[blockMesh] mergePatchPairs problem when migrating from OFext1.6 to OFext3.1
Like Tree1Likes
  • 1 Post By ma-tri-x
Old   October 27, 2015, 12:36
Default mergePatchPairs problem when migrating from OFext1.6 to OFext3.1
ma-tri-x is on a distinguished road
Hi Community!
I encounter a strange phenomenon... when I take my old mesh I used to calculate on with OFext1.6, now with OFext3.1, mergePatchPairs inside the blockMeshDict seems to not work properly anymore. When I open the Mesh with paraFoam (paraview version 4.4.0, thirdparty built-in), I get the error that faces and owners do not match:
Warning: In /home/kitware/Dashboards/buildbot/paraview-debian4dash-linux-shared-release_qt4_superbuild/source-paraview/VTK/IO/Geometry/vtkOpenFOAMReader.cxx, line 4744
vtkOpenFOAMReaderPrivate (0x4a9e3c0): Numbers of faces in faces 257521 and owner 256973 does not match
can anyone tell me why this is the case?
I can view the mesh when I do not apply mergePatchPairs, but of course I the cannot do calculations. Here's a minimal example:
|  \\    /   O peration     | Version:  2.0.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version         2.0;
    format          ascii;
    root            "";
    case            "";
    instance        "";
    local           "";
    class           dictionary;
    object          blockMeshDict;
convertToMeters 1;
vertices
(0 0  0)         // Vertex lfb = 0
(1 0  0)         // Vertex rfb = 1
(1 0 -1)         // Vertex rrb = 2
(0 0 -1)         // Vertex lrb = 3
(0 1  0)         // Vertex lft = 4
(1 1  0)         // Vertex rft = 5
(1 1 -1)         // Vertex rrt = 6
(0 1 -1)         // Vertex lrt = 7
(1 0  0)         // Vertex LFB = 8
(2 0  0)         // Vertex RFB = 9
(2 0 -1)         // Vertex RRB = 10
(1 0 -1)         // Vertex LRB = 11
(1 1  0)         // Vertex LFT = 12
(2 1  0)         // Vertex RFT = 13
(2 1 -1)         // Vertex RRT = 14
(1 1 -1)         // Vertex LRT = 15
blocks
  hex (0 1 2 3   4 5 6 7) (10 10 10) simpleGrading (2 1 1)
  hex (8 9 10 11   12 13 14 15) (10 20 10) simpleGrading (1 1 1)
edges
patches
    patch wall
        (0 1 2 3)
        (11 8 9 10)
        (7 4 5 6)
        (15 12 13 14)
        (3 2 6 7)
        (11 10 14 15)
        (0 1 5 4)
        (8 9 13 12)
        (3 0 4 7)
        (10 9 13 14)
    patch left
        (1 2 6 5)
    patch right
        (8 12 15 11)
mergePatchPairs
    (right left)
For the minimal example I could fix the problem when using stitchMesh instead of mergePatchPairs. However for the bigger example, I do not know how to apply stitchMesh repeatedly to different patch pairs.
Thanks for any suggestions!!!
Max
ma-tri-x is offline   Reply With Quote
Old   October 29, 2015, 10:01
Default work around
A colleage of mine found a work-around solution:
- decompose the mesh with decomposePar (if necessary only one domain)
- copying the parts processor*/0/polyMesh into processor*/constant
- loading the 'decomposed' case in paraview
in bash:
#! /bin/bash
for dir in `ls -d processor*`;
do
  cd $dir
  mkdir constant/
  cp -rp 0/polyMesh constant/
  cd ../
done
indeed that works. I consider this is an OFext3.1 bug. Does anyone know why this happens?
Best regards,
Max
bigorange likes this.
Old   January 12, 2021, 05:23
Default Manage to solve the same problem when mergePatchPair but don't understand why
anaspauzi's Avatar
Anas Muhamad Pauzi
anaspauzi is on a distinguished road
Thank you, this solve my problem in OF4-0
just put this code into my Allrun
Could anyone explain why this work and any other alternatives
Thank you
in bash:
#! /bin/bash
do
  cd $dir
  mkdir constant/
  cd ../
done
Best regards,
Max
anaspauzi is offline   Reply With Quote
Mesh& steptime independant: conduction-convection problem Fati1 Main CFD Forum 1 October 28, 2018 14:52
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
Periodic flow boundary condition problem sudha FLUENT 3 April 28, 2004 09:40
extremely simple problem... can you solve it properly? Mikhail Main CFD Forum 40 September 9, 1999 10:11
