[Salome] Salome generating facezone instead of patches
Like Tree1Likes
  • 1 Post By fracasce
Old   September 14, 2015, 00:58
Cool Salome generating facezone instead of patches
Franco
fracasce is on a distinguished road
I'm trying to solve a chtMultiRegionFoam problem and I'm creating the geometry and the mesh on Salome.
I'm having troubles when I export the geometry to OpenFoam: in fact, when I lunch the command ideasUnvToFoam, I realize that some of my faces are patches (as it should be), and others are facezone. This is giving me some problems, since when I use the command ideasUnvToFoam, I get the following error
ideasUnvToFoam: ideasUnvToFoam.C:1273: int main(int, char**): Assertion `noveau > -1' failed.
Aborted (core dumped)
Could anyone help me please? I'll leave you my hdf file
Thanks in advance!!!
fracasce is offline   Reply With Quote
Old   September 19, 2015, 14:00
Franco
problem solved, I made a new geometry and I defined all the faces of the geometry
saidc. likes this.
Old   December 15, 2016, 16:11
Default Salome generating facezone instead of patches
Thodoris
teodm is on a distinguished road
Could you please tell me exactly what you did because i have done everything but still i have a facezone or cellzone boundary
teodm is offline   Reply With Quote
Old   December 16, 2016, 11:58
Franco
The problem raises once you generate a face (for instance, once you make an extrusion) that is an interface between two objects (two solids or one fluid and one solid). So, what you can do is to check that every extrusion has its own faces (and not "shared" faces): one way to solve this problem is to generate the faces (that will be used for extrusion) from lines; then, these lines will not be used by any other extrusion face.
I hope it helps!
Franco
Old   December 17, 2016, 15:23
Thodoris
Excuse me Franco but can i send you my hdf file so you can see exactly which is the problem?Thank you very much in advance.
Old   December 19, 2016, 10:47
Franco
Hi Thodoris
Upload the case in the forum, I'll give it a look later...
Franco
salome patches facezone
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
Problem using AMI vinz OpenFOAM Running, Solving & CFD 298 November 13, 2023 09:19
Possible bug with stitchMesh and cyclics in OpenFoam Jack001 OpenFOAM Pre-Processing 0 May 21, 2016 09:00
Regarding periodic BC in ICEM generated grid Tarak OpenFOAM 32 April 30, 2013 15:46
Doxygen documentation Tanay OpenFOAM Installation 9 September 23, 2011 12:40
