[blockMesh] FOAM FATAL IO ERROR_Cannot find patchField entry |
January 21, 2016, 07:07 |
Mohsen
Rep Power: 14 |
Hi Everybody
i'm trying to create a geometry with blockMesh but when i want to run the Mesh and see the result, it will jump out from paraview automatically it can create the mesh and when i use checkMesh, it say it's ok but i can't see my Shape. please help Me .... here is the error that i see in my terminal Thank you ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~ Checking geometry... Overall domain bounding box (0 0 0) (7 4 1) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (2.6723e-16 9.71858e-17 -5.45199e-17) OK. Max cell openness = 8.67362e-17 OK. Max aspect ratio = 1 OK. Minimum face area = 0.01. Maximum face area = 0.01. Face area magnitudes OK. Min volume = 0.001. Max volume = 0.001. Total volume = 10. Cell volumes OK. Mesh non-orthogonality Max: 0 average: 0 Non-orthogonality check OK. Face pyramids OK. Max skewness = 6.89684e-14 OK. Coupled point location match (average 0) OK. Mesh OK. End top@top-Lenovo-G580:~/OpenFOAM/top-3.0.0/run/examples/pitzDaily$ paraFoam Created temporary 'pitzDaily.OpenFOAM' --> FOAM FATAL IO ERROR: Cannot find patchField entry for inlet_two file: /home/top/OpenFOAM/top-3.0.0/run/examples/pitzDaily/0/p.boundaryField from line 25 to line 39. From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&) in file /home/openfoam/OpenFOAM/OpenFOAM-3.0.0/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 209. FOAM exiting ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ ~~~~~~~~~~~~~~ |
January 21, 2016, 09:24 |
#2 | |
Dear Mohsen,
Jibran Haider |
January 21, 2016, 09:51 |
Mohsen
Rep Power: 14 |
Thank you for your help Sir
blockmesh, fatalerror, geometery, parafoam |
Incompatible dimensions for operation | ruben23 | OpenFOAM Running, Solving & CFD | 2 | June 12, 2015 05:14 |
[Other] Cannot find patchField entry for walls | eruwaedhiel | OpenFOAM Meshing & Mesh Conversion | 0 | June 8, 2015 23:57 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 05:38 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
