[blockMesh] blockMesh error - Negative Volume Block
Like Tree3Likes
  • 2 Post By Antimony
  • 1 Post By Mojtaba6974
Old   March 19, 2016, 11:35
Default blockMesh error - Negative Volume Block
Mateus Peixoto
adoledin is on a distinguished road
Hi all,
I'm pretty new at OpenFoam.
I want the pitzDaily case but with another geometry.
When I run blockMesh I got this error:
| \\ / O peration | Version: 2.1.1 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.1.1-221db2718bbb
Exec : blockMesh
Date : Mar 19 2016
Time : 11:30:15
Host : "mateus-HP-G42-Notebook-PC"
PID : 9692
Case : /home/mateus/Desktop/pitzDaily
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Creating block mesh from
"/home/mateus/Desktop/pitzDaily/constant/polyMesh/blockMeshDict"
Creating curved edges
Creating topology blocks
Creating topology patches
Creating block mesh topology
--> FOAM Warning :
From function cellModel::mag(const labelList&, const pointField&)
in file meshes/meshShapes/cellModel/cellModel.C at line 128
zero or negative pyramid volume: -0.133333 for face 0
--> FOAM Warning :
zero or negative pyramid volume: -0.133333 for face 1
--> FOAM Warning :
zero or negative pyramid volume: -0.133333 for face 2
--> FOAM Warning :
zero or negative pyramid volume: -0.133333 for face 3
--> FOAM Warning :
zero or negative pyramid volume: -0.133333 for face 4
--> FOAM Warning :
zero or negative pyramid volume: -0.133333 for face 5
--> FOAM Warning :
From function blockMesh::createTopology(IOdictionary&)
in file blockMesh/blockMeshTopology.C at line 255
negative volume block : 0, probably defined inside-out
--> FOAM Warning :
zero or negative pyramid volume: -0.666667 for face 0
--> FOAM Warning :
zero or negative pyramid volume: -0.666667 for face 1
--> FOAM Warning :
zero or negative pyramid volume: -0.666667 for face 2
--> FOAM Warning :
zero or negative pyramid volume: -0.666667 for face 3
--> FOAM Warning :
zero or negative pyramid volume: -0.666667 for face 4
--> FOAM Warning :
zero or negative pyramid volume: -0.666667 for face 5
--> FOAM Warning :
negative volume block : 1, probably defined inside-out
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
--> FOAM Warning :
negative volume block : 2, probably defined inside-out
Check topology
Basic statistics
Number of internal faces : 2
Number of boundary faces : 14
Number of defined boundary faces : 14
Number of undefined boundary faces : 0
Checking patch -> block consistency
Creating block offsets
Creating merge list .
Creating polyMesh from blockMesh
Creating patches
Creating cells
Creating points with scale 0.001
Writing polyMesh
Mesh Information
boundingBox: (0 0 -0.0001) (0.012 0.004 0.0001)
nPoints: 65062
nCells: 32000
nFaces: 128530
nInternalFaces: 63470
Patches
patch 0 (start: 63470 size: 40) name: inlet
patch 1 (start: 63510 size: 80) name: outlet
patch 2 (start: 63590 size: 450) name: upperWall
patch 3 (start: 64040 size: 490) name: lowerWall
patch 4 (start: 64530 size: 64000) name: frontAndBack
End
adoledin is offline   Reply With Quote
Old   March 20, 2016, 09:26
Antimony is on a distinguished road
Since blockMesh says there are negative volumes, the most probable reason is the way in which you have defined your vertices and the block made up of these vertices.
http://cfd.direct/openfoam/user-guide/blockMesh/
The link gives you the description on how to create the blockMesh.
In the case of a simple cube, I define the vertices of the lower square first before the upper square. For each of the squares, I start from the lower left, move in a anti-clockwise manner to the upper left.
Eg:
//Lower square
(0 0 0)
(0 1 0)
(1 1 0)
(1 0 0)
//Upper square
(0 0 1)
(0 1 1)
(1 1 1)
(1 0 1)
hex (0 1 2 3 4 5 6 7) ...
Hope this helps.
Cheers,
Antimony
Shri Hari and Mojtaba6974 like this.
Antimony is offline   Reply With Quote
Old   June 22, 2016, 11:44
Red face
Mojtaba
Mojtaba6974 is on a distinguished road
i think its because of your chosen axis, they may be different from axis that are defined on openFoam.
meshman likes this.
Mojtaba6974 is offline   Reply With Quote
Problem with blockMesh cshsgy OpenFOAM Pre-Processing 2 October 2, 2017 12:46
Block showing negative volume in pointwise skn455 Pointwise & Gridgen 1 September 29, 2014 20:42
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
[blockMesh] subtract volume in blockMesh Smed OpenFOAM Meshing & Mesh Conversion 2 April 16, 2012 09:57
