mesh with Gmsh (just a single hexahedral cell to make my cube) before saving my file in .stl. Now, when I'm importing this geometry it seems to work fine, snappy is meshing all around my cube.
BUT, there is a but... As you can see in the picture, snappy doesn't fit perfectly the cube... what is it due to ?
  • Is it still a geometry problem (from my .stl file, because I wasn't suppose to make it like that) ,
  • or is it something about my snappyHexMeshDict that I have to adjust now ?
Have a nice day
Old   May 20, 2016, 09:31
AdOo
Hi all,
My problem was coming from my snappyHexMeshDict:
replacing
cube.stl
            // Surface-wise min and max refinement level
level (3 4);
by
cube.stl
level (4 4);
Well, that's the end for this topic I think...
Have a nice day, and good luck for your project
Old   May 20, 2016, 13:22
Antimony is on a distinguished road
If you want to capture the edges of the cube, you could also increase the feature refinement. Take note that you would need to have an eMesh for this before you run snappy. The eMesh file can be obtained from the surfaceFeatureExtract command.
Cheers,
Antimony
adrieno likes this.
Antimony is offline   Reply With Quote
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 06:38
[snappyHexMesh] 'cracks' in Mesh on surface using STL Fschi OpenFOAM Meshing & Mesh Conversion 5 January 19, 2017 13:24
[ICEM] STL file! How is it useful? bidi ANSYS Meshing & Geometry 0 December 26, 2016 22:33
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 19:10
