September 21, 2015, 08:49 |
Cylinder from Gmsh to OpenFoam
S Atkinson
Rep Power: 11 |
Hi All,
I am looking to create a multiphase or baffled model and the first step for an initial model is to import a mesh. I prefer to use Gmsh due to the easy layering feature so I creased a simple two cylinders inside of each other. Point(1) = {0,0,0}; Point(2) = {0.635,0,0}; Point(3) = {0,0.635,0}; Point(4) = {-0.635,0,0}; Point(5) = {0,-0.635,0}; Point(6) = {2,0,0}; Point(7) = {0,2,0}; Point(8) = {-2,0,0}; Point(9) = {0, -2 ,0}; Circle(1) = {2,1,3}; Circle(325) = {3,1,4}; Circle(649) = {4,1,5}; Circle(973) = {5,1,2}; Circle(10) = {6,1,7}; Circle(3250) = {7,1,8}; Circle(6490) = {8,1,9}; Circle(9730) = {9,1,6}; Line Loop(100) = {1,325,649,973}; Line Loop(101) = {10,3250,6490,9730}; Plane Surface(1000) = {100}; Plane Surface(1001) = {101, 100}; surfaceVector[] = Extrude {0, 0, 16} { Surface{1000}; Layers{1}; Recombine; }; surfaceVector4[] = Extrude {0, 0, 16} { Surface{1001}; Layers{1}; Recombine; }; Physical Volume("fuel") = surfaceVector[1]; Physical Volume("block") = surfaceVector4[1]; Physical Surface("blockboundary") = {surfaceVector4[2], surfaceVector4[4], surfaceVector4[3], surfaceVector4[5]}; Physical Surface("cylinder") = {surfaceVector4[9], surfaceVector4[8], surfaceVector4[7], surfaceVector4 [6]}; Mesh.RemeshParametrization=4; Mesh.RemeshAlgorithm=1; Mesh.Algorithm = 6; Mesh.Algorithm3D = 6; Mesh.SubdivisionAlgorithm = 0; When I visualise this structure in gmsh I see all of the surfaces individually, which I want to turn into boundaries later. Unfortunately no matter what I try when I use gmshToFoam on this, the surfaces are never transferred and they are always grouped together in defaultFaces. I have also tried to extrude each volume separately however using this method the surfaces don't fully surround the cylinder when opened in paraview and the faces are placed in defaultFaces again. One way to get around this is to use splitmesh which gives me two sets of default faces which I can rename and this is an option for creating multiphase designs, however I think that Openfoam is trying to phase out multiphase designs for thermal calculations and move everything to baffles instead? I have not seen an example for baffled programs using splitmesh yet in the tutorials. Eventually I will have conduction and turbulent convection (k-epsilon model) in the model so I am looking for the easiest method to accommodate all of these properties if there are any suggestions. Cheers, Satkinson |
How to contribute to the community of OpenFOAM users and to the OpenFOAM technology | wyldckat | OpenFOAM | 17 | November 10, 2017 16:54 |
OpenFOAM 4.0 Released | CFDFoundation | OpenFOAM Announcements from OpenFOAM Foundation | 2 | October 6, 2017 06:40 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 15:24 |
Importing Mesh from GMsh to OpenFoam | bmaldi | OpenFOAM Running, Solving & CFD | 1 | May 4, 2016 12:57 |
Tube with cylinder inside in OpenFoam | orxan.shibli | OpenFOAM Running, Solving & CFD | 1 | September 6, 2015 12:53 |
