[blockMesh] About Simple Grading in blockMesh
Like Tree9Likes
  • 1 Post By ce73stargazer
  • 5 Post By Antimony
  • 2 Post By Tobermory
  • 1 Post By Zetison
Old   January 10, 2016, 21:47
Default About Simple Grading in blockMesh
Zhifang Hu
ce73stargazer is on a distinguished road
I understand simple grading is the ratio between the size of the end cell and the size of initial cell.
How about the cell size in between, what kind of changes they follow to reach the final cell?
Like constant changes?
For instane, the first cell is size 10 and the last cell is size 5, the middle cells will have a size 10-dx*(N-1) ? where the dx is the constant changes between cells, N is the number of cells in that direction.
This is how i understand it, not sure if thats right.
I am writing a small code to output the cell ID by just inputting the x,y coordinates, however i realised that it only work fine for uniform distributed mesh, not the one with gradings. Hence i came out with this question. Any one have any suggestions? (Or if anyone has faster way to output cell ID (in paraview) and dont mind share with me)
Many Thanks.
pedroamaral likes this.
ce73stargazer is offline   Reply With Quote
Old   January 12, 2016, 05:45
Antimony is on a distinguished road
The expansion is geometric, not arithmetic.
Here is a useful tool that gives you an idea about the expansion from the start cell to the end cell:
https://openfoamwiki.net/index.php/S...ng_calculation
Antimony is offline   Reply With Quote
Old   May 7, 2020, 06:50
Jon Vegard Venås
Zetison is on a distinguished road
What is the exact formula used here? With n being the number of cells, r=\frac{\delta_e}{\delta_s} being the expansion ratio, L the total length, and based on the distribution of the nodes
x_i = x_0 + L\left(\frac{i}{n}\right)^g\quad i=0,\dots,n
the following formula seems reasonable to me
\delta_s = \frac{L}{n^g}
\delta_e = L\left[1-\left(\frac{n-1}{n}\right)^g\right]
Alternatively, the formulas for a geometric expansion
x_i = x_0 + L\frac{g^i-1}{g^n-1}\quad i=0,\dots,n
\delta_s = L\frac{g-1}{g^n-1}
\delta_e = L\left[1-\frac{g^{n-1}-1}{g^n-1}\right]
but neither matches the program (or OpenFoam?). What is wrong here?
Zetison is offline   Reply With Quote
Old   May 8, 2020, 08:47
Tobermory will become famous soon enough
Apologies, I did not try to debug your maths above, but for simplicity I will give you the correct expressions below in a simpler and more standard terminology.
For a set of n cells, with vertices x_i, where i varies from 0 to N, then the cell width is the gap between the vertices. If we define a constant stretching rate of \beta then:
\delta_i = (x_{i+1} - x_i) = \beta \delta_{i-1}
Armed with this, you can get to the following:
\delta_i = \beta^i \delta_0
now r = \delta_{n-1} / \delta_0, the ratio of the last to the first cell width, so:
r = \beta^{n-1}
The \delta_i's form a geometric progression, the sum of which is:
Sum_i = \delta_0 + \delta_1 + ... + \delta_i = \delta_0 (1 - \beta^i)/(1 - \beta)
So, the coord of vertex i is:
x_i = x_0 + Sum_i = x_0 + \delta_0 (1 - \beta^i)/(1 - \beta)
Finally, the cell centre is defined as
xc_i = x_i + 0.5 \delta_i
so you can then calculate the cell coords using xc_i. This is probably what you are outputing from OpenFOAM when you are doing the comparison.
Here's a worked example:
n = 5
beta = 1.3
r = 2.8561
i, x, dx, xc
0 0.000 0.100 0.050
1 0.100 0.130 0.165
2 0.230 0.169 0.315
3 0.399 0.220 0.509
4 0.619 0.286 0.762
5 0.904
Hope this helps - good luck!
(PS - can someone tell me how to format a table in a post, to get the spacing right?)
ruloz and GregNordin like this.
Tobermory is online now   Reply With Quote
Old   May 9, 2020, 06:37
Jon Vegard Venås
Thanks for your reply, your formula gets me very close. Given a length L=x_N-x_0, the width of the start cell \delta_0 and the end cell \delta_{N-1} one can compute the number of cells N using the equations
r = \beta^{n-1}=\frac{\delta_{n-1}}{\delta_0}
L = x_N-x_0
Solving yields
\beta = \frac{L-\delta_0}{L-\delta_{N-1}}
such that
N = 1+\frac{\ln\frac{\delta_{N-1}}{\delta_0}}{\ln\frac{L-\delta_0}{L-\delta_{N-1}}}
For L = 1, \delta_0 = 0.05, \delta_{N-1}=0.2 I then get
\beta = 1.1875 and \lfloor N\rceil = 9 (rounded from 9.066873951)
Comparing this to the "Scripts/blockMesh grading calculation"-tool we have
                         \beta               N
My computation           1.1875          9.066873951
Calculator-tool          1.189207115     9.066872597
Ps. I do not think it is possible to create tables here considering the lacking response on this post making table in cfd-post with example
ashvinc9 likes this.
SIMPLE algorithm in 3D cylindrical coordinates zouchu Main CFD Forum 1 January 20, 2014 18:02
Inconsistent Grading Caused by Simple Translation wildfire230 OpenFOAM Running, Solving & CFD 5 August 25, 2013 12:08
[ICEM] Subdomain meshing and simple Hexahedral Grading Mojtaba.a ANSYS Meshing & Geometry 0 April 22, 2013 14:28
[blockMesh] A simple problem about blockMesh sharonyue OpenFOAM Meshing & Mesh Conversion 2 September 30, 2012 21:34
Blockmesh cavity error message tonitoney OpenFOAM Installation 2 March 17, 2008 12:59
