[blockMesh] Cylinder with special inlet
Like Tree1Likes
  • 1 Post By linnemann
Old   October 20, 2015, 13:43
Default Cylinder with special inlet
Bogdan Osyka
Bogdan90 is on a distinguished road
Hello!
I am trying to mesh entire cylinder, where I have some certain boundary condition for the inlet. This is the whole geometry for the case:
In my project I will be only working with the part of this geometry, the right cylinder. As you can see, the actual inlet here has to be defined as a circle inside of a bigger circle. So my question is what is the easiest way to implement this kind of inlet? Do I have to mesh a cylinder inside of a cylinder and define correct patches or is there a way to mesh a cylinder and have some certain condition for the inlet patch?
Thanx in advance!
Bogdan90 is offline   Reply With Quote
Old   October 22, 2015, 07:05
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
First off, if you are new to OF avoid using BlockMesh.
It will give you more headaches than joy.
Instead I recommend using Salome (salome-platform.org)
It is sorta parametric cad where you can dump your setup to a python file and run it on another computer with minimal effort.
Run the script and edit dimensions to fit your needs in the python file (rename to .py and not .py.txt).
Export mesh to unv and use openfoam command ideasUnvToFoam.
I won't give you anymore hints since the official help documentation in Salome is quite good (hit F1).
Bogdan90 likes this.
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   October 22, 2015, 16:52
Bogdan Osyka
Originally Posted by linnemann View Post
Hi
Thank you a lot for the answer! I completely agree with you that BlockMesh is a headache when it yields complex geometries. I have downloaded Salome and converted your script, which enabled me to run LES model on this geometryand it seems to be working really nice. Unfortunately after playing some hours with Salome and the geometry you 've send I still wasn't able to figure out how do I change dimensions, do I need to change them directly in the script? I would really appreciate if you could help me with that or probably point at some particular tutorial:-)
Thanks in advance
Old   February 18, 2020, 21:00
Amirhossein Taran
amirhosseintaran is on a distinguished road
hi , did you change the domain size ? if yes , then how ??
Bests.
amirhosseintaran is offline   Reply With Quote
cylinder mesh, inlet bc, pipe cross
Looping over all faces within a boundary condition (turbulent inlet development) Sevex OpenFOAM Programming & Development 5 September 8, 2016 14:58
Species mass flow inlet lorenz FLUENT 3 March 15, 2012 08:26
[blockMesh] Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 04:56
Drag cylinder : Turb at Inlet PK FLUENT 2 February 25, 2007 13:01
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
