[Salome] Precision in UNV to FOAM mesh conversion |
August 18, 2015, 14:25 |
Richard Vega
Rep Power: 12 |
I am able to use ideasUnvToFoam with ease to convert meshes I have created using Salome into OpenFOAM format. There is only one problem: when I look at the points file that gets created in the polyMesh folder, I find that it is writing coordinates with a maximum of 5 decimal places. Is there a way to increase this precision?
August 18, 2015, 15:50 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: In your case folder, "system/controlDict" -> "writePrecision" - or in "writeFormat" use "binary" format for full precision... although it's binary.
August 19, 2015, 11:38 |
Richard Vega
Rep Power: 12 |
Thank you very much for the quick reply. It worked! For some reason I did not associate the controlDict with the mesh converters. I thought it was just for the solver to write the field variables. Thank you again!!
ideasunvtofoam |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
[Commercial meshers] fluent mesh conversion to foam | sangram | OpenFOAM Meshing & Mesh Conversion | 1 | November 14, 2016 08:14 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 04:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
